04-12-2018, 11:33 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: serbia Age: 44
Member: 1131244 Status: Offline Sonork: 100.1596724 Thanks Meter: 376 | Samsung GT-N8000 smart repair done Code: Welcome to Medusa Pro Software version 1.5.6. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Reader #2: FT SCR2000 1 Reader #3: FT SCR2000 2 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : GT-N8000 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-N8000_EMMC_MAG2GA.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC MAG2GA Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 1501004D414732474107282279421133 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : MAG2GA Product revision : 0.7 Product serial number : (hex) 28227942 Manufacturing date : 01/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFFF8A406063 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : YES TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7659520 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 1818624 Number of sectors : 2867200 Device Manufacturer :samsung Device Platform :exynos4 Build ID :KOT49H Display Build ID :KOT49H.N8000XXSDQA5 Release ID :4.4.2 Device Model :GT-N8000 Device Name :p4noterfxx Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Build Description :p4noterfxx-user 4.4.2 KOT49H N8000XXSDQA5 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/MAG2GA_12_04_2018_10_23_47.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.6; FW: 1.23. P00: GPT (00000000, 00002000) 4 MB P01: BOTA0 (00002000, 00002000) 4 MB P02: BOTA1 (00004000, 00002000) 4 MB P03: EFS (00006000, 0000A000) 20 MB P04: PARAM (00010000, 00004000) 8 MB P05: BOOT (00014000, 00004000) 8 MB P06: RECOVERY (00018000, 00004000) 8 MB P07: RADIO (0001C000, 00010000) 32 MB P08: CACHE (0002C000, 00190000) 800 MB P09: SYSTEM (001BC000, 002BC000) 1400 MB P10: HIDDEN (00478000, 000FA000) 500 MB P11: OTA (00572000, 00004000) 8 MB P12: USERDATA (00576000, 017E2000) 11.94 GB Save to C:/Program Files (x86)/Medusa Pro Software/Backups/Samsung n8000 file... Reading partition GPT... Done. Reading partition BOTA0... Done. Reading partition BOTA1... Done. Reading partition EFS... Done. Reading partition PARAM... Done. Reading partition BOOT... Done. Reading partition RECOVERY... Done. Reading partition RADIO... Done. Reading partition CACHE... Done. Reading partition SYSTEM... Done. Reading partition HIDDEN... Done. Reading partition OTA... Done. Reading partition USERDATA... Done. Reading is finished. SW: 1.5.6; FW: 1.23. Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-N8000_EMMC_MAG2GA.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Read/write verification error. Possible reasons: damaged or write protected eMMC. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : GT-N8000 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-N8000_EMMC_MAG2GA.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC MAG2GA Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 1501004D414732474107282279421133 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : MAG2GA Product revision : 0.7 Product serial number : (hex) 28227942 Manufacturing date : 01/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFFF8A406063 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : YES TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7659520 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Cancelling operation. Please wait...Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 1818624 Number of sectors : 2867200 Device Manufacturer :samsung Device Platform :exynos4 Build ID :KOT49H Display Build ID :KOT49H.N8000XXSDQA5 Release ID :4.4.2 Device Model :GT-N8000 Device Name :p4noterfxx Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Build Description :p4noterfxx-user 4.4.2 KOT49H N8000XXSDQA5 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/MAG2GA_12_04_2018_12_27_32.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.6; FW: 1.23. P00: GPT (00000000, 00002000) 4 MB P01: BOTA0 (00002000, 00002000) 4 MB P02: BOTA1 (00004000, 00002000) 4 MB P03: EFS (00006000, 0000A000) 20 MB P04: PARAM (00010000, 00004000) 8 MB P05: BOOT (00014000, 00004000) 8 MB P06: RECOVERY (00018000, 00004000) 8 MB P07: RADIO (0001C000, 00010000) 32 MB P08: CACHE (0002C000, 00190000) 800 MB P09: SYSTEM (001BC000, 002BC000) 1400 MB P10: HIDDEN (00478000, 000FA000) 500 MB P11: OTA (00572000, 00004000) 8 MB P12: USERDATA (00576000, 017E2000) 11.94 GB Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : GT-N8000 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-N8000_EMMC_MAG2GA.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC MAG2GA Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 1501004D414732474107282279421133 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : MAG2GA Product revision : 0.7 Product serial number : (hex) 28227942 Manufacturing date : 01/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFFF8A406063 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : YES TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7659520 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 1818624 Number of sectors : 2867200 Device Manufacturer :samsung Device Platform :exynos4 Build ID :KOT49H Display Build ID :KOT49H.N8000XXSDQA5 Release ID :4.4.2 Device Model :GT-N8000 Device Name :p4noterfxx Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Build Description :p4noterfxx-user 4.4.2 KOT49H N8000XXSDQA5 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/MAG2GA_12_04_2018_12_27_51.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.6; FW: 1.23. P00: GPT (00000000, 00002000) 4 MB P01: BOTA0 (00002000, 00002000) 4 MB P02: BOTA1 (00004000, 00002000) 4 MB P03: EFS (00006000, 0000A000) 20 MB P04: PARAM (00010000, 00004000) 8 MB P05: BOOT (00014000, 00004000) 8 MB P06: RECOVERY (00018000, 00004000) 8 MB P07: RADIO (0001C000, 00010000) 32 MB P08: CACHE (0002C000, 00190000) 800 MB P09: SYSTEM (001BC000, 002BC000) 1400 MB P10: HIDDEN (00478000, 000FA000) 500 MB P11: OTA (00572000, 00004000) 8 MB P12: USERDATA (00576000, 017E2000) 11.94 GB Remove write protect successfully completed. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : GT-N8000 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-N8000_EMMC_MAG2GA.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC MAG2GA Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 1501004D414732474107282279421133 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : MAG2GA Product revision : 0.7 Product serial number : (hex) 28227942 Manufacturing date : 01/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFFF8A404007 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7659520 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 1818624 Number of sectors : 2867200 Device Manufacturer :samsung Device Platform :exynos4 Build ID :KOT49H Display Build ID :KOT49H.N8000XXSDQA5 Release ID :4.4.2 Device Model :GT-N8000 Device Name :p4noterfxx Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Build Description :p4noterfxx-user 4.4.2 KOT49H N8000XXSDQA5 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/MAG2GA_12_04_2018_12_28_28.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.6; FW: 1.23. P00: GPT (00000000, 00002000) 4 MB P01: BOTA0 (00002000, 00002000) 4 MB P02: BOTA1 (00004000, 00002000) 4 MB P03: EFS (00006000, 0000A000) 20 MB P04: PARAM (00010000, 00004000) 8 MB P05: BOOT (00014000, 00004000) 8 MB P06: RECOVERY (00018000, 00004000) 8 MB P07: RADIO (0001C000, 00010000) 32 MB P08: CACHE (0002C000, 00190000) 800 MB P09: SYSTEM (001BC000, 002BC000) 1400 MB P10: HIDDEN (00478000, 000FA000) 500 MB P11: OTA (00572000, 00004000) 8 MB P12: USERDATA (00576000, 017E2000) 11.94 GB Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-N8000_EMMC_MAG2GA.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to boot area partition 2. Writing BOOT2 partition... Done. Switched to user area. Writing GPT partition... Done. Writing BOTA0 partition... Done. Writing BOTA1 partition... Done. Writing PARAM partition... Done. Writing BOOT partition... Done. Writing RECOVERY partition... Done. Writing RADIO partition... Done. Smart Repair is successfully complete. SW: 1.5.6; FW: 1.23. Disconnected. Last edited by Medusa Box; 04-12-2018 at 12:11. |
The Following 3 Users Say Thank You to galijus For This Useful Post: |
