07-21-2018, 15:09 | #1 (permalink) |
Insane Poster Join Date: Dec 2017 Location: India, Kerala, Kottayam
Member: 2784835 Status: Offline Thanks Meter: 61 | Samsung GT-S7562 Dead Boot Repair Sucessfully Done With Smart Repair Model Settings: Interface : eMMC Brand : Samsung Model : GT-S7562 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-S7562_EMMC_JJS00A_BY_PIJUSH_DAS.srf Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC J5U00B Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 1501004A355530304208DAEE0A24B079 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : J5U00B Product revision : 0.8 Product serial number : (hex) DAEE0A24 Manufacturing date : 11/2013 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFE18E404029 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1271808 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/J5U00B_21_07_2018_19_21_51.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.4; FW: 1.24. P00: FSBL (00000001, 00000028) 20 KB P01: QCSBL (00000029, 0000012C) 150 KB P02: FAT32 (00000155, 0000A000) 20 MB P03: OSBL (0000C000, 000007D0) 1000 KB P04: APPSBL (0000C7D0, 000007D0) 1000 KB P05: PART_28 (0000CFA0, 00000FA0) 2000 KB P06: PART_29 (0000DF40, 00006000) 12 MB P07: PART_2A (00013F40, 00001800) 3072 KB P08: PART_2B (00015740, 00001800) 3072 KB P09: PART_2C (00016F40, 00004000) 8 MB P10: PART_2D (0001AF40, 00006000) 12 MB P11: PART_2E (00020F40, 00002000) 4 MB P12: PART_2F (00022F40, 00002000) 4 MB P13: PART_30 (00024F40, 00000400) 512 KB P14: PART_31 (00025340, 00258000) 1200 MB P15: PART_32 (0027D340, 000FA000) 500 MB P16: PART_33 (00377340, 00001000) 2048 KB P17: SPLASH (00378340, 00006000) 12 MB P18: PART_35 (0037E340, 0000C000) 24 MB P19: PART_36 (0038A340, 00002000) 4 MB P20: PART_37 (0038C340, 00019000) 50 MB P21: PART_38 (003A5340, 000007D0) 1000 KB P22: PART_39 (003A5B10, 00002000) 4 MB Erasing. Please wait... Done. SW: 1.6.4; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : GT-S7562 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-S7562_EMMC_JJS00A_BY_PIJUSH_DAS.srf Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC J5U00B Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 1501004A355530304208DAEE0A24B079 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : J5U00B Product revision : 0.8 Product serial number : (hex) DAEE0A24 Manufacturing date : 11/2013 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFE18E404029 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1271808 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/J5U00B_21_07_2018_19_22_59.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.4; FW: 1.24. Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-S7562_EMMC_JJS00A_BY_PIJUSH_DAS.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to boot area partition 2. Writing BOOT2 partition... Done. Switched to user area. Writing FSBL partition... Done. Writing QCSBL partition... Done. Writing FAT32 partition... Done. Writing OSBL partition... Done. Writing APPSBL partition... Done. Writing PART_28 partition... Done. Writing PART_29 partition... Done. Writing PART_2A partition... Done. Writing PART_2B partition... Done. Writing PART_2C partition... Done. Writing PART_2D partition... Done. Writing PART_2E partition... Done. Writing PART_2F partition... Done. Writing PART_30 partition... Done. Writing PART_33 partition... Done. Writing SPLASH partition... Done. Writing PART_35 partition... Done. Writing PART_36 partition... Done. Writing PART_38 partition... Done. Writing PART_39 partition... Done. Writing mbrCustom partition... Done. Writing mbrCustom partition... Done. Writing mbrCustom partition... Done. Writing mbrCustom partition... Done. Writing mbrCustom partition... Done. Writing mbrCustom partition... Done. Writing mbrCustom partition... Done. Writing mbrCustom partition... Done. Writing mbrCustom partition... Done. Writing mbrCustom partition... Done. Writing mbrCustom partition... Done. Writing mbrCustom partition... Done. Writing mbrCustom partition... Done. Writing mbrCustom partition... Done. Writing mbrCustom partition... Done. Writing mbrCustom partition... Done. Writing mbrCustom partition... Done. Writing mbrCustom partition... Done. Writing mbrCustom partition... Done. Writing mbrCustom partition... Done. Writing mbrCustom partition... Done. Writing mbrCustom partition... Done. Writing mbrCustom partition... Done. Smart Repair is successfully complete. SW: 1.6.4; FW: 1.24. Disconnected. Last edited by Medusa Box; 07-22-2018 at 09:48. |
The Following User Says Thank You to Paappan Mobiles For This Useful Post: |
