04-13-2013, 11:03 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: turkey
Member: 706822 Status: Offline Thanks Meter: 647 | s8600 problem repair boot... [Solved] Selected device model: Samsung GT-S8600 Connecting. Please wait... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. Detected TAP ID: 27B360E1, IR Length = 5. ERROR[000]: Unable to halt core. Welcome to Medusa Box Software version 1.7.6 Selected device model: Samsung GT-S8600 Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. Detected TAP ID: 27B360E1, IR Length = 5. Unsupported CPU detected (ID: 00000000). ERROR[000]: Unable to halt core. ERROR[035]: Target device has been powered off during connect. Last edited by Octopus box; 04-16-2013 at 11:04. |
04-13-2013, 11:12 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. What power supply do You use exactly for powering the device? Please note, You need to use both fully charged phone's battery and USB cable at the same time. |
04-13-2013, 12:15 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please check soldering of all Jtag wires, make them as more shorter. Also try to connect with different Jtag speed. |
04-13-2013, 12:41 | #7 (permalink) |
Member: 706822 Status: Offline Thanks Meter: 647 | Selected device model: Samsung GT-S8600 Connecting. Please wait... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. Detected TAP ID: 27B360E1, IR Length = 5. ERROR[000]: Unable to halt core. |
04-13-2013, 12:52 | #9 (permalink) |
Member: 706822 Status: Offline Thanks Meter: 647 | Please connect the target device and power it on... VREF = 0.21V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. Detected TAP ID: 27B360E1, IR Length = 5. ERROR[000]: Unable to halt core. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. Detected TAP ID: 27B360E1, IR Length = 5. JTAG speed : Auto (RTCK). VREF level : 1.60 V CPU : Qualcomm MSM8255T Core ID : 2057A0E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. |
04-15-2013, 17:02 | #12 (permalink) |
Member: 706822 Status: Offline Thanks Meter: 647 | auto selct connect ok. s8600 select connect error m.r octopus Selected device model: Auto Connecting. Please wait... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. Detected TAP ID: 27B360E1, IR Length = 5. JTAG speed : Auto (RTCK). VREF level : 1.81 V CPU : Qualcomm MSM8255T Core ID : 2057A0E1 Storage Device: ******* eMMC SEM04G Device ID : 00450001 Block size : 512 bytes Blocks : 7733248 Storage size : 3776 Mb Connect successful. Disconnected Selected device model: Samsung GT-S8600 Connecting. Please wait... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. Detected TAP ID: 27B360E1, IR Length = 5. JTAG speed : Auto (RTCK). VREF level : 1.81 V CPU : Qualcomm MSM8255T Core ID : 2057A0E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. |
04-15-2013, 17:26 | #14 (permalink) |
Member: 706822 Status: Offline Thanks Meter: 647 | SAMSUNG S8600 OK. FULL FLASH OK. REPAİR BOOT OK. Detect Phone Connect ... Connect Phone OK. Read Phone Info ... Read Phone Info OK. Please Wait Burn Flash ... Updata Fota ... Updata Amss Code ... Updata Apps ... Updata RSRC1 ... Updata RSRC2 ... Formatting FFS ... Updata FFS ... Upgrade ShpApp ... Upgrade Csc ... Update Flash OK! Total Time: 816.0 s |
The Following User Says Thank You to mathew_di For This Useful Post: |
