02-03-2020, 11:22 | #1 (permalink) |
Freak Poster Join Date: Jun 2014 Location: punjab pakistan
Member: 2205429 Status: Offline Thanks Meter: 12 | Samsung J100H Dead boot repair error [Answered] Interface : eMMC Brand : Samsung Model : SM-J100H SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J100H_EMMC_H4G2B.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A483447326211013011B23E32C7 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) 3011B23E Manufacturing date : 03/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H4G2b_03_02_2020_15_10_39.bin. Connect successful. [3:14 PM, 2/3/2020] Mohsin Raza: Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J100H_EMMC_H4G2B.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to user area. Writing GPT partition... Done. Writing SBOOT partition... Done. Writing SBOOT2 partition... Done. Writing wfixnv1 partition... Done. Writing wfixnv2 partition... Done. Writing tdfixnv1 partition... Done. Writing tdfixnv2 partition... Done. Writing WDSP partition... Done. Writing MODEM partition... Done. Writing MODEM2 partition... Done. Writing TDDSP partition... Done. Writing wruntimenv1 partition... ERROR[012]: Write error. At sector 75776 Attempting to write... Done. Writing wruntimenv2 partition... Done. Writing tdruntimenv1 partition... Done. Writing tdruntimenv2 partition... Done. Writing PARAM partition... Done. Writing efs partition... Done. Smart Repair is successfully complete. SW: 2.0.2; FW: 1.24. [3:14 PM, 2/3/2020] Mohsin Raza: Selected pit file: D:/Software/Mobile Data/Samsung Soft File/SM-J100H/J100HXXU0AOB4_OXE0AOB4_v4.4.4_Repair_Firmware/J13G.pit Open file "D:/Software/Mobile Data/Samsung Soft File/SM-J100H/J100HXXU0AOB4_OXE0AOB4_v4.4.4_Repair_Firmware/BL_J100HXXU0AOB4_CL375756_QB4030225_REV01_user_low _ship.tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT... ERROR[012]: Write error. At sector 7634911. Disconnected. Sir When pit file and bl show this error plz hepl.... |
02-03-2020, 12:39 | #2 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,105 | This model phone have very Bad emmc chip You Can repaire it to boot but temporary solution but I advise you to replace emmc with New compatible chip |
The Following User Says Thank You to rebainoor For This Useful Post: |
