02-24-2019, 12:51 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: mumbai wadala
Member: 1037372 Status: Offline Thanks Meter: 557 | Samsung j510f dead boot repair change emmc Q313MB to R311MB Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC R311MB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 150100523331314D42006CA3D6B7C1AD Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : R311MB Product revision : 0.0 Product serial number : (hex) 6CA3D6B7 Manufacturing date : 12/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/R311MB_23_02_2019_19_43_13.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.5; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... Device : Samsung eMMC R311MB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 150100523331314D42006CA3D6B7C1AD Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : R311MB Product revision : 0.0 Product serial number : (hex) 6CA3D6B7 Manufacturing date : 12/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/R311MB_23_02_2019_19_43_21.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.5; FW: 1.24. Selected pit file: C:/Users/AFIFA/Downloads/Compressed/J5XNLTE_EUR_OPEN.pit Open file "C:/Users/AFIFA/Desktop/SM-J510F_1_20180528181601_e2oh79bl4k/J510FXXU2BRE2_J510FOJV2BRD1_J510FXXU2BRE1_HOME.tar .md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Writing partition APNHLOS... Done. Writing partition MODEM... Done. Writing partition SBL1... Done. Writing partition ABOOT... Done. Writing partition RPM... Done. Writing partition QSEE... Done. Writing partition QHEE... Done. Writing partition BOOT... Done. Writing partition RECOVERY... Done. Writing is finished. SW: 1.7.5; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... Device : Samsung eMMC R311MB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 150100523331314D42006CA3D6B7C1AD Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : R311MB Product revision : 0.0 Product serial number : (hex) 6CA3D6B7 Manufacturing date : 12/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/R311MB_23_02_2019_19_45_36.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.5; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: apnhlos (00002000, 00007800) 15 MB P02: modem (00009800, 0001C980) 57.19 MB P03: sbl1 (00026180, 00000400) 512 KB P04: ddr (00026580, 00000040) 32 KB P05: aboot (000265C0, 00001000) 2048 KB P06: rpm (000275C0, 00000400) 512 KB P07: qsee (000279C0, 00000600) 768 KB P08: qhee (00027FC0, 00000400) 512 KB P09: fsg (000283C0, 00001800) 3072 KB P10: sec (00029BC0, 00000020) 16 KB P11: pad (00029BE0, 00005420) 10.52 MB P12: param (0002F000, 00005000) 10 MB P13: efs (00034000, 00007000) 14 MB P14: modemst1 (0003B000, 00001800) 3072 KB P15: modemst2 (0003C800, 00001800) 3072 KB P16: boot (0003E000, 00006800) 13 MB P17: recovery (00044800, 00007800) 15 MB P18: fota (0004C000, 00005FFA) 12 MB P19: backup (00051FFA, 000037EE) 6.991 MB P20: fsc (000557E8, 00001800) 3072 KB P21: ssd (00056FE8, 00000010) 8 KB P22: persist (00056FF8, 00004000) 8 MB P23: persistent (0005AFF8, 00000800) 1024 KB P24: persdata (0005B7F8, 00004808) 9.004 MB P25: system (00060000, 005DC000) 3000 MB P26: cache (0063C000, 00064000) 200 MB P27: hidden (006A0000, 0001E000) 60 MB P28: userdata (006BE000, 0169A000) 11.3 GB |
The Following User Says Thank You to royalnasim For This Useful Post: |
