03-04-2020, 16:26 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: FOCSANI Age: 39
Member: 718470 Status: Offline Thanks Meter: 79 | Samsung J7 Prime G6100 repair boot ? [Answered] i have isp pinout i see another box suport g6100 medusa not suported ?? |
03-04-2020, 17:49 | #2 (permalink) |
No Life Poster Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Offline Thanks Meter: 1,450 | If U Have ISP Pinout Yes Possible To Repair Via Medusa Pro Or Medusa Pro 2 ..Use Factory File Method To Repair This Device..Or Better If U Connect N Share Log Will Tell U What To Do Next |
The Following User Says Thank You to hitech care For This Useful Post: |
03-05-2020, 17:55 | #3 (permalink) |
Member: 718470 Status: Offline Thanks Meter: 79 | Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC RX1BMB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100525831424D4210AA44D044837D Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : RX1BMB Product revision : 1.0 Product serial number : (hex) AA44D044 Manufacturing date : 08/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 688128 Number of sectors : 7372800 Device Manufacturer : samsung Device Platform : msm8953 Build ID : MMB29M Display Build ID : MMB29M.G610FXXU1API4 Release ID : 6.0.1 Device Model : SM-G610F Device Name : on7xltezh Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : on7xltezh-user 6.0.1 MMB29M G610FXXU1API4 release-keys Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/RX1BMB_05_03_2020_18_47_40.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.6; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: sbl1 (00002000, 00000400) 512 KB P02: sbl1bak (00002400, 00000400) 512 KB P03: ddr (00002800, 00000400) 512 KB P04: rpm (00002C00, 00000400) 512 KB P05: tz (00003000, 00001000) 2048 KB P06: aboot (00004000, 00001000) 2048 KB P07: sec (00005000, 00000200) 256 KB P08: lksecapp (00005200, 00000400) 512 KB P09: keymaster (00005600, 00000200) 256 KB P10: cmnlib (00005800, 00000200) 256 KB P11: cmnlib64 (00005A00, 00000200) 256 KB P12: fsg (00005C00, 00002000) 4 MB P13: pad (00007C00, 00000400) 512 KB P14: modemst1 (00008000, 00002000) 4 MB P15: modemst2 (0000A000, 00002000) 4 MB P16: efs (0000E000, 00008000) 16 MB P17: fsc (00016000, 00001A00) 3328 KB P18: ssd (00017A00, 00000200) 256 KB P19: devcfg (00017C00, 00000200) 256 KB P20: apdp (00017E00, 00000100) 128 KB P21: msadp (00017F00, 00000100) 128 KB P22: param (00018000, 00006000) 12 MB P23: backup (0001E000, 00002000) 4 MB P24: boot (00020000, 00010000) 32 MB P25: recovery (00030000, 00010000) 32 MB P26: bota (00040000, 00004000) 8 MB P27: fota (00044000, 00002000) 4 MB P28: persist (00046000, 00010000) 32 MB P29: persistent (00056000, 00000800) 1024 KB P30: steady (00056800, 00000800) 1024 KB P31: keystore (00057000, 00000800) 1024 KB P32: config (00057800, 00000800) 1024 KB P33: dsp (00058000, 00008000) 16 MB P34: modem (00060000, 00030000) 96 MB P35: apnhlos (00090000, 00010000) 32 MB P36: persdata (000A0000, 00006000) 12 MB P37: reserved2 (000A6000, 00002000) 4 MB P38: system (000A8000, 00708000) 3600 MB P39: cache (007B0000, 00064000) 200 MB P40: userdata (00814000, 03229FD8) 25.08 GB Backuping fsg partition... Opening C:/Program Files/Octoplus Pro JTAG Software/Backups/RX1BMB_fsg_0x5c00_0x2000_05_03_2020_18_47_40.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.0.6; FW: 1.24. Backuping modemst1 partition... Opening C:/Program Files/Octoplus Pro JTAG Software/Backups/RX1BMB_modemst1_0x8000_0x2000_05_03_2020_18_47_40. bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.0.6; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files/Octoplus Pro JTAG Software/Backups/RX1BMB_modemst2_0xa000_0x2000_05_03_2020_18_47_40. bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.0.6; FW: 1.24. Backuping efs partition... Opening C:/Program Files/Octoplus Pro JTAG Software/Backups/RX1BMB_efs_0xe000_0x8000_05_03_2020_18_47_40.bin file... Reading. Please wait... Done. Elapsed time 00:00:06 SW: 2.0.6; FW: 1.24. Selected pit file: C:/Users/gsmiulian/Desktop/G6100_CHN.pit Selected pit file: C:/Users/gsmiulian/Desktop/G6100_CHN.pit how to repair or write pit i select pit file but no have write ? |
03-05-2020, 18:53 | #4 (permalink) |
Member: 718470 Status: Offline Thanks Meter: 79 | Selected pit file: C:/Users/gsmiulian/Desktop/New folder/G6100_CHN.pit Selected firmware file: C:/Users/gsmiulian/Desktop/New folder/AP_G6100ZHU1AQJ2_CL12479065_QB15466375_REV00_user_ low_ship_MULTI_CERT.tar.md5 Open file "C:/Users/gsmiulian/Desktop/New folder/AP_G6100ZHU1AQJ2_CL12479065_QB15466375_REV00_user_ low_ship_MULTI_CERT.tar.md5". Selected firmware file: C:/Users/gsmiulian/Desktop/New folder/CP_G6100ZHU1AQJ2_CL12479065_QB15466375_REV00_user_ low_ship_MULTI_CERT.tar.md5 Open file "C:/Users/gsmiulian/Desktop/New folder/CP_G6100ZHU1AQJ2_CL12479065_QB15466375_REV00_user_ low_ship_MULTI_CERT.tar.md5". Selected firmware file: C:/Users/gsmiulian/Desktop/New folder/BL_G6100ZHU1AQJ2_CL12479065_QB15466375_REV00_user_ low_ship_MULTI_CERT.tar.md5 Open file "C:/Users/gsmiulian/Desktop/New folder/BL_G6100ZHU1AQJ2_CL12479065_QB15466375_REV00_user_ low_ship_MULTI_CERT.tar.md5". Selected firmware file: C:/Users/gsmiulian/Desktop/New folder/AP_G6100ZHU1AQJ2_CL12479065_QB15466375_REV00_user_ low_ship_MULTI_CERT.tar.md5 Open file "C:/Users/gsmiulian/Desktop/New folder/AP_G6100ZHU1AQJ2_CL12479065_QB15466375_REV00_user_ low_ship_MULTI_CERT.tar.md5". Selected firmware file: C:/Users/gsmiulian/Desktop/New folder/CP_G6100ZHU1AQJ2_CL12479065_QB15466375_REV00_user_ low_ship_MULTI_CERT.tar.md5 Open file "C:/Users/gsmiulian/Desktop/New folder/CP_G6100ZHU1AQJ2_CL12479065_QB15466375_REV00_user_ low_ship_MULTI_CERT.tar.md5". Selected firmware file: C:/Users/gsmiulian/Desktop/New folder/CSC_ZZH_G6100ZZH1AQJ2_CL12479065_QB15466375_REV00_ user_low_ship_MULTI_CERT.tar.md5 Open file "C:/Users/gsmiulian/Desktop/New folder/CSC_ZZH_G6100ZZH1AQJ2_CL12479065_QB15466375_REV00_ user_low_ship_MULTI_CERT.tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Writing partition SBL1... from 2000 to 313 Done. Writing partition RPM... from 2C00 to 194 Done. Writing partition TZ... from 3000 to BE7 Done. Writing partition ABOOT... from 4000 to ED3 Done. Writing partition SEC... from 5000 to 2 Done. Writing partition LKSECAPP... from 5200 to 209 Done. Writing partition KEYMASTER... from 5600 to 1FA Done. Writing partition CMNLIB... from 5800 to 1CA Done. Writing partition DEVCFG... from 17C00 to 8B Done. Writing partition APDP... from 17E00 to 5B Done. Writing partition MSADP... from 17F00 to 5B Done. Writing partition BOOT... from 20000 to 6CC9 Done. Writing partition RECOVERY... from 30000 to 7935 Done. Writing partition PERSIST... from 46000 to 2441 Done. Writing partition DSP... from 58000 to 8000 Done. Writing partition MODEM... from 60000 to 2A001 Done. Writing partition APNHLOS... from 90000 to D24C Done. Writing partition SYSTEM... from A8000 to 64290C Done. Writing partition CACHE... from 7B0000 to 234C9 Done. Writing is finished. SW: 2.0.6; FW: 1.24. after write phone not power in device manager HS-USB QDLoader 9008 |
03-06-2020, 13:28 | #5 (permalink) | |
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Quote:
03-06-2020, 13:40 | #6 (permalink) |
Member: 718470 Status: Offline Thanks Meter: 79 | Post Selected pit file: C:/Users/gsmiulian/Desktop/New folder/G6100_CHN.pit Selected firmware file: C:/Users/gsmiulian/Desktop/New folder/AP_G6100ZHU1AQJ2_CL12479065_QB15466375_REV00_user_ low_ship_MULTI_CERT.tar.md5 Open file "C:/Users/gsmiulian/Desktop/New folder/AP_G6100ZHU1AQJ2_CL12479065_QB15466375_REV00_user_ low_ship_MULTI_CERT.tar.md5". Selected firmware file: C:/Users/gsmiulian/Desktop/New folder/CP_G6100ZHU1AQJ2_CL12479065_QB15466375_REV00_user_ low_ship_MULTI_CERT.tar.md5 Open file "C:/Users/gsmiulian/Desktop/New folder/CP_G6100ZHU1AQJ2_CL12479065_QB15466375_REV00_user_ low_ship_MULTI_CERT.tar.md5". Selected firmware file: C:/Users/gsmiulian/Desktop/New folder/BL_G6100ZHU1AQJ2_CL12479065_QB15466375_REV00_user_ low_ship_MULTI_CERT.tar.md5 Open file "C:/Users/gsmiulian/Desktop/New folder/BL_G6100ZHU1AQJ2_CL12479065_QB15466375_REV00_user_ low_ship_MULTI_CERT.tar.md5". Selected firmware file: C:/Users/gsmiulian/Desktop/New folder/AP_G6100ZHU1AQJ2_CL12479065_QB15466375_REV00_user_ low_ship_MULTI_CERT.tar.md5 Open file "C:/Users/gsmiulian/Desktop/New folder/AP_G6100ZHU1AQJ2_CL12479065_QB15466375_REV00_user_ low_ship_MULTI_CERT.tar.md5". Selected firmware file: C:/Users/gsmiulian/Desktop/New folder/CP_G6100ZHU1AQJ2_CL12479065_QB15466375_REV00_user_ low_ship_MULTI_CERT.tar.md5 Open file "C:/Users/gsmiulian/Desktop/New folder/CP_G6100ZHU1AQJ2_CL12479065_QB15466375_REV00_user_ low_ship_MULTI_CERT.tar.md5". Selected firmware file: C:/Users/gsmiulian/Desktop/New folder/CSC_ZZH_G6100ZZH1AQJ2_CL12479065_QB15466375_REV00_ user_low_ship_MULTI_CERT.tar.md5 Open file "C:/Users/gsmiulian/Desktop/New folder/CSC_ZZH_G6100ZZH1AQJ2_CL12479065_QB15466375_REV00_ user_low_ship_MULTI_CERT.tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Writing partition SBL1... from 2000 to 313 Done. Writing partition RPM... from 2C00 to 194 Done. Writing partition TZ... from 3000 to BE7 Done. Writing partition ABOOT... from 4000 to ED3 Done. Writing partition SEC... from 5000 to 2 Done. Writing partition LKSECAPP... from 5200 to 209 Done. Writing partition KEYMASTER... from 5600 to 1FA Done. Writing partition CMNLIB... from 5800 to 1CA Done. Writing partition DEVCFG... from 17C00 to 8B Done. Writing partition APDP... from 17E00 to 5B Done. Writing partition MSADP... from 17F00 to 5B Done. Writing partition BOOT... from 20000 to 6CC9 Done. Writing partition RECOVERY... from 30000 to 7935 Done. Writing partition PERSIST... from 46000 to 2441 Done. Writing partition DSP... from 58000 to 8000 Done. Writing partition MODEM... from 60000 to 2A001 Done. Writing partition APNHLOS... from 90000 to D24C Done. Writing partition SYSTEM... from A8000 to 64290C Done. Writing partition CACHE... from 7B0000 to 234C9 Done. Writing is finished. SW: 2.0.6; FW: 1.24. Sm-g6100 īs firmware But no power on |
03-10-2020, 13:50 | #15 (permalink) |
Member: 718470 Status: Offline Thanks Meter: 79 | this is not full firmware bl ap cp csc and pit ??? Post Selected pit file: C:/Users/gsmiulian/Desktop/New folder/G6100_CHN.pit Selected firmware file: C:/Users/gsmiulian/Desktop/New folder/AP_G6100ZHU1AQJ2_CL12479065_QB15466375_REV00_user_ low_ship_MULTI_CERT.tar.md5 Open file "C:/Users/gsmiulian/Desktop/New folder/AP_G6100ZHU1AQJ2_CL12479065_QB15466375_REV00_user_ low_ship_MULTI_CERT.tar.md5". Selected firmware file: C:/Users/gsmiulian/Desktop/New folder/CP_G6100ZHU1AQJ2_CL12479065_QB15466375_REV00_user_ low_ship_MULTI_CERT.tar.md5 Open file "C:/Users/gsmiulian/Desktop/New folder/CP_G6100ZHU1AQJ2_CL12479065_QB15466375_REV00_user_ low_ship_MULTI_CERT.tar.md5". Selected firmware file: C:/Users/gsmiulian/Desktop/New folder/BL_G6100ZHU1AQJ2_CL12479065_QB15466375_REV00_user_ low_ship_MULTI_CERT.tar.md5 Open file "C:/Users/gsmiulian/Desktop/New folder/BL_G6100ZHU1AQJ2_CL12479065_QB15466375_REV00_user_ low_ship_MULTI_CERT.tar.md5". Selected firmware file: C:/Users/gsmiulian/Desktop/New folder/AP_G6100ZHU1AQJ2_CL12479065_QB15466375_REV00_user_ low_ship_MULTI_CERT.tar.md5 Open file "C:/Users/gsmiulian/Desktop/New folder/AP_G6100ZHU1AQJ2_CL12479065_QB15466375_REV00_user_ low_ship_MULTI_CERT.tar.md5". Selected firmware file: C:/Users/gsmiulian/Desktop/New folder/CP_G6100ZHU1AQJ2_CL12479065_QB15466375_REV00_user_ low_ship_MULTI_CERT.tar.md5 Open file "C:/Users/gsmiulian/Desktop/New folder/CP_G6100ZHU1AQJ2_CL12479065_QB15466375_REV00_user_ low_ship_MULTI_CERT.tar.md5". Selected firmware file: C:/Users/gsmiulian/Desktop/New folder/CSC_ZZH_G6100ZZH1AQJ2_CL12479065_QB15466375_REV00_ user_low_ship_MULTI_CERT.tar.md5 Open file "C:/Users/gsmiulian/Desktop/New folder/CSC_ZZH_G6100ZZH1AQJ2_CL12479065_QB15466375_REV00_ user_low_ship_MULTI_CERT.tar.md5". this is not full firmware bl ap cp csc and pit ??? i use SM-G6100 4Files (Repair Firmware) |
