10-29-2018, 08:15 | #1 (permalink) |
Freak Poster Join Date: Apr 2013 Location: Pakistan Age: 24
Member: 1919988 Status: Offline Thanks Meter: 178 | Samsung SM-C7000 boot repair question [Answered] iam unable to find model in this list here is pic Last edited by Medusa Box; 10-29-2018 at 09:02. |
The Following User Says Thank You to sindhi.aslam For This Useful Post: |
10-29-2018, 09:05 | #4 (permalink) | |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | @ sindhi.aslam Hello. We don't eMMC pinout for this phone at the moment. Maybe someone have and upload it here for You. If You know eMMC (ISP) pinout for this device, You can try to solder all necessary eMMC wires and connect the device. If connection will be successful, do "Factory Repair" using proper PIT file and the latest original Samsung firmware for this phone. Also, if You have an experience in soldering, You can remove eMMC chip from PCB for repairing (programming), solder necessary wires directly to eMMC chip contacts (or use proper eMMC adapter for direct connection), do "Factory Repair" using the latest original Samsung firmware and then solder eMMC chip back to device's PCB. Also look here: http://forum.gsmhosting.com/vbb/f664...wered-2441292/. @ .: D :. Quote:
12-20-2018, 05:40 | #10 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | If You have connected the device correctly, You can try to repair the device via "Factory Repair" procedure ("Factory Repair" tab in Software) using proper PIT file and the latest full original firmware (in "*.tar"/"*.md5" format) for this device model. |
