05-09-2018, 18:55 | #1 (permalink) |
Freak Poster Join Date: Apr 2005 Location: morocco Age: 36
Member: 140858 Status: Offline Sonork: hoba0073gyyh Thanks Meter: 21 | Samsung SM-G531F repair done Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-G531F SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G531F_EMMC_P1J95K.srf Voltage : 2.2V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-G531F SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G531F_EMMC_P1J95K.srf Voltage : 2.2V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H8G4t! Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A4838473474210117012C1213E1 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4t! Product revision : 0.1 Product serial number : (hex) 17012C12 Manufacturing date : 01/2016 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A400013 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 284672 Number of sectors : 3774464 Device Manufacturer :samsung Device Platform :mrvl Build ID :LMY48B Display Build ID :LMY48B.G531FXXU1APA1 Release ID :5.1.1 Device Model :SM-G531F Device Name :grandprimeveltexx Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :grandprimeveltexx-user 5.1.1 LMY48B G531FXXU1APA1 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G4t!_09_05_2018_17_46_53.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.8; FW: 1.23. P00: GPT (00000000, 00002000) 4 MB P01: LOKE2ND (00002000, 00001000) 2048 KB P02: LOKE1ST (00003000, 00001000) 2048 KB P03: MRD (00004000, 00000800) 1024 KB P04: MRD1 (00004800, 00000800) 1024 KB P05: MEP2 (00005000, 00001000) 2048 KB P06: EFS (00006000, 00007000) 14 MB P07: PARAM (0000D000, 00001000) 2048 KB P08: RECOVERY (0000E000, 00008000) 16 MB P09: KERNEL (00016000, 00008000) 16 MB P10: MODEM (0001E000, 0000E000) 28 MB P11: SSTD (0002C000, 00008000) 16 MB P12: OTA (00034000, 00000800) 1024 KB P13: NVM (00034800, 0000C000) 24 MB P14: PERSDATA (00040800, 00004800) 9 MB P15: PERSISTENT (00045000, 00000800) 1024 KB P16: SYSTEM (00045800, 00399800) 1843 MB P17: CACHE (003DF000, 00064000) 200 MB P18: HIDDEN (00443000, 00005000) 10 MB P19: USER (00448000, 00A47800) 5.14 GB Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G531F_EMMC_P1J95K.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to user area. Writing GPT partition... Done. Writing LOKE2ND partition... Done. Writing LOKE1ST partition... Done. Writing MRD partition... Done. Writing MRD1 partition... Done. Writing MEP2 partition... Done. Writing EFS partition... Done. Writing PARAM partition... Done. Writing RECOVERY partition... Done. Writing KERNEL partition... Done. Writing MODEM partition... Done. Writing SSTD partition... Done. Writing OTA partition... Done. Writing NVM partition... Done. Writing PERSDATA partition... Done. Writing PERSISTENT partition... Done. Smart Repair is successfully complete. SW: 1.5.8; FW: 1.23. Disconnected. |
