Member: 135661
Thanks Meter: 92 | Samsung SM-G532F "dead" boot repair done Samsung SM-G532F "dead" boot repair done: Quote:
Model Settings:
Interface : eMMC
Brand : Samsung
Model : SM-G532F
SRF : C:/Program Files/Octoplus Pro JTAG Software/firmwareFolder/SAMSUNG_SM-G532F_EMMC_QN16BB.srf
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Hynix eMMC H8G4u
Page size : 512 B
Block size : 512 B
Block count : 15269888
Size : 7.28 GB (7456.00 MB)
CID Info
CID : 90014A483847347592011118F0B7B481
Manufacturer ID : 0X90
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X4A
Product name : H8G4u
Product revision : 0.1
Product serial number : (hex) 1118F0B7
Manufacturing date : 11/2017
CSD Info
CSD : D02701320F5903FFFFFFFFE78A40002B
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.7 (for MMC v5.0, v5.01)
Erase block size : 512 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 4096 Kbytes
Partition config : (0x48) 01001000
Boot partition enable : Boot partition 1
(Bus width = 1Bit)
Boot ACK : Boot acknowledge sent during boot operation Bit
Boot bus conditions : (0x00) 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x01) RST_n signal is permanently enabled
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 3817472 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...
Ok
Disk/Image size : d2000000 bytes
Device sector size : 512 bytes
Partition offset : 393216
Number of sectors : 6307840
Device Manufacturer :samsung
Device Platform :mt6737t
Build ID :MMB29T
Display Build ID :MMB29T.G532FXWU1APJ3
Release ID :6.0.1
Device Model :SM-G532F
Device Name :grandpplteser
Architecture ABI :armeabi-v7a
Architecture ABI2 :armeabi
Architecture ABI List :armeabi-v7a,armeabi
Build Description :grandpplteser-user 6.0.1 MMB29T G532FXWU1APJ3 release-keys
Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/H8G4u_01_09_2018_16_42_24.bin.
Connect successful.
SW: 1.6.3; FW: 1.24.
P00: GPT (00000000, 00002000) 4 MB
P01: BOTA0 (00002000, 00002000) 4 MB
P02: nvram (00004000, 00004000) 8 MB
P03: lk (00008000, 00001000) 2048 KB
P04: BOTA1 (00009000, 00001000) 2048 KB
P05: secro (0000A000, 00003800) 7 MB
P06: seccfg (0000D800, 00000400) 512 KB
P07: efuse (0000DC00, 00000400) 512 KB
P08: tee1 (0000E000, 00003000) 6 MB
P09: BOTA2 (00011000, 00003000) 6 MB
P10: EFS (00014000, 00004000) 8 MB
P11: nvdata (00018000, 00010000) 32 MB
P12: PARAM (00028000, 00004000) 8 MB
P13: recovery (0002C000, 00008000) 16 MB
P14: boot (00034000, 00008000) 16 MB
P15: md1img (0003C000, 00010000) 32 MB
P16: md1dsp (0004C000, 00002000) 4 MB
P17: keystore (0004E000, 00004000) 8 MB
P18: omekeystore (00052000, 00001C00) 3584 KB
P19: proinfo (00053C00, 00001400) 2560 KB
P20: para (00055000, 00000400) 512 KB
P21: PERSISTENT (00055400, 00000400) 512 KB
P22: STEADY (00055800, 00000800) 1024 KB
P23: protect1 (00056000, 00004000) 8 MB
P24: protect2 (0005A000, 00004000) 8 MB
P25: RESERVE2 (0005E000, 00002000) 4 MB
P26: system (00060000, 00604000) 3080 MB
P27: cache (00664000, 000C8000) 400 MB
P28: hidden (0072C000, 0001E000) 60 MB
P29: userdata (0074A000, 00744000) 3720 MB
Selected pit file: L:/Samsung/SM-G/G532F/GRANDPPLTE_CIS_SER.pit
Open file "L:/G532FXWU1ARG4_G532FOJV1ARG3_XSG/BL_G532FXWU1ARG4_CL13981262_QB18927805_REV00_user_ low_ship_MULTI_CERT.tar.md5".
Writing MBR...Done.
Writing primary GPT...Done.
Writing secondary GPT...Done.
Writing PIT
Write data verification is enabled.
Writing. Please wait...
Switched to boot area partition 1.
Writing partition BOOTLOADER... Done.
Switched to user area.
Writing partition lk... Done.
Writing partition efuse... Done.
Writing partition tee1... Done.
Writing partition PARAM... Done.
Writing is finished.
