10-28-2018, 15:02 | #1 (permalink) |
No Life Poster Join Date: Dec 2016 Location: Pakistan Age: 27
Member: 2665080 Status: Offline Thanks Meter: 63 | Samsung SM-G532F "dead" boot repair done, but phone not on [Answered] Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-G532F SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G532F_EMMC_QN16BB.srf Voltage : 3.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H8G4u Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A483847347592011125401AB4E5 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4u Product revision : 0.1 Product serial number : (hex) 1125401A Manufacturing date : 11/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFE78A40002B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 393216 Number of sectors : 6307840 Device Manufacturer :samsung Device Platform :mt6737t Build ID :MMB29T Display Build ID :MMB29T.G532FXWU1APJ1 Release ID :6.0.1 Device Model :SM-G532F Device Name :grandpplteser Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :grandpplteser-user 6.0.1 MMB29T G532FXWU1APJ1 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G4u_28_10_2018_19_00_21.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.7; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: BOTA0 (00002000, 00002000) 4 MB P02: nvram (00004000, 00004000) 8 MB P03: lk (00008000, 00001000) 2048 KB P04: BOTA1 (00009000, 00001000) 2048 KB P05: secro (0000A000, 00003800) 7 MB P06: seccfg (0000D800, 00000400) 512 KB P07: efuse (0000DC00, 00000400) 512 KB P08: tee1 (0000E000, 00003000) 6 MB P09: BOTA2 (00011000, 00003000) 6 MB P10: EFS (00014000, 00004000) 8 MB P11: nvdata (00018000, 00010000) 32 MB P12: PARAM (00028000, 00004000) 8 MB P13: recovery (0002C000, 00008000) 16 MB P14: boot (00034000, 00008000) 16 MB P15: md1img (0003C000, 00010000) 32 MB P16: md1dsp (0004C000, 00002000) 4 MB P17: keystore (0004E000, 00004000) 8 MB P18: omekeystore (00052000, 00001C00) 3584 KB P19: proinfo (00053C00, 00001400) 2560 KB P20: para (00055000, 00000400) 512 KB P21: PERSISTENT (00055400, 00000400) 512 KB P22: STEADY (00055800, 00000800) 1024 KB P23: protect1 (00056000, 00004000) 8 MB P24: protect2 (0005A000, 00004000) 8 MB P25: RESERVE2 (0005E000, 00002000) 4 MB P26: system (00060000, 00604000) 3080 MB P27: cache (00664000, 000C8000) 400 MB P28: hidden (0072C000, 0001E000) 60 MB P29: userdata (0074A000, 00744000) 3720 MB Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G532F_EMMC_QN16BB.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to user area. Writing GPT partition... Done. Writing BOTA0 partition... Done. Writing lk partition... Done. Writing BOTA1 partition... Done. Writing secro partition... Done. Writing seccfg partition... Done. Writing efuse partition... Done. Writing tee1 partition... Done. Writing BOTA2 partition... Done. Writing EFS partition... Done. Writing PARAM partition... Done. Writing recovery partition... Done. Writing boot partition... Done. Writing md1img partition... Done. Writing md1dsp partition... Done. Writing keystore partition... Done. Writing omekeystore partition... Done. Writing proinfo partition... Done. Writing para partition... Done. Writing PERSISTENT partition... Done. Writing STEADY partition... Done. Smart Repair is successfully complete. SW: 1.6.7; FW: 1.24. Disconnected. Last edited by Octopus box; 10-28-2018 at 16:37. |
The Following User Says Thank You to imeilock For This Useful Post: |
10-28-2018, 16:37 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. If the device doesn't go into Download Mode (DM) after repairing, here can be two main reasons of this problem - device has HW problems or boot loaders in SRF file and firmware, which You have used for repairing, could be not suitable (not compatible) with your phone (boot loaders are older (has lower version) than should be in your phone, thus the phone can't go into DM because of enabled boot downgrade protection). Try to perform "Factory Repair" operation using another original Samsung firmwares (try latest available binary firmwares) for this phone model. Also, please look here: http://forum.gsmhosting.com/vbb/f664.../#post13155328, http://forum.gsmhosting.com/vbb/f664...l#post13032839, http://forum.gsmhosting.com/vbb/f664...l#post13035535, http://forum.gsmhosting.com/vbb/f664.../#post12952209. Try to do "Factory Repair" with firmwares for SM-G532G/M. Also try to desolder wires and put the device into DM using Samsung JIG cable. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
10-29-2018, 07:23 | #3 (permalink) |
Member: 2665080 Status: Offline Thanks Meter: 63 | Welcome to Medusa Pro Software version 1.6.7. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Alcor Micro USB Smart Card Reader 1 Reader #2: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-G532F SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G532F_EMMC_QN16BB.srf Voltage : 3.0V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-G532F SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G532F_EMMC_QN16BB.srf Voltage : 3.0V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-G532F SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G532F_EMMC_QN16BB.srf Voltage : 3.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H8G4u Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A483847347592011125401AB4E5 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4u Product revision : 0.1 Product serial number : (hex) 1125401A Manufacturing date : 11/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFE78A40002B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 393216 Number of sectors : 6307840 Device Manufacturer :samsung Device Platform :mt6737t Build ID :MMB29T Display Build ID :MMB29T.G532FXWU1APJ1 Release ID :6.0.1 Device Model :SM-G532F Device Name :grandpplteser Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :grandpplteser-user 6.0.1 MMB29T G532FXWU1APJ1 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G4u_29_10_2018_11_16_06.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.7; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: BOTA0 (00002000, 00002000) 4 MB P02: nvram (00004000, 00004000) 8 MB P03: lk (00008000, 00001000) 2048 KB P04: BOTA1 (00009000, 00001000) 2048 KB P05: secro (0000A000, 00003800) 7 MB P06: seccfg (0000D800, 00000400) 512 KB P07: efuse (0000DC00, 00000400) 512 KB P08: tee1 (0000E000, 00003000) 6 MB P09: BOTA2 (00011000, 00003000) 6 MB P10: EFS (00014000, 00004000) 8 MB P11: nvdata (00018000, 00010000) 32 MB P12: PARAM (00028000, 00004000) 8 MB P13: recovery (0002C000, 00008000) 16 MB P14: boot (00034000, 00008000) 16 MB P15: md1img (0003C000, 00010000) 32 MB P16: md1dsp (0004C000, 00002000) 4 MB P17: keystore (0004E000, 00004000) 8 MB P18: omekeystore (00052000, 00001C00) 3584 KB P19: proinfo (00053C00, 00001400) 2560 KB P20: para (00055000, 00000400) 512 KB P21: PERSISTENT (00055400, 00000400) 512 KB P22: STEADY (00055800, 00000800) 1024 KB P23: protect1 (00056000, 00004000) 8 MB P24: protect2 (0005A000, 00004000) 8 MB P25: RESERVE2 (0005E000, 00002000) 4 MB P26: system (00060000, 00604000) 3080 MB P27: cache (00664000, 000C8000) 400 MB P28: hidden (0072C000, 0001E000) 60 MB P29: userdata (0074A000, 00744000) 3720 MB Selected pit file: C:/Users/************/Desktop/New folder/G532F Dead Boot Repair File Ok/G532F Dead Boot Repair File Ok/GRANDPPLTE_CIS_SER.pit Selected pit file: C:/Users/************/Desktop/New folder/G532F Dead Boot Repair File Ok/G532F Dead Boot Repair File Ok/BL_G532FXXU1AQC2_CL10340273_QB12918482_REV00_user_ low_ship_MULTI_CERT.tar.md5 Unknown format of input file C:/Users/************/Desktop/New folder/G532F Dead Boot Repair File Ok/G532F Dead Boot Repair File Ok/BL_G532FXXU1AQC2_CL10340273_QB12918482_REV00_user_ low_ship_MULTI_CERT.tar.md5! |
10-29-2018, 07:30 | #4 (permalink) |
Member: 2665080 Status: Offline Thanks Meter: 63 | Selected pit file: C:/Users/************/Desktop/New folder/G532F Dead Boot Repair File Ok/G532F Dead Boot Repair File Ok/GRANDPPLTE_CIS_SER.pit Selected firmware file: C:/Users/************/Desktop/New folder/G532F Dead Boot Repair File Ok/G532F Dead Boot Repair File Ok/BL_G532FXXU1AQC2_CL10340273_QB12918482_REV00_user_ low_ship_MULTI_CERT.tar.md5 Open file "C:/Users/************/Desktop/New folder/G532F Dead Boot Repair File Ok/G532F Dead Boot Repair File Ok/BL_G532FXXU1AQC2_CL10340273_QB12918482_REV00_user_ low_ship_MULTI_CERT.tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Writing partition BOOTLOADER... Done. #greenWriting partition lk... Done. #greenWriting partition efuse... Done. #greenWriting partition tee1... Done. #greenWriting partition PARAM... Done. #greenWriting is finished. SW: 1.6.7; FW: 1.24. #blue |
