05-11-2018, 14:59 | #1 (permalink) |
Freak Poster Join Date: Jan 2010 Location: mystery city
Member: 1199392 Status: Offline Thanks Meter: 95 | Samsung SM-G600FY dead boot repair log request [Answered] i want to buy medusa pro full set Last edited by Medusa Box; 05-12-2018 at 07:03. |
05-12-2018, 07:03 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Hello. Repairing of this device is supported and proper SRF (Smart Repair File) is present on the Support Area. eMMC pinout is inside of SRF. Also You can download Live Log for this device with correct connection info from the Support Area: Code: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QN16MB Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB --------------------------------------------------------------- CID Info CID : 150100514E31364D42002050DC172307 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QN16MB Product revision : 0.0 Product serial number : (hex) 2050DC17 Manufacturing date : 02/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file D:/Projects/Octoplus_JTag/build/EXT_CSD Backups/QN16MB_20_10_2017_08_15_08.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.6; FW: 1.22. P00: GPT (00000000, 00002000) P01: apnhlos (00002000, 00007800) P02: modem (00009800, 0001CB80) P03: sbl1 (00026380, 00000400) P04: ddr (00026780, 00000040) P05: aboot (000267C0, 00001000) P06: rpm (000277C0, 00000400) P07: qsee (00027BC0, 00000600) P08: qhee (000281C0, 00000400) P09: fsg (000285C0, 00001800) P10: sec (00029DC0, 00000020) P11: pad (00029DE0, 00005220) P12: param (0002F000, 00005000) P13: efs (00034000, 00007000) P14: modemst1 (0003B000, 00001800) P15: modemst2 (0003C800, 00001800) P16: boot (0003E000, 00006800) P17: recovery (00044800, 00007800) P18: fota (0004C000, 00006002) P19: backup (00052002, 000037EE) P20: fsc (000557F0, 00001800) P21: ssd (00056FF0, 00000010) P22: persist (00057000, 00004000) P23: persistent (0005B000, 00000800) P24: persdata (0005B800, 00004800) P25: system (00060000, 00480000) P26: cache (004E0000, 00064000) P27: userdata (00544000, 0094BFD8) Last edited by Medusa Box; 05-12-2018 at 07:09. |
