11-10-2016, 11:20 | #1 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Left out from our gsm field Age: 29
Member: 2386560 Status: Offline Sonork: NOW I DON'T USE IT Thanks Meter: 561 | Samsung SM-G7102 sucessfully boot repair with medusa pro Code: Welcome to Medusa Pro Software version 1.2.2. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Please disconnect battery and USB cable. Selected device model: Samsung G7102. Selected file: C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_G7102_(TEST).srf. eMMC interface selected. Connecting... Device : Samsung eMMC 8WMB3R Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB --------------------------------------------------------------- CID Info CID : 15010038574D423352003C545B173151 Manufacturer ID : 0X15 Device/BGA : BGA(Discrete embeded) OEM/Application ID : 0X00 Product name : 8WMB3R Product revision : 0.0 Product serial number : (hex)3C545B17 Manufacturing date : 03/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Boot partition enable : Device not boot enabled (default) Partition config : 00000000 Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/8WMB3R_08_11_2016_18_17_58.bin. Connect successful. --------------------------------------------------------------- Switched to Boot1!!! Writting BOOT1 partition... Done. Switched to Boot2!!! Writting BOOT2 partition... Done. Switched to UA!!! Writting GPT partition... Done. Writting apnhlos partition... Done. Writting modem partition... Done. Writting sbl1 partition... Done. Writting dbi partition... Done. Writting ddr partition... Done. Writting aboot partition... Done. Writting rpm partition... Done. Writting tz partition... Done. Writting pad partition... Done. Writting param partition... Done. Writting efs partition... Done. Writting modemst1 partition... Done. Writting modemst2 partition... Done. Writting boot partition... Done. Writting recovery partition... Done. Writting fota partition... Done. Writting backup partition... Done. Writting fsg partition... Done. Writting fsc partition... Done. Writting ssd partition... Done. Writting persist partition... Done. Writting hidden partition... Done. Smart Repair is successfully complete. SW: 1.2.2; FW: 1.13. Disconnected Last edited by Medusa Box; 11-10-2016 at 12:09. |
The Following User Says Thank You to vickyjadhav6161 For This Useful Post: |
01-27-2017, 21:44 | #3 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. You can download SRF (Smart Repair File) from Medusa Pro Software via "Download *.srf" button (look at "USER UPLOADED SRF/SAMSUNG/SM-G7102" folder). To repair SM-G7102, do the following: 1. Install the latest version of Medusa Pro Software (Medusa Pro Box Downloads). 2. Download mentioned above SRF. 3. Select Samsung SM-G7102 in Software list (device model will appear in Software list after You download SRF). 4. Press "Pinout" button to look at pinout picture. 5. Solder all necessary wires accordingly to the pinout picture. 6. Connect the device to Box and press "Connect" button in Software. 7. When connection will be successful, press "Smart repair" button to repair the device. |
The Following 3 Users Say Thank You to Medusa Box For This Useful Post: |
06-07-2017, 12:41 | #4 (permalink) |
Freak Poster Join Date: Jun 2016 Location: Bangladesh Age: 34
Member: 2581716 Status: Offline Sonork: 30294069 Thanks Meter: 137 | Medusa Software Installer 2.6.1.5 not supported Sm-G7102 Hello - Medusa Software Installer 2.6.1.5 not supported Sm-G7102 Plz Help Me Bro.....:c onfused: |
06-07-2017, 14:37 | #5 (permalink) | |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Yes, repairing of Sm-G7102 is supported via eMMC, not via JTAG. To work with eMMC You need to have Medusa Pro Box. Old Medusa Box HW doesn't support work with eMMC. Also, to repair this device via eMMC You should use Medusa Pro Software, not old Medusa Software. Please carefully read instructions (steps) on how to repair this device: Quote:
The Following User Says Thank You to Medusa Box For This Useful Post: |
11-18-2018, 02:22 | #7 (permalink) |
Junior Member Join Date: Nov 2015 Location: Nicaragua, Masaya
Member: 2488840 Status: Offline Thanks Meter: 1 | log Model Settings: Interface : eMMC Brand : Samsung Model : G7102 SRF : C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/SAMSUNG_G7102_(TEST)_THANKS_TO_MR_MIRAZG.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC 8WMB3R Page size : 512 B Block size : 512 B Block count : 2097152 Size : 1024.00 MB --------------------------------------------------------------- CID Info CID : 15010038574D42335200D71C5B11512D Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 8WMB3R Full name : KLM8G1WEMB-B031 Product revision : 0.0 Product serial number : (hex) D71C5B11 Manufacturing date : 05/1998 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.0 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.0 (for MMC v4.0) Erase block size : 0 Kbytes Boot1 size : 0 Kbytes Boot2 size : 0 Kbytes RPMB size : 0 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Max enhanced data size: 0 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/8WMB3R_17_11_2018_19_17_27.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.9; FW: 1.24. |
11-18-2018, 13:13 | #8 (permalink) | ||
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | As You can see from your Software log, You have not connected the device correctly or eMMC has HW problems - eMMC size (capacity) can't be 1024.00 MB: Quote:
