05-01-2018, 07:44 | #1 (permalink) |
Freak Poster Join Date: May 2016 Location: India,Odisha Age: 27
Member: 2573604 Status: Offline Thanks Meter: 30 | Samsung SM-J100H "dead" boot repair sucess Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J100H SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J100H_EMMC_H4G2B.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A4834473262110137290864324B Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) 37290864 Manufacturing date : 03/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H4G2b_01_05_2018_11_49_08.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.8; FW: 1.23. Erasing. Please wait... Done. SW: 1.5.8; FW: 1.23. No General Purpose Partition 1 enhanced attribute is not set write reliablity is set No General Purpose Partition 2 enhanced attribute is not set write reliablity is set No General Purpose Partition 3 enhanced attribute is not set write reliablity is set No General Purpose Partition 4 enhanced attribute is not set write reliablity is set No enhanced user data area write reliablity is not set Creating HW partitions succesfully complete! Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J100H SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J100H_EMMC_H4G2B.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A4834473262110137290864324B Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) 37290864 Manufacturing date : 03/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x1 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H4G2b_01_05_2018_11_49_41.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.8; FW: 1.23. Selected pit file: C:/Users/Majub Alli/Desktop/j1/J13G.pit Open file "C:/Users/Majub Alli/Desktop/j1/SM-J100H/J100HDDS0AQB1_J100HODD0AQA2_J100HDDU0APH1_HOME.tar .md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition BOOT... Done. Switched to user area. Writing partition SBOOT... Done. Writing partition SBOOT2... Done. Writing partition WDSP... Done. Writing partition MODEM... Done. Writing partition KERNEL... Done. Writing partition RECOVERY... Done. Writing partition CSC... Done. Writing partition system... Done. Writing partition HIDDEN... Done. Writing is finished. SW: 1.5.8; FW: 1.23. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J100H SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J100H_EMMC_H4G2B.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A4834473262110137290864324B Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) 37290864 Manufacturing date : 03/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x1 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : e9000000 bytes Device sector size : 512 bytes Partition offset : 616448 Number of sectors : 2129920 Device Manufacturer :samsung Device Platform :sc8830 Build ID :KTU84P Display Build ID :KTU84P.J100HDDS0AQB1 Release ID :4.4.4 Device Model :SM-J100H Device Name :j13gxx Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Build Description :j13gxx-user 4.4.4 KTU84P J100HDDS0AQB1 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H4G2b_01_05_2018_11_59_57.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.8; FW: 1.23. P00: GPT (00000000, 00002000) 4 MB P01: sboot (00002000, 00001000) 2048 KB P02: sboot2 (00003000, 00001000) 2048 KB P03: wfixnv1 (00004000, 00000800) 1024 KB P04: wfixnv2 (00004800, 00000800) 1024 KB P05: tdfixnv1 (00005000, 00000800) 1024 KB P06: tdfixnv2 (00005800, 00000800) 1024 KB P07: wdsp (00006000, 00002000) 4 MB P08: modem (00008000, 00004000) 8 MB P09: modem2 (0000C000, 00004000) 8 MB P10: tddsp (00010000, 00002000) 4 MB P11: fota_sig (00012000, 00000800) 1024 KB P12: wruntimenv1 (00012800, 00000800) 1024 KB P13: wruntimenv2 (00013000, 00000800) 1024 KB P14: tdruntimenv1 (00013800, 00000800) 1024 KB P15: tdruntimenv2 (00014000, 00000800) 1024 KB P16: param (00014800, 00001000) 2048 KB P17: efs (00015800, 0000A000) 20 MB P18: prodnv (0001F800, 00002800) 5 MB P19: reserved2 (00022000, 00000800) 1024 KB P20: kernel (00022800, 00008000) 16 MB P21: recovery (0002A800, 00008000) 16 MB P22: csc (00032800, 00064000) 200 MB P23: system (00096800, 00208000) 1040 MB P24: hidden (0029E800, 00014000) 40 MB P25: userdata (002B2800, 00493800) 2343 MB Disconnected. Last edited by Medusa Box; 05-01-2018 at 11:47. |
The Following User Says Thank You to majub alli For This Useful Post: |
