12-31-2018, 18:34 | #1 (permalink) |
No Life Poster Join Date: Jul 2013 Location: in my company
Member: 1984825 Status: Offline Thanks Meter: 222 | Samsung SM-J100H repair question [Solved] Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: Generic EMV Smartcard Reader 0 Reader #3: Generic EMV Smartcard Reader 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J100H SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J100H_EMMC_H4G2B.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A4834473262110166EBE0DF32F9 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) 66EBE0DF Manufacturing date : 03/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/H4G2b_31_12_2018_09_29_38.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.2; FW: 1.24. Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J100H_EMMC_H4G2B.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to user area. Writing GPT partition... Done. Writing SBOOT partition... Done. Writing SBOOT2 partition... Done. Writing wfixnv1 partition... Done. Writing wfixnv2 partition... Done. Writing tdfixnv1 partition... Done. Writing tdfixnv2 partition... Done. Writing WDSP partition... Done. Writing MODEM partition... Done. Writing MODEM2 partition... Done. Writing TDDSP partition... Done. Writing wruntimenv1 partition... ERROR[012]: Write error. At sector 75776 Attempting to write... Done. Writing wruntimenv2 partition... Done. Writing tdruntimenv1 partition... Done. Writing tdruntimenv2 partition... Done. Writing PARAM partition... Done. Writing efs partition... Done. Smart Repair is successfully complete. SW: 1.7.2; FW: 1.24. Disconnected. whats wrong great team Last edited by Medusa Box; 01-02-2019 at 05:18. |
The Following User Says Thank You to tikourine For This Useful Post: |
01-01-2019, 09:03 | #2 (permalink) | |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Most likely, device has HW issue, because an errors occur on the process of writing: Quote:
If the device doesn't go into DM, here can be two main reasons of this problem - device has HW issue (most likely) or boot loaders in SRF files which You have used for repairing could be not suitable (not compatible) with your phone (boot loaders are older (has lower version) than should be in your phone, thus the phone can't go into Download Mode because of enabled boot downgrade protection). Try to perform "Factory Repair" operation ("Factory repair" tab in Software) using proper PIT file and different latest original Samsung firmwares for this phone model. Also please note, that here exist different HW revisions of this device, maybe your device has another HW, that the supported one and repair file on the Support Area is not compatible for your phone. To repair the phone try to do the following: 1. Download "Boot Area Partition 1" file "BOOT1_SAMSUNG SM-J100H) HYNIX EMMC H4G2B.BIN" via "Download *.srf" button. 2. Connect the phone and erase "Boot Area Partition 1" (select "Boot Area Partition 1" option in Software and press "Erase" button). 3. Disconnect the phone. 4. Connect the phone and write "Boot Area Partition 1" file "BOOT1_SAMSUNG SM-J100H) HYNIX EMMC H4G2B.BIN" (select "Boot Area Partition 1" option and press "Write" button). 5. Disconnect the phone. 6. Connect the phone and do "Factory Repair" ("Factory repair" tab in Software) using PIT file and original Samsung firmware from here: [ Post here Latest Original Firmwares ] For Repair Boot in [ Factory Mode ] - Page 5 - GSM-Forum. 7. Disconnect the phone and try to power it on or put it into Download Mode. Try to use different latest original Samsung firmwares for "Factory Repair". Also, look here: http://forum.gsmhosting.com/vbb/f664.../#post12541224, http://forum.gsmhosting.com/vbb/f664.../#post12335114, http://forum.gsmhosting.com/vbb/f664.../#post12611783, http://forum.gsmhosting.com/vbb/f664...l#post12925569, http://forum.gsmhosting.com/vbb/f664.../#post12849039. If the problem is still the same, check HW, try to replace eMMC chip and do repair again. | |
The Following User Says Thank You to Medusa Box For This Useful Post: |
01-01-2019, 12:56 | #3 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,103 | Use the same method and step for j110h to resolve "ERROR[012]: Write error" as here: http://forum.gsmhosting.com/vbb/f664...irmed-2537855/, http://forum.gsmhosting.com/vbb/f664...olved-2537084/, http://forum.gsmhosting.com/vbb/f664...wered-2534704/. Last edited by Octopus box; 01-01-2019 at 14:54. |
The Following User Says Thank You to rebainoor For This Useful Post: |
01-01-2019, 16:15 | #4 (permalink) |
Member: 231728 Status: Offline Thanks Meter: 2,103 | after successefull connected in emmc mode go to EMMC service tab and clic in HW Partitions and do not change any think and clic in write after that you will get this : Code: No General Purpose Partition 1 enhanced attribute is not set write reliablity is set No General Purpose Partition 2 enhanced attribute is not set write reliablity is set No General Purpose Partition 3 enhanced attribute is not set write reliablity is set No General Purpose Partition 4 enhanced attribute is not set write reliablity is set No enhanced user data area write reliablity is not set Creating HW partitions succesfully complete! |
The Following 2 Users Say Thank You to rebainoor For This Useful Post: |
01-01-2019, 21:32 | #5 (permalink) | |
Member: 1984825 Status: Offline Thanks Meter: 222 | Quote:
rebainoor thx a lot you make me happy tonight this log of operation Selected pit file: C:/Users/mobile solutions/Downloads/SM-J100H_15-11-2016_12-31-28.pit Selected firmware file: C:/Users/mobile solutions/Desktop/J100HXXU0AOA2_OJV0AOA2_Repair_Firmware_4Files(1)/AP_J100HXXU0AOA2_CL332283_QB3547216_REV01_user_low _ship_.tar.md5 Open file "C:/Users/mobile solutions/Desktop/J100HXXU0AOA2_OJV0AOA2_Repair_Firmware_4Files(1)/AP_J100HXXU0AOA2_CL332283_QB3547216_REV01_user_low _ship_.tar.md5". Selected firmware file: C:/Users/mobile solutions/Desktop/J100HXXU0AOA2_OJV0AOA2_Repair_Firmware_4Files(1)/BL_J100HXXU0AOA2_CL332283_QB3547216_REV01_user_low _ship.tar.md5 Open file "C:/Users/mobile solutions/Desktop/J100HXXU0AOA2_OJV0AOA2_Repair_Firmware_4Files(1)/BL_J100HXXU0AOA2_CL332283_QB3547216_REV01_user_low _ship.tar.md5". Selected firmware file: C:/Users/mobile solutions/Desktop/J100HXXU0AOA2_OJV0AOA2_Repair_Firmware_4Files(1)/CP_J100HXXU0AOA3_CL332283_QB3609726_REV01_user_low _ship.tar.md5 Open file "C:/Users/mobile solutions/Desktop/J100HXXU0AOA2_OJV0AOA2_Repair_Firmware_4Files(1)/CP_J100HXXU0AOA3_CL332283_QB3609726_REV01_user_low _ship.tar.md5". Selected firmware file: C:/Users/mobile solutions/Desktop/J100HXXU0AOA2_OJV0AOA2_Repair_Firmware_4Files(1)/CSC_OJV_J100HOJV0AOA2_CL332283_QB3547216_REV01_use r_low_ship.tar.md5 Open file "C:/Users/mobile solutions/Desktop/J100HXXU0AOA2_OJV0AOA2_Repair_Firmware_4Files(1)/CSC_OJV_J100HOJV0AOA2_CL332283_QB3547216_REV01_use r_low_ship.tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Writing partition BOOT... Done. #greenWriting partition SBOOT... Done. #greenWriting partition SBOOT2... Done. #greenWriting partition wfixnv2... Done. #greenWriting partition WDSP... Done. #greenWriting partition MODEM... Done. #greenWriting partition PARAM... Done. #greenWriting partition KERNEL... Done. #greenWriting partition RECOVERY... Done. #greenWriting partition CSC... Done. #greenWriting partition system... Done. #greenWriting partition HIDDEN... Done. #greenWriting is finished. SW: 1.7.2; FW: 1.24. #blue | |
The Following 2 Users Say Thank You to tikourine For This Useful Post: |
