11-03-2018, 18:57 | #1 (permalink) |
Insane Poster Join Date: Nov 2006 Location: Goiás - Brasil Age: 39
Member: 397772 Status: Offline Sonork: 5561995554600 Thanks Meter: 97 | Samsung SM-J105B repair 100% done, but appliance will not turn on [Answered] Log: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : 15 MHz Connecting... Device : Hynix eMMC H8G4t Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A4838473474920128F23C7E5363 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4t Product revision : 0.1 Product serial number : (hex) 28F23C7E Manufacturing date : 05/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFE78A40002B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 638976 Number of sectors : 4399104 Device Manufacturer :samsung Device Platform :sc8830 Build ID :LMY47V Display Build ID :LMY47V.J105BUBU0ARD1 Release ID :5.1.1 Device Model :SM-J105B Device Name :j1mini3gub Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :j1mini3gub-user 5.1.1 LMY47V J105BUBU0ARD1 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G4t_03_11_2018_14_54_05.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.9; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: SBOOT (00002000, 00001000) 2048 KB P02: SBOOT2 (00003000, 00001000) 2048 KB P03: wfixnv1 (00004000, 00000800) 1024 KB P04: wfixnv2 (00004800, 00000800) 1024 KB P05: tdfixnv1 (00005000, 00000800) 1024 KB P06: tdfixnv2 (00005800, 00000800) 1024 KB P07: WDSP (00006000, 00002000) 4 MB P08: MODEM (00008000, 00004000) 8 MB P09: MODEM2 (0000C000, 00004000) 8 MB P10: TDDSP (00010000, 00002000) 4 MB P11: FOTA_SIG (00012000, 00000800) 1024 KB P12: wruntimenv1 (00012800, 00000800) 1024 KB P13: wruntimenv2 (00013000, 00000800) 1024 KB P14: tdruntimenv1 (00013800, 00000800) 1024 KB P15: tdruntimenv2 (00014000, 00000800) 1024 KB P16: PARAM (00014800, 00001000) 2048 KB P17: efs (00015800, 0000A000) 20 MB P18: prodnv (0001F800, 00002800) 5 MB P19: RESERVED2 (00022000, 00001000) 2048 KB P20: KERNEL (00023000, 00008000) 16 MB P21: RECOVERY (0002B000, 00008000) 16 MB P22: PERSISTENT (00033000, 00000800) 1024 KB P23: persdata (00033800, 00004800) 9 MB P24: CACHE (00038000, 00064000) 200 MB P25: SYSTEM (0009C000, 00432000) 2148 MB P26: HIDDEN (004CE000, 00014000) 40 MB P27: userdata (004E2000, 009A8000) 4.828 GB Last edited by Medusa Box; 11-04-2018 at 13:08. |
11-05-2018, 12:13 | #3 (permalink) | |
Member: 397772 Status: Offline Sonork: 5561995554600 Thanks Meter: 97 | Quote:
Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... Device : Hynix eMMC H8G4t Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A4838473474920128F23C7E5363 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4t Product revision : 0.1 Product serial number : (hex) 28F23C7E Manufacturing date : 05/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFE78A40002B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G4t_01_11_2018_15_10_14.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.9; FW: 1.24. The same area. Opening C:/Users/Camilo Celular/Desktop/J105B/jord bkp/GPT_31_10_2018_13_54_45.bin file... Write data verification is enabled. Writing. Please wait... Done. SW: 1.6.9; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... Device : Hynix eMMC H8G4t Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A4838473474920128F23C7E5363 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4t Product revision : 0.1 Product serial number : (hex) 28F23C7E Manufacturing date : 05/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFE78A40002B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G4t_01_11_2018_15_10_33.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.9; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: SBOOT (00002000, 00001000) 2048 KB P02: SBOOT2 (00003000, 00001000) 2048 KB P03: wfixnv1 (00004000, 00000800) 1024 KB P04: wfixnv2 (00004800, 00000800) 1024 KB P05: tdfixnv1 (00005000, 00000800) 1024 KB P06: tdfixnv2 (00005800, 00000800) 1024 KB P07: WDSP (00006000, 00002000) 4 MB P08: MODEM (00008000, 00004000) 8 MB P09: MODEM2 (0000C000, 00004000) 8 MB P10: TDDSP (00010000, 00002000) 4 MB P11: FOTA_SIG (00012000, 00000800) 1024 KB P12: wruntimenv1 (00012800, 00000800) 1024 KB P13: wruntimenv2 (00013000, 00000800) 1024 KB P14: tdruntimenv1 (00013800, 00000800) 1024 KB P15: tdruntimenv2 (00014000, 00000800) 1024 KB P16: PARAM (00014800, 00001000) 2048 KB P17: efs (00015800, 0000A000) 20 MB P18: prodnv (0001F800, 00002800) 5 MB P19: RESERVED2 (00022000, 00001000) 2048 KB P20: KERNEL (00023000, 00008000) 16 MB P21: RECOVERY (0002B000, 00008000) 16 MB P22: PERSISTENT (00033000, 00000800) 1024 KB P23: persdata (00033800, 00004800) 9 MB P24: CACHE (00038000, 00064000) 200 MB P25: SYSTEM (0009C000, 00432000) 2148 MB P26: HIDDEN (004CE000, 00014000) 40 MB P27: userdata (004E2000, 009A8000) 4.828 GB Selected pit file: E:/Flash Samsung Z3X/J105B_ZTO/J1MINI3G_EUR_OPEN.pit Open file "E:/Flash Samsung Z3X/J105B_ZTO/AP_J105BUBU0ARD1_CL13289775_QB17546192_REV00_user_ low_ship.tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Writing partition KERNEL... Done. Writing partition RECOVERY... Done. Writing partition SYSTEM... Done. Writing is finished. SW: 1.6.9; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... Device : Hynix eMMC H8G4t Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A4838473474920128F23C7E5363 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4t Product revision : 0.1 Product serial number : (hex) 28F23C7E Manufacturing date : 05/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFE78A40002B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G4t_01_11_2018_15_35_20.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.9; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: sboot (00002000, 00001000) 2048 KB P02: sboot2 (00003000, 00001000) 2048 KB P03: wfixnv1 (00004000, 00000800) 1024 KB P04: wfixnv2 (00004800, 00000800) 1024 KB P05: tdfixnv1 (00005000, 00000800) 1024 KB P06: tdfixnv2 (00005800, 00000800) 1024 KB P07: wdsp (00006000, 00002000) 4 MB P08: modem (00008000, 00004000) 8 MB P09: modem2 (0000C000, 00004000) 8 MB P10: tddsp (00010000, 00002000) 4 MB P11: fota_sig (00012000, 00000800) 1024 KB P12: wruntimenv1 (00012800, 00000800) 1024 KB P13: wruntimenv2 (00013000, 00000800) 1024 KB P14: tdruntimenv1 (00013800, 00000800) 1024 KB P15: tdruntimenv2 (00014000, 00000800) 1024 KB P16: param (00014800, 00001000) 2048 KB P17: efs (00015800, 0000A000) 20 MB P18: prodnv (0001F800, 00002800) 5 MB P19: reserved2 (00022000, 00001000) 2048 KB P20: kernel (00023000, 00008000) 16 MB P21: recovery (0002B000, 00008000) 16 MB P22: persistent (00033000, 00000800) 1024 KB P23: persdata (00033800, 00004800) 9 MB P24: cache (00038000, 00064000) 200 MB P25: system (0009C000, 00432000) 2148 MB P26: hidden (004CE000, 00014000) 40 MB P27: userdata (004E2000, 009AC000) 4.836 GB Write data verification is enabled. Write partitions from C:/Users/Camilo Celular/Desktop/J105B/Hynix eMMC H8G4t_qua out 31 2018_14_04_09.mpt file... Writing partition GPT... Done. Writing partition SBOOT... Done. Writing partition SBOOT2... Done. Writing partition wfixnv1... Done. Writing partition wfixnv2... Done. Writing partition tdfixnv1... Done. Writing partition tdfixnv2... Done. Writing partition WDSP... Done. Writing partition MODEM... Done. Writing partition MODEM2... Done. Writing partition TDDSP... Done. Writing partition FOTA_SIG... Done. Writing partition wruntimenv1... Done. Writing partition wruntimenv2... Done. Writing partition tdruntimenv1... Done. Writing partition tdruntimenv2... Done. Writing partition PARAM... Done. Writing partition efs... Done. Writing partition prodnv... Done. Writing partition RESERVED2... Done. Writing partition KERNEL... Done. Writing partition RECOVERY... Done. SW: 1.6.9; FW: 1.24. The same area. Opening C:/Users/Camilo Celular/Desktop/J105B/jord bkp/PERSISTENT_31_10_2018_14_52_21.bin file... Write data verification is enabled. Writing. Please wait... Done. SW: 1.6.9; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... Device : Hynix eMMC H8G4t Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A4838473474920128F23C7E5363 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4t Product revision : 0.1 Product serial number : (hex) 28F23C7E Manufacturing date : 05/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFE78A40002B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G4t_01_11_2018_15_39_03.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.9; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... Device : Hynix eMMC H8G4t Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A4838473474920128F23C7E5363 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4t Product revision : 0.1 Product serial number : (hex) 28F23C7E Manufacturing date : 05/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFE78A40002B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G4t_01_11_2018_15_39_10.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.9; FW: 1.24. Cancelled writing. The same area. Opening C:/Users/Camilo Celular/Desktop/J105B/jord bkp/GPT_31_10_2018_13_54_45.bin file... Write data verification is enabled. Writing. Please wait... Done. SW: 1.6.9; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... Device : Hynix eMMC H8G4t Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A4838473474920128F23C7E5363 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4t Product revision : 0.1 Product serial number : (hex) 28F23C7E Manufacturing date : 05/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFE78A40002B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G4t_01_11_2018_15_39_35.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.9; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: SBOOT (00002000, 00001000) 2048 KB P02: SBOOT2 (00003000, 00001000) 2048 KB P03: wfixnv1 (00004000, 00000800) 1024 KB P04: wfixnv2 (00004800, 00000800) 1024 KB P05: tdfixnv1 (00005000, 00000800) 1024 KB P06: tdfixnv2 (00005800, 00000800) 1024 KB P07: WDSP (00006000, 00002000) 4 MB P08: MODEM (00008000, 00004000) 8 MB P09: MODEM2 (0000C000, 00004000) 8 MB P10: TDDSP (00010000, 00002000) 4 MB P11: FOTA_SIG (00012000, 00000800) 1024 KB P12: wruntimenv1 (00012800, 00000800) 1024 KB P13: wruntimenv2 (00013000, 00000800) 1024 KB P14: tdruntimenv1 (00013800, 00000800) 1024 KB P15: tdruntimenv2 (00014000, 00000800) 1024 KB P16: PARAM (00014800, 00001000) 2048 KB P17: efs (00015800, 0000A000) 20 MB P18: prodnv (0001F800, 00002800) 5 MB P19: RESERVED2 (00022000, 00001000) 2048 KB P20: KERNEL (00023000, 00008000) 16 MB P21: RECOVERY (0002B000, 00008000) 16 MB P22: PERSISTENT (00033000, 00000800) 1024 KB P23: persdata (00033800, 00004800) 9 MB P24: CACHE (00038000, 00064000) 200 MB P25: SYSTEM (0009C000, 00432000) 2148 MB P26: HIDDEN (004CE000, 00014000) 40 MB P27: userdata (004E2000, 009A8000) 4.828 GB Repairing from file "C:/Users/Camilo Celular/Desktop/J105B/Samsung_J105B.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to boot area partition 2. Writing BOOT2 partition... Done. Switched to user area. Writing GPT partition... Done. Writing SBOOT partition... Done. Writing SBOOT2 partition... Done. Writing wfixnv1 partition... Done. Writing wfixnv2 partition... Done. Writing tdfixnv1 partition... Done. Writing tdfixnv2 partition... Done. Writing WDSP partition... Done. Writing MODEM partition... Done. Writing MODEM2 partition... Done. Writing TDDSP partition... Done. Writing FOTA_SIG partition... Done. Writing wruntimenv1 partition... Done. Writing wruntimenv2 partition... Done. Writing tdruntimenv1 partition... Done. Writing tdruntimenv2 partition... Done. Writing PARAM partition... Done. Writing efs partition... Done. Writing prodnv partition... Done. Writing RESERVED2 partition... Done. Writing KERNEL partition... Done. Writing RECOVERY partition... Done. Smart Repair is successfully complete. SW: 1.6.9; FW: 1.24. Disconnected. | |
11-05-2018, 13:54 | #4 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Accordingly to your Software log, "Smart Repair" operation was performed successfully and correctly. If the device doesn't go into Download Mode, here can be two main reasons of this problem - device has HW issue (problem with eMMC chip) or boot in firmware file, which You have used for repairing, are not suitable (not compatible) with your phone revision (boot loaders are older (has lower version) than should be in your phone, thus the phone can't go into Download Mode because of enabled boot downgrade protection). Try to perform "Factory Repair" operation using other original full firmwares for this device model. Also if You have the same working device, read out Boot Area Partition 1 backup and full flash and try to write them into your device. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
11-05-2018, 14:18 | #5 (permalink) |
No Life Poster Join Date: Dec 2016 Location: Pakistan Age: 27
Member: 2665080 Status: Offline Thanks Meter: 63 | Welcome to Medusa Pro Software version 1.6.7. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Alcor Micro USB Smart Card Reader 1 Reader #2: Alcor Micro USB Smart Card Reader 2 Reader #3: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J106H SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J106H_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H8G4t Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A483847347492011C4060AB4479 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4t Product revision : 0.1 Product serial number : (hex) 1C4060AB Manufacturing date : 04/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFE78A40002B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G4t_05_11_2018_18_07_26.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.7; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: SBOOT (00002000, 00001000) 2048 KB P02: SBOOT2 (00003000, 00001000) 2048 KB P03: wfixnv1 (00004000, 00000800) 1024 KB P04: wfixnv2 (00004800, 00000800) 1024 KB P05: tdfixnv1 (00005000, 00000800) 1024 KB P06: tdfixnv2 (00005800, 00000800) 1024 KB P07: WDSP (00006000, 00002000) 4 MB P08: MODEM (00008000, 00004000) 8 MB P09: MODEM2 (0000C000, 00004000) 8 MB P10: TDDSP (00010000, 00002000) 4 MB P11: FOTA_SIG (00012000, 00000800) 1024 KB P12: wruntimenv1 (00012800, 00000800) 1024 KB P13: wruntimenv2 (00013000, 00000800) 1024 KB P14: tdruntimenv1 (00013800, 00000800) 1024 KB P15: tdruntimenv2 (00014000, 00000800) 1024 KB P16: PARAM (00014800, 00001000) 2048 KB P17: efs (00015800, 0000A000) 20 MB P18: prodnv (0001F800, 00002800) 5 MB P19: RESERVED2 (00022000, 00000C00) 1536 KB P20: KERNEL (00022C00, 00008000) 16 MB P21: RECOVERY (0002AC00, 00008000) 16 MB P22: PERSISTENT (00032C00, 00000400) 512 KB P23: STEADY (00033000, 00000800) 1024 KB P24: persdata (00033800, 00004800) 9 MB P25: CACHE (00038000, 00064000) 200 MB P26: SYSTEM (0009C000, 00568000) 2768 MB P27: HIDDEN (00604000, 00014000) 40 MB P28: userdata (00618000, 00872000) 4.223 GB Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J106H SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J106H_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H8G4t Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A483847347492011C4060AB4479 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4t Product revision : 0.1 Product serial number : (hex) 1C4060AB Manufacturing date : 04/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFE78A40002B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G4t_05_11_2018_18_07_40.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.7; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: SBOOT (00002000, 00001000) 2048 KB P02: SBOOT2 (00003000, 00001000) 2048 KB P03: wfixnv1 (00004000, 00000800) 1024 KB P04: wfixnv2 (00004800, 00000800) 1024 KB P05: tdfixnv1 (00005000, 00000800) 1024 KB P06: tdfixnv2 (00005800, 00000800) 1024 KB P07: WDSP (00006000, 00002000) 4 MB P08: MODEM (00008000, 00004000) 8 MB P09: MODEM2 (0000C000, 00004000) 8 MB P10: TDDSP (00010000, 00002000) 4 MB P11: FOTA_SIG (00012000, 00000800) 1024 KB P12: wruntimenv1 (00012800, 00000800) 1024 KB P13: wruntimenv2 (00013000, 00000800) 1024 KB P14: tdruntimenv1 (00013800, 00000800) 1024 KB P15: tdruntimenv2 (00014000, 00000800) 1024 KB P16: PARAM (00014800, 00001000) 2048 KB P17: efs (00015800, 0000A000) 20 MB P18: prodnv (0001F800, 00002800) 5 MB P19: RESERVED2 (00022000, 00000C00) 1536 KB P20: KERNEL (00022C00, 00008000) 16 MB P21: RECOVERY (0002AC00, 00008000) 16 MB P22: PERSISTENT (00032C00, 00000400) 512 KB P23: STEADY (00033000, 00000800) 1024 KB P24: persdata (00033800, 00004800) 9 MB P25: CACHE (00038000, 00064000) 200 MB P26: SYSTEM (0009C000, 00568000) 2768 MB P27: HIDDEN (00604000, 00014000) 40 MB P28: userdata (00618000, 00872000) 4.223 GB Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J106H_EMMC.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to boot area partition 2. Writing BOOT2 partition... Done. Switched to user area. Writing GPT partition... Done. Writing SBOOT partition... Done. Writing SBOOT2 partition... Done. Writing wfixnv1 partition... Done. Writing wfixnv2 partition... Done. Writing tdfixnv1 partition... Done. Writing tdfixnv2 partition... Done. Writing WDSP partition... Done. Writing MODEM partition... Done. Writing MODEM2 partition... Done. Writing TDDSP partition... Done. Writing FOTA_SIG partition... Done. Writing wruntimenv1 partition... Done. Writing wruntimenv2 partition... Done. Writing tdruntimenv1 partition... Done. Writing tdruntimenv2 partition... Done. Writing PARAM partition... Done. Writing efs partition... Done. Writing prodnv partition... Done. Writing RESERVED2 partition... Done. Writing KERNEL partition... Done. Writing RECOVERY partition... Done. Writing PERSISTENT partition... Done. Writing STEADY partition... Done. Writing persdata partition... Done. Writing CACHE partition... Done. Writing HIDDEN partition... Done. Smart Repair is successfully complete. SW: 1.6.7; FW: 1.24. Disconnected. |
11-05-2018, 15:03 | #7 (permalink) | |
Welcome to Medusa Pro Software version 1.6.9. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: FT SCR2000 2 Reader #3: FT SCR2000 3 Reader #4: Gemalto e-gate Smart Card 0 Reader #5: Generic Usb Smart Card Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H8G4t Page size : 512 B Block size : 512 B Block count : 15261696 Size : 7.28 GB (7452.00 MB) --------------------------------------------------------------- CID Info CID : 90014A4838473474920128F23C7E5363 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4t Product revision : 0.1 Product serial number : (hex) 28F23C7E Manufacturing date : 05/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFE78A40002B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x04) 00000100 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Retain BOOT_BUS_WIDTH and BOOT_MODE values after boot operation Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x1 GP partition 1 size : 4 MB GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : d1c00000 bytes Device sector size : 512 bytes Partition offset : 638976 Number of sectors : 4399104 Device Manufacturer :samsung Device Platform :sc8830 Build ID :LMY47V Display Build ID :LMY47V.J105BUBU0ARD1 Release ID :5.1.1 Device Model :SM-J105B Device Name :j1mini3gub Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :j1mini3gub-user 5.1.1 LMY47V J105BUBU0ARD1 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G4t_05_11_2018_11_37_57.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.9; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: SBOOT (00002000, 00001000) 2048 KB P02: SBOOT2 (00003000, 00001000) 2048 KB P03: wfixnv1 (00004000, 00000800) 1024 KB P04: wfixnv2 (00004800, 00000800) 1024 KB P05: tdfixnv1 (00005000, 00000800) 1024 KB P06: tdfixnv2 (00005800, 00000800) 1024 KB P07: WDSP (00006000, 00002000) 4 MB P08: MODEM (00008000, 00004000) 8 MB P09: MODEM2 (0000C000, 00004000) 8 MB P10: TDDSP (00010000, 00002000) 4 MB P11: FOTA_SIG (00012000, 00000800) 1024 KB P12: wruntimenv1 (00012800, 00000800) 1024 KB P13: wruntimenv2 (00013000, 00000800) 1024 KB P14: tdruntimenv1 (00013800, 00000800) 1024 KB P15: tdruntimenv2 (00014000, 00000800) 1024 KB P16: PARAM (00014800, 00001000) 2048 KB P17: efs (00015800, 0000A000) 20 MB P18: prodnv (0001F800, 00002800) 5 MB P19: RESERVED2 (00022000, 00001000) 2048 KB P20: KERNEL (00023000, 00008000) 16 MB P21: RECOVERY (0002B000, 00008000) 16 MB P22: PERSISTENT (00033000, 00000800) 1024 KB P23: persdata (00033800, 00004800) 9 MB P24: CACHE (00038000, 00064000) 200 MB P25: SYSTEM (0009C000, 00432000) 2148 MB P26: HIDDEN (004CE000, 00014000) 40 MB P27: userdata (004E2000, 009A8000) 4.828 GB Please select file. Selected pit file: C:/Users/Camilo Celular/Desktop/J105B/J105B_4_partes_ZTO/J1MINI3G_EUR_OPEN.pit Open file "C:/Users/Camilo Celular/Desktop/J105B/J105B_4_partes_ZTO/BL_J105BUBU0ARD1_CL13289775_QB17546192_REV00_user_ low_ship.tar". Open file "C:/Users/Camilo Celular/Desktop/J105B/J105B_4_partes_ZTO/CP_J105BUBU0ARC1_CL13139564_QB17134855_REV00_user_ low_ship.tar". Open file "C:/Users/Camilo Celular/Desktop/J105B/J105B_4_partes_ZTO/CSC_ZTO_J105BZTO0ARC1_CL13139660_QB17146277_REV00_ user_low_ship.tar". Open file "C:/Users/Camilo Celular/Desktop/J105B/J105B_4_partes_ZTO/AP_J105BUBU0ARD1_CL13289775_QB17546192_REV00_user_ low_ship.tar". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition BOOT... Done. Switched to user area. Writing partition SBOOT... Done. Writing partition SBOOT2... Done. Writing partition wfixnv2... Done. Writing partition WDSP... Done. Writing partition MODEM... Done. Writing partition PARAM... Done. Writing partition KERNEL... Done. Writing partition RECOVERY... Done. Writing partition CACHE... Done. Writing partition SYSTEM... Done. Writing partition HIDDEN... Done. Writing is finished. SW: 1.6.9; FW: 1.24. ----------------------------------------------------- Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H8G4t Page size : 512 B Block size : 512 B Block count : 15261696 Size : 7.28 GB (7452.00 MB) --------------------------------------------------------------- CID Info CID : 90014A4838473474920128F23C7E5363 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4t Product revision : 0.1 Product serial number : (hex) 28F23C7E Manufacturing date : 05/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFE78A40002B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x04) 00000100 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Retain BOOT_BUS_WIDTH and BOOT_MODE values after boot operation Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x1 GP partition 1 size : 4 MB GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : d1c00000 bytes Device sector size : 512 bytes Partition offset : 638976 Number of sectors : 4399104 Device Manufacturer :samsung Device Platform :sc8830 Build ID :LMY47V Display Build ID :LMY47V.J105BUBU0ARD1 Release ID :5.1.1 Device Model :SM-J105B Device Name :j1mini3gub Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :j1mini3gub-user 5.1.1 LMY47V J105BUBU0ARD1 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G4t_05_11_2018_11_58_52.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.9; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: sboot (00002000, 00001000) 2048 KB P02: sboot2 (00003000, 00001000) 2048 KB P03: wfixnv1 (00004000, 00000800) 1024 KB P04: wfixnv2 (00004800, 00000800) 1024 KB P05: tdfixnv1 (00005000, 00000800) 1024 KB P06: tdfixnv2 (00005800, 00000800) 1024 KB P07: wdsp (00006000, 00002000) 4 MB P08: modem (00008000, 00004000) 8 MB P09: modem2 (0000C000, 00004000) 8 MB P10: tddsp (00010000, 00002000) 4 MB P11: fota_sig (00012000, 00000800) 1024 KB P12: wruntimenv1 (00012800, 00000800) 1024 KB P13: wruntimenv2 (00013000, 00000800) 1024 KB P14: tdruntimenv1 (00013800, 00000800) 1024 KB P15: tdruntimenv2 (00014000, 00000800) 1024 KB P16: param (00014800, 00001000) 2048 KB P17: efs (00015800, 0000A000) 20 MB P18: prodnv (0001F800, 00002800) 5 MB P19: reserved2 (00022000, 00001000) 2048 KB P20: kernel (00023000, 00008000) 16 MB P21: recovery (0002B000, 00008000) 16 MB P22: persistent (00033000, 00000800) 1024 KB P23: persdata (00033800, 00004800) 9 MB P24: cache (00038000, 00064000) 200 MB P25: system (0009C000, 00432000) 2148 MB P26: hidden (004CE000, 00014000) 40 MB P27: userdata (004E2000, 009AA000) 4.832 GB | |
