08-08-2018, 13:43 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: South africa Age: 35
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | Samsung SM-J200H boot repair assistance required [Answered] Repairing from file "C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/SAMSUNG_SM-J200H_EMMC.SRF". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to boot area partition 2. Writing BOOT2 partition... Done. Switched to user area. Writing GPT partition... Done. Writing SBOOT partition... Done. Writing SBOOT2 partition... Done. Writing wfixnv1 partition... Done. Writing wfixnv2 partition... Done. Writing tdfixnv1 partition... Done. Writing tdfixnv2 partition... Done. Writing WDSP partition... Done. Writing MODEM partition... Done. Writing MODEM2 partition... Done. Writing TDDSP partition... Done. Writing FOTA_SIG partition... Done. Writing wruntimenv1 partition... Done. Writing wruntimenv2 partition... Done. Writing tdruntimenv1 partition... Done. Writing tdruntimenv2 partition... Done. Writing PARAM partition... Done. Writing efs partition... Done. Writing prodnv partition... Done. Writing RESERVED2 partition... Done. Writing KERNEL partition... Done. Writing RECOVERY partition... Done. Writing PERSISTENT partition... Done. Writing persdata partition... Done. Smart Repair is successfully complete. SW: 1.6.5; FW: 1.24. Disconnected. Last edited by Medusa Box; 08-08-2018 at 14:04. |
08-08-2018, 14:03 | #2 (permalink) | |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Quote:
Accordingly to your Software log, "Smart Repair" operation was performed successfully and correctly. If the device doesn't go into Download Mode, here can be two main reasons of this problem - device has HW issue (problem with eMMC chip, often occur with this device model) or boot loaders in SRF, which You have used for repairing, are not suitable (not compatible) with your phone revision (boot loaders are older (has lower version) than should be in your phone, thus the phone can't go into Download Mode because of enabled boot downgrade protection). Try to perform "Factory Repair" operation ("Factory repair" tab in Software) using proper PIT file and the latest available original Samsung firmware (in "*.tar" format) for this device model. Post the result. | |
The Following User Says Thank You to Medusa Box For This Useful Post: |
08-08-2018, 14:24 | #3 (permalink) | |
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | 100%you right i donnt have now latest file soon i give you report Quote:
Open file "E:/FLASH FILES/samsung files/j200h/J200HXXU0AOIB_5.1.1_Pre_Rooted/J2.tar". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition BOOT... Done. Switched to user area. Writing partition SBOOT... Done. Writing partition SBOOT2... Done. Writing partition WDSP... Done. Writing partition MODEM... Done. Writing partition KERNEL... Done. Writing partition RECOVERY... Done. Writing partition CACHE... Done. Writing partition SYSTEM... Done. Writing partition HIDDEN... Done. Writing is finished. SW: 1.6.5; FW: 1.24. | |
