01-12-2019, 19:11 | #1 (permalink) |
No Life Poster Join Date: Nov 2011 Location: Student
Member: 1686564 Status: Offline Sonork: PM me Thanks Meter: 157 | Samsung SM-J200H boot Repair ok BUT No power on [Answered] Phone connect Info Model Settings: Interface : eMMC Brand : Samsung Model : SM-J200H SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J200H_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H8G4t! Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A483847347421010214644B23BD Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4t! Product revision : 0.1 Product serial number : (hex) 214644B Manufacturing date : 02/2016 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A400013 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/H8G4t!_12_01_2019_17_40_11.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.2; FW: 1.24. Smart Repair ok INFO SW: 1.7.2; FW: 1.24. Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J200H_EMMC.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to boot area partition 2. Writing BOOT2 partition... Done. Switched to user area. Writing GPT partition... Done. Writing SBOOT partition... Done. Writing SBOOT2 partition... Done. Writing wfixnv1 partition... Done. Writing wfixnv2 partition... Done. Writing tdfixnv1 partition... Done. Writing tdfixnv2 partition... Done. Writing WDSP partition... Done. Writing MODEM partition... Done. Writing MODEM2 partition... Done. Writing TDDSP partition... Done. Writing FOTA_SIG partition... Done. Writing wruntimenv1 partition... Done. Writing wruntimenv2 partition... Done. Writing tdruntimenv1 partition... Done. Writing tdruntimenv2 partition... Done. Writing PARAM partition... Done. Writing efs partition... Done. Writing prodnv partition... Done. Writing RESERVED2 partition... Done. Writing KERNEL partition... Done. Writing RECOVERY partition... Done. Writing PERSISTENT partition... Done. Writing persdata partition... Done. Smart Repair is successfully complete. & also tray wit factory fashor option pit & BL File loding & also tray by sammobile latest flash file flashing ok but no power on & no download moad MY stapes 1 after connect phone tray to smart repair smart repair ok But nopower on & no download moad 2 aftar smart repair phone not ok i tray to flash by factory file pit & Bl file flashing ok but no power on |
01-14-2019, 09:35 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Quote:
Accordingly to your Software log, "Smart Repair" operation was performed successfully and correctly. If the device doesn't go into Download Mode, here can be two main reasons of this problem - device has HW issue (problem with eMMC chip, often occur with this device model) or boot loaders in SRF, which You have used for repairing, are not suitable (not compatible) with your phone revision (boot loaders are older (has lower version) than should be in your phone, thus the phone can't go into Download Mode because of enabled boot downgrade protection). | |
