12-27-2018, 13:03 | #1 (permalink) |
Freak Poster Join Date: Dec 2014 Location: Savar,Dhaka,Bangladesh.
Member: 2318480 Status: Offline Sonork: 100.1669259 Thanks Meter: 198 | Samsung SM-J200H "dead" boot repair successfully done Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Reader #2: FT SCR2000 1 Downloaded file C:/Program Files/Medusa Pro Software/firmwareFolder/(BOOT1 SAMSUNG SM-J200H) HYNIX EMMC H8G4T!.BIN. Downloaded file C:/Program Files/Medusa Pro Software/firmwareFolder/(BOOT2 SAMSUNG SM-J200H) HYNIX EMMC H8G4T!.BIN. Downloaded file C:/Program Files/Medusa Pro Software/firmwareFolder/(EXT_CSD SAMSUNG SM-J200H) HYNIX EMMC H8G4T!.BIN. Downloaded file C:/Program Files/Medusa Pro Software/firmwareFolder/(LIVE_LOG SAMSUNG SM-J200H) HYNIX EMMC H8G4T!.TXT. Downloaded and installed file C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J200H_EMMC.srf. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J200H SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J200H_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H8G4t! Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A48384734742101C18548D3928D Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4t! Product revision : 0.1 Product serial number : (hex) C18548D3 Manufacturing date : 09/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A400013 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G4t!_27_12_2018_17_56_28.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.1; FW: 1.24. Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J200H_EMMC.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to boot area partition 2. Writing BOOT2 partition... Done. Switched to user area. Writing GPT partition... Done. Writing SBOOT partition... Done. Writing SBOOT2 partition... Done. Writing wfixnv1 partition... Done. Writing wfixnv2 partition... Done. Writing tdfixnv1 partition... Done. Writing tdfixnv2 partition... Done. Writing WDSP partition... Done. Writing MODEM partition... Done. Writing MODEM2 partition... Done. Writing TDDSP partition... Done. Writing FOTA_SIG partition... Done. Writing wruntimenv1 partition... Done. Writing wruntimenv2 partition... Done. Writing tdruntimenv1 partition... Done. Writing tdruntimenv2 partition... Done. Writing PARAM partition... Done. Writing efs partition... Done. Writing prodnv partition... Done. Writing RESERVED2 partition... Done. Writing KERNEL partition... Done. Writing RECOVERY partition... Done. Writing PERSISTENT partition... Done. Writing persdata partition... Done. Smart Repair is successfully complete. SW: 1.7.1; FW: 1.24. Last edited by Medusa Box; 12-27-2018 at 13:46. |
The Following User Says Thank You to shahinbangla For This Useful Post: |
