05-13-2018, 15:26 | #1 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Earth
Member: 1766494 Status: Offline Sonork: 100.1649672 Thanks Meter: 325 | Samsung SM-J210F eMMC pinout notice [Answered] Code: please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J210F SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J210F_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Im trying to connect a J210F but it seems pinout of medusa pro help wrong. CLK is on GND, i guess. may be my wrong. please check. Last edited by Medusa Box; 05-15-2018 at 13:02. |
05-15-2018, 13:02 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hi. Thanks for your notice, we will fix pinout picture in SRF in next Software update. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
08-08-2018, 16:45 | #6 (permalink) | |
No Life Poster Join Date: Apr 2014 Location: B A N G L A D E S H
Member: 2171294 Status: Offline Sonork: 100.1659207(No More Use) Thanks Meter: 706 | Always showing error.. Quote:
08-09-2018, 04:27 | #7 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | We will check pinout and write You here the result. |
08-09-2018, 14:08 | #9 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | We have tested pinout from SFR - it is correct and device connected without any problems: Here is connection log: Code: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC Q313BB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 1501005133313342420004E1ECD3A351 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : Q313BB Product revision : 0.0 Product serial number : (hex) 4E1ECD3 Manufacturing date : 10/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 671744 Number of sectors : 4603904 Device Manufacturer :samsung Device Platform :sc8830 Build ID :MMB29Q Display Build ID :MMB29Q.J210FXXU0APF4 Release ID :6.0.1 Device Model :SM-J210F Device Name :j2xltedd Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :j2xltedd-user 6.0.1 MMB29Q J210FXXU0APF4 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/Q313BB_13_08_2018_12_30_55.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.5; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: SBOOT (00002000, 00001000) 2048 KB P02: SBOOT2 (00003000, 00001000) 2048 KB P03: l_fixnv1 (00004000, 00000800) 1024 KB P04: l_fixnv2 (00004800, 00000800) 1024 KB P05: pm_sys (00005000, 00000800) 1024 KB P06: rsvdfixnv1 (00005800, 00000800) 1024 KB P07: l_ldsp (00006000, 00002000) 4 MB P08: l_modem (00008000, 00008000) 16 MB P09: l_gdsp (00010000, 00002000) 4 MB P10: l_warm (00012000, 00002000) 4 MB P11: FOTA_SIG (00014000, 00000800) 1024 KB P12: l_runtimenv1 (00014800, 00000800) 1024 KB P13: l_runtimenv2 (00015000, 00000800) 1024 KB P14: td_runtimenv1 (00015800, 00000800) 1024 KB P15: td_runtimenv2 (00016000, 00000800) 1024 KB P16: PARAM (00016800, 00001000) 2048 KB P17: efs (00017800, 0000A000) 20 MB P18: prodnv (00021800, 00002800) 5 MB P19: RESERVED2 (00024000, 00003000) 6 MB P20: KERNEL (00027000, 0000A000) 20 MB P21: RECOVERY (00031000, 0000A000) 20 MB P22: PERSISTENT (0003B000, 00000800) 1024 KB P23: PERSDATA (0003B800, 00004800) 9 MB P24: CACHE (00040000, 00064000) 200 MB P25: SYSTEM (000A4000, 00464000) 2248 MB P26: HIDDEN (00508000, 00014000) 40 MB P27: userdata (0051C000, 01838000) 12.11 GB Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J210F SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J210F_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC Q313BB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 1501005133313342420004E1ECD3A351 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : Q313BB Product revision : 0.0 Product serial number : (hex) 4E1ECD3 Manufacturing date : 10/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 671744 Number of sectors : 4603904 Device Manufacturer :samsung Device Platform :sc8830 Build ID :MMB29Q Display Build ID :MMB29Q.J210FXXU0APF4 Release ID :6.0.1 Device Model :SM-J210F Device Name :j2xltedd Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :j2xltedd-user 6.0.1 MMB29Q J210FXXU0APF4 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/Q313BB_13_08_2018_12_31_20.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.5; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: SBOOT (00002000, 00001000) 2048 KB P02: SBOOT2 (00003000, 00001000) 2048 KB P03: l_fixnv1 (00004000, 00000800) 1024 KB P04: l_fixnv2 (00004800, 00000800) 1024 KB P05: pm_sys (00005000, 00000800) 1024 KB P06: rsvdfixnv1 (00005800, 00000800) 1024 KB P07: l_ldsp (00006000, 00002000) 4 MB P08: l_modem (00008000, 00008000) 16 MB P09: l_gdsp (00010000, 00002000) 4 MB P10: l_warm (00012000, 00002000) 4 MB P11: FOTA_SIG (00014000, 00000800) 1024 KB P12: l_runtimenv1 (00014800, 00000800) 1024 KB P13: l_runtimenv2 (00015000, 00000800) 1024 KB P14: td_runtimenv1 (00015800, 00000800) 1024 KB P15: td_runtimenv2 (00016000, 00000800) 1024 KB P16: PARAM (00016800, 00001000) 2048 KB P17: efs (00017800, 0000A000) 20 MB P18: prodnv (00021800, 00002800) 5 MB P19: RESERVED2 (00024000, 00003000) 6 MB P20: KERNEL (00027000, 0000A000) 20 MB P21: RECOVERY (00031000, 0000A000) 20 MB P22: PERSISTENT (0003B000, 00000800) 1024 KB P23: PERSDATA (0003B800, 00004800) 9 MB P24: CACHE (00040000, 00064000) 200 MB P25: SYSTEM (000A4000, 00464000) 2248 MB P26: HIDDEN (00508000, 00014000) 40 MB P27: userdata (0051C000, 01838000) 12.11 GB Last edited by Medusa Box; 08-13-2018 at 10:37. |
08-14-2018, 17:13 | #10 (permalink) |
Member: 2171294 Status: Offline Sonork: 100.1659207(No More Use) Thanks Meter: 706 | you sucess with old Hardware eMMc.. Now there are New Hardware J210F availble at market... PS. I am not spamer (i am old user of octopus & Medusa) So , Post Delete (Not Solution) |
08-14-2018, 18:58 | #11 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | eMMC pinout is correct and should be the same for new and old revision. What is the difference in PCB of new and old revision? Are there any differences on your device PCB and on PCB on the pinout picture? Make photos in high quality of each wire, which You have soldered and post here, we will check, whether You have soldered all wires correctly. Note, You should make each wire as short as possible. Also check shorts on PCB. |
