06-25-2018, 19:01 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Ukraine Age: 44
Member: 75408 Status: Offline Thanks Meter: 1,190 | Samsung SM-N7100 Writing eMMC firmware successfully done Code: Welcome to Medusa Pro Software version 1.6.2. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Reader #2: FT SCR2000 1 Reader #3: Gemalto e-gate Smart Card 0 Reader #4: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : GT-N7100 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-N7100_EMMC_VTU00M.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC VTU00M Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 15010056545530304DF13A44097E9FD9 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : VTU00M Full name : KMVTU000LM-B503 Product revision : 15.1 Product serial number : (hex) 3A44097E Manufacturing date : 09/2012 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFFF8E40406D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7659520 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 3129344 Number of sectors : 4194304 Device Manufacturer :samsung Device Platform :exynos4 Build ID :KOT49H Display Build ID :KOT49H.N7100XXUFNJ1 Release ID :4.4.2 Device Model :GT-N7100 Device Name :t03gxx Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Build Description :t03gxx-user 4.4.2 KOT49H N7100XXUFNJ1 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/VTU00M_25_06_2018_20_14_29.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.2; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: BOTA0 (00002000, 00002000) 4 MB P02: BOTA1 (00004000, 00002000) 4 MB P03: EFS (00006000, 0000A000) 20 MB P04: m9kefs1 (00010000, 00002000) 4 MB P05: m9kefs2 (00012000, 00002000) 4 MB P06: m9kefs3 (00014000, 00002000) 4 MB P07: PARAM (00016000, 00004000) 8 MB P08: BOOT (0001A000, 00004000) 8 MB P09: RECOVERY (0001E000, 00004000) 8 MB P10: RADIO (00022000, 0002C000) 88 MB P11: TOMBSTONES (0004E000, 00002000) 4 MB P12: CACHE (00050000, 002AC000) 1368 MB P13: SYSTEM (002FC000, 00400000) 2048 MB P14: HIDDEN (006FC000, 00118000) 560 MB P15: OTA (00814000, 00004000) 8 MB P16: USERDATA (00818000, 01540000) 10.62 GB Writing eMMC firmware from file: C:/Program Files/Medusa Pro Software/EMMC_firmwares/KMVTU000LM-B503/KMVTU000LM-B503_FW.bin...Done. Finalizing...Done. Changing CID to 15010056545530304DF780F6213A2123. Write CID succesfully completed. Disconnected. EMMC writing firmware Done. SW: 1.6.2; FW: 1.24. Code: Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : GT-N7100 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-N7100_EMMC_VTU00M.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC VTU00M Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 15010056545530304DF780F6213A2123 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : VTU00M Full name : KMVTU000LM-B503 Product revision : 15.7 Product serial number : (hex) 80F6213A Manufacturing date : 02/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFFF8E40406D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7659520 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/VTU00M_25_06_2018_20_20_57.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.2; FW: 1.24. Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-N7100_EMMC_VTU00M.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to user area. Writing GPT partition... Done. Writing BOTA0 partition... Done. Writing BOTA1 partition... Done. Writing EFS partition... Done. Writing m9kefs1 partition... Done. Writing m9kefs2 partition... Done. Writing m9kefs3 partition... Done. Writing PARAM partition... Done. Writing BOOT partition... Done. Writing RECOVERY partition... Done. Smart Repair is successfully complete. SW: 1.6.2; FW: 1.24. Disconnected. Code: Model Settings: Interface : eMMC Brand : Samsung Model : GT-N7100 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-N7100_EMMC_VTU00M.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC VTU00M Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 15010056545530304DF780F6213A2123 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : VTU00M Full name : KMVTU000LM-B503 Product revision : 15.7 Product serial number : (hex) 80F6213A Manufacturing date : 02/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFFF8E40406D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7659520 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/VTU00M_25_06_2018_20_30_04.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.2; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: BOTA0 (00002000, 00002000) 4 MB P02: BOTA1 (00004000, 00002000) 4 MB P03: EFS (00006000, 0000A000) 20 MB P04: m9kefs1 (00010000, 00002000) 4 MB P05: m9kefs2 (00012000, 00002000) 4 MB P06: m9kefs3 (00014000, 00002000) 4 MB P07: PARAM (00016000, 00004000) 8 MB P08: BOOT (0001A000, 00004000) 8 MB P09: RECOVERY (0001E000, 00004000) 8 MB P10: RADIO (00022000, 0002C000) 88 MB P11: TOMBSTONES (0004E000, 00002000) 4 MB P12: CACHE (00050000, 002AC000) 1368 MB P13: SYSTEM (002FC000, 00400000) 2048 MB P14: HIDDEN (006FC000, 00118000) 560 MB P15: OTA (00814000, 00004000) 8 MB P16: USERDATA (00818000, 01540000) 10.62 GB Selected pit file: C:/1/n7100/T03G_EUR_OPEN.pit Selected pit file: C:/1/n7100/T03G_EUR_OPEN.pit Open file "C:/1/n7100/CSC_OXE_N7100OXEFNE1_1552758_REV04_user_low_ship.tar.md5". Open file "C:/1/n7100/CP_N7100XXUFND3_REV08_CL1477145.tar.md5". Open file "C:/1/n7100/BL_N7100XXUFNE1_1552758_REV04_user_low_ship.tar.md5". Open file "C:/1/n7100/AP_N7100XXUFNE1_1552758_REV04_user_low_ship.tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition BOOTLOADER... Done. Writing partition TZSW... Done. Switched to user area. Writing partition PARAM... Done. Writing partition BOOT... Done. Writing partition RECOVERY... Done. Writing partition RADIO... Done. Writing partition CACHE... Done. Writing partition SYSTEM... Done. Writing partition HIDDEN... Done. Writing is finished. SW: 1.6.2; FW: 1.24. Last edited by Medusa Box; 06-26-2018 at 05:06. |
The Following 2 Users Say Thank You to Dr_Wolodya For This Useful Post: |
