06-24-2018, 09:54 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: JSR, BD
Member: 310155 Status: Offline Thanks Meter: 1,313 | KMR820001M-B609 BGA -211 need recover content [Answered] Welcome to Medusa Pro Software version 1.6.2. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC R821MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100523832314D42007A15D0775225 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : R821MB Product revision : 0.0 Product serial number : (hex) 7A15D077 Manufacturing date : 05/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF9240606D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : YES TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 5087232 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/R821MB_24_06_2018_14_49_43.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.2; FW: 1.24. Opening C:/Program Files/Medusa Pro Software/Samsung eMMC R821MB_24_06_2018_14_49_45.bin file... Reading. Please wait... ERROR[011]: Read error. At sector 22504 Attempting to read... Disconnected. ------------------------------------------------------- Now search content but no content found................. how fixed this ???? Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. #red Model Settings:#blue Interface : eMMC #greenVoltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... #blueDevice : Samsung eMMC R821MB #greenPage size : 512 B #greenBlock size : 512 B #greenBlock count : 30535680 #greenSize : 14.56 GB (14910.00 MB) #green--------------------------------------------------------------- CID Info #blueCID : 150100523832314D42007A15D0775225 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : R821MB Product revision : 0.0 Product serial number : (hex) 7A15D077 Manufacturing date : 05/2015 --------------------------------------------------------------- CSD Info #blueCSD : D02701320F5903FFF6DBFFEF9240606D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : YES TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info #blueRevision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes #greenBoot1 size : 4096 Kbytes #greenBoot2 size : 4096 Kbytes #greenRPMB size : 4096 Kbytes #green Partition config : (0x48) 01001000 #greenBoot partition enable : Boot partition 1 #green(Bus width = 1Bit) #blueBoot ACK : Boot acknowledge sent during boot operation Bit #green Boot bus conditions : (0x00) 00000000 #greenBoot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) #greenReset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) #greenBoot mode : Use single data rate + backward compatible timings in boot operation (default) #green RST_n function : (0x01) RST_n signal is permanently enabled #green Partitioning support : Device supports partitioning features #greenEnhanced attribute : Device can have enhanced technological features in partitions and user data area. #greenMax enhanced data size: 5087232 Kbytes #greenPartitions attribute : 0x0 #greenPart setting completed: 0x0 #greenGP partition 1 size : 0 b #greenGP partition 2 size : 0 b #greenGP partition 3 size : 0 b #greenGP partition 4 size : 0 b #greenEnhanced area size : (0x0) 0 b #greenEnhanced area start : (0x0) 0 b #green ---------------------------------------------------------------Searching Android build info... Not found#red --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/R821MB_24_06_2018_14_49_43.bin. Connect successful. #green--------------------------------------------------------------- SW: 1.6.2; FW: 1.24. #blueWhole proccess time: . Opening C:/Program Files/Medusa Pro Software/Samsung eMMC R821MB_24_06_2018_14_49_45.bin file... Reading. Please wait... #blue ERROR[011]: Read error. #redAt sector 22504 Attempting to read... Disconnected. #red Please disconnect battery and USB cable. #red Model Settings:#blue Interface : eMMC #greenVoltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... #blueDevice : Samsung eMMC R821MB #greenPage size : 512 B #greenBlock size : 512 B #greenBlock count : 30535680 #greenSize : 14.56 GB (14910.00 MB) #green--------------------------------------------------------------- CID Info #blueCID : 150100523832314D42007A15D0775225 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : R821MB Product revision : 0.0 Product serial number : (hex) 7A15D077 Manufacturing date : 05/2015 --------------------------------------------------------------- CSD Info #blueCSD : D02701320F5903FFF6DBFFEF9240606D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : YES TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info #blueRevision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes #greenBoot1 size : 4096 Kbytes #greenBoot2 size : 4096 Kbytes #greenRPMB size : 4096 Kbytes #green Partition config : (0x48) 01001000 #greenBoot partition enable : Boot partition 1 #green(Bus width = 1Bit) #blueBoot ACK : Boot acknowledge sent during boot operation Bit #green Boot bus conditions : (0x00) 00000000 #greenBoot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) #greenReset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) #greenBoot mode : Use single data rate + backward compatible timings in boot operation (default) #green RST_n function : (0x01) RST_n signal is permanently enabled #green Partitioning support : Device supports partitioning features #greenEnhanced attribute : Device can have enhanced technological features in partitions and user data area. #greenMax enhanced data size: 5087232 Kbytes #greenPartitions attribute : 0x0 #greenPart setting completed: 0x0 #greenGP partition 1 size : 0 b #greenGP partition 2 size : 0 b #greenGP partition 3 size : 0 b #greenGP partition 4 size : 0 b #greenEnhanced area size : (0x0) 0 b #greenEnhanced area start : (0x0) 0 b #green ---------------------------------------------------------------Searching Android build info... Not found#red --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/R821MB_24_06_2018_14_50_32.bin. Connect successful. #green--------------------------------------------------------------- SW: 1.6.2; FW: 1.24. #blueWhole proccess time: . Parsing device... Image size in bytes: 2749366272 Warning: Unknown file system type. Details: Sector offset: 0 Parse finished. Whole proccess time: 1 seconds : 0 ms. Parsing contacts........done. No contacts found. Parsing SMSs........done. No SMS info found. Last edited by Medusa Box; 06-24-2018 at 10:01. |
06-24-2018, 10:01 | #2 (permalink) | |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | As You can see from Software log: Quote:
The Following User Says Thank You to Medusa Box For This Useful Post: |
06-25-2018, 09:40 | #3 (permalink) | |
Member: 310155 Status: Offline Thanks Meter: 1,313 | Quote:
what about read full dump ?? Reading. Please wait... ERROR[011]: Read error. At sector 22504 Attempting to read... Disconnected. -------------- | |
06-25-2018, 09:59 | #4 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Try to set higher Voltage level (try 2.0V-2.4V) and different Bus Speed values and repeat the operation again. If the the same error will still arrise while reading data, probably eMMC has HW problems. |
