04-29-2018, 13:21 | #1 (permalink) |
Junior Member Join Date: Feb 2011
Member: 1507732 Status: Offline Thanks Meter: 36 | Samsung SM-J510F "Dead" Boot Repair Done 100% successfully Open file "D:/Samsung/J510FXXU2BRA2_J510FOJV2BRA2_3/J510FXXU2BRA2_J510FOJV2BRA2_J510FXXU2BQK1_HOME.tar .md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Writing partition APNHLOS... Done. Writing partition MODEM... Done. Writing partition SBL1... Done. Writing partition ABOOT... Done. Writing partition RPM... Done. Writing partition QSEE... Done. Writing partition QHEE... Done. Writing partition BOOT... Done. Writing partition RECOVERY... Done. Writing partition SYSTEM... Done. Writing partition CACHE... Done. Writing partition HIDDEN... Done. Writing is finished. SW: 1.5.8; FW: 1.23. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Huawei Model : ALE-L21 SRF : C:/Program Files/Octoplus Pro JTAG Software/firmwareFolder/HUAWEI_ALE-L21_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC Q313MB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 150100513331334D420097ADA67173B7 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : Q313MB Product revision : 0.0 Product serial number : (hex) 97ADA671 Manufacturing date : 07/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 393216 Number of sectors : 6144000 Device Manufacturer :samsung Device Platform :msm8916 Build ID :NMF26X Display Build ID :NMF26X.J510FXXU2BRA2 Release ID :7.1.1 Device Model :SM-J510F Device Name :j5xnltejv Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :j5xnltejv-user 7.1.1 NMF26X J510FXXU2BRA2 release-keys Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/Q313MB_29_04_2018_17_14_02.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.8; FW: 1.23. P00: GPT (00000000, 00002000) 4 MB P01: apnhlos (00002000, 00007800) 15 MB P02: modem (00009800, 0001C980) 57.19 MB P03: sbl1 (00026180, 00000400) 512 KB P04: ddr (00026580, 00000040) 32 KB P05: aboot (000265C0, 00001000) 2048 KB P06: rpm (000275C0, 00000400) 512 KB P07: qsee (000279C0, 00000600) 768 KB P08: qhee (00027FC0, 00000400) 512 KB P09: fsg (000283C0, 00001800) 3072 KB P10: sec (00029BC0, 00000020) 16 KB P11: pad (00029BE0, 00005420) 10.52 MB P12: param (0002F000, 00005000) 10 MB P13: efs (00034000, 00007000) 14 MB P14: modemst1 (0003B000, 00001800) 3072 KB P15: modemst2 (0003C800, 00001800) 3072 KB P16: boot (0003E000, 00006800) 13 MB P17: recovery (00044800, 00007800) 15 MB P18: fota (0004C000, 00005FFA) 12 MB P19: backup (00051FFA, 000037EE) 6.991 MB P20: fsc (000557E8, 00001800) 3072 KB P21: ssd (00056FE8, 00000010) 8 KB P22: persist (00056FF8, 00004000) 8 MB P23: persistent (0005AFF8, 00000800) 1024 KB P24: persdata (0005B7F8, 00004808) 9.004 MB P25: system (00060000, 005DC000) 3000 MB P26: cache (0063C000, 00064000) 200 MB P27: hidden (006A0000, 0001E000) 60 MB P28: userdata (006BE000, 0169A000) 11.3 GB Last edited by Medusa Box; 04-30-2018 at 08:30. |
The Following 7 Users Say Thank You to /\/\@ster For This Useful Post: |
05-12-2018, 18:13 | #3 (permalink) |
Freak Poster Join Date: Jan 2014 Location: karachi
Member: 2117616 Status: Offline Sonork: 100.1652203 Thanks Meter: 71 | hi i need j510 piout plz upload image hi i need j510f pinout plz upload image i have j510f after flash dead no detect pc |
The Following User Says Thank You to sheraz raza For This Useful Post: |
05-13-2018, 09:08 | #4 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Hello. If You have experience in soldering, You can remove eMMC chip from PCB for repairing (programming), solder necessary wires directly to eMMC chip contacts (or use proper eMMC adapter for direct connection), do repair and then solder eMMC chip back to device's PCB. Unfortunately, at the moment we don't have eMMC ISP pinout for this device. Maybe someone have and upload it here for You. Also look here: http://forum.gsmhosting.com/vbb/f664...wered-2390937/. |
06-20-2018, 06:56 | #6 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Hello. Please read post above: to repair this device You need to remove eMMC chip from PCB, solder necessary wires directly to eMMC chip contacts (or use proper eMMC adapter for direct connection), do "Factory Repair" ("Factory repair" tab in Software) using proper PIT file and the latest proper original Samsung firmware for this device model (in "*.tar" format) and then solder eMMC chip back to device's PCB. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
06-20-2018, 09:14 | #10 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | As You can see from your photo, this is BGA 221 eMMC type package. Pinout You can look here: https://mega.nz/#!X84n0DjL!O7pzg2Dap...yR0hdwmCoy4AkY. Also, look these: https://i.imgur.com/AEHKliA.jpg, https://drive.google.com/open?id=12i...gicQBPGddEcu2F. |
The Following 3 Users Say Thank You to Medusa Box For This Useful Post: |
06-21-2018, 16:57 | #15 (permalink) |
Freak Poster Join Date: Feb 2006 Location: B D S Age: 40
Member: 237628 Status: Offline Sonork: 100.1668254 Thanks Meter: 140 | samsung j510f look at this photo i mean cap where i connect this plz hlp |
The Following User Says Thank You to ss.com For This Useful Post: |
