03-08-2018, 10:56 | #1 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Samsung SM-J510F Direct EMMC Pinouts Needed [Answered] i have removed the emmc chip . direct pinouts needed ... Thanks Last edited by Medusa Box; 03-08-2018 at 11:21. |
The Following User Says Thank You to Aamir_Zia For This Useful Post: |
03-08-2018, 11:21 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,395 | Hello. Please make photo of eMMC chip (contacts side) and post it here, we will check and try to help You with pinout. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
03-08-2018, 13:40 | #6 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,395 | Do You mean eMMC settings for connection or what? As usually: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto |
03-08-2018, 17:59 | #10 (permalink) |
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | also tried your pinouts . FAILS to connect it .. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Model Settings: Interface : eMMC Voltage : 3.3V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. |
05-24-2018, 20:17 | #14 (permalink) |
No Life Poster Join Date: Jul 2007 Location: My Computer
Member: 553178 Status: Offline Sonork: 100.1592454 Thanks Meter: 957 | Hello to all, these all pinouts are correct accept GND. I will try to give corrected picture but not have this time. Remove spaces after youtu. Last edited by Octopus box; 05-25-2018 at 04:38. |
06-30-2018, 09:05 | #15 (permalink) |
No Life Poster Join Date: Apr 2006 Location: APPLE i Center Age: 39
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | FULL FILES WRITTEN WITH THE HELP OF THE FOLLOWING ATTACH PIC PINOUTS.... Code: Welcome to Medusa Pro Software version 1.5.4. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC Q313BB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 15010051333133424200C5AEEE9AC34F Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : Q313BB Product revision : 0.0 Product serial number : (hex) C5AEEE9A Manufacturing date : 12/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file D:/Backup Data/TORNADO/TOOL_BOXs/MEDUSA/MEDUSA PRO/EXT_CSD Backups/Q313BB_30_06_2018_12_34_59.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.4; FW: 1.23. Remove write protect successfully completed. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC Q313BB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 15010051333133424200C5AEEE9AC34F Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : Q313BB Product revision : 0.0 Product serial number : (hex) C5AEEE9A Manufacturing date : 12/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file D:/Backup Data/TORNADO/TOOL_BOXs/MEDUSA/MEDUSA PRO/EXT_CSD Backups/Q313BB_30_06_2018_12_35_20.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.4; FW: 1.23. EXT_CSD saved to file C:/Users/faisa/Desktop/EXT_CSD_30_06_2018_12_35_38.bin. Boot config succesfully changed! Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC Q313BB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 15010051333133424200C5AEEE9AC34F Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : Q313BB Product revision : 0.0 Product serial number : (hex) C5AEEE9A Manufacturing date : 12/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file D:/Backup Data/TORNADO/TOOL_BOXs/MEDUSA/MEDUSA PRO/EXT_CSD Backups/Q313BB_30_06_2018_12_36_15.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.4; FW: 1.23. Selected pit file: C:/Users/faisa/Desktop/XSG-J510FXXU2BRB2-20180309135532/SM-J510F_4-11-2017_14-4-51.pit Open file "C:/Users/faisa/Desktop/XSG-J510FXXU2BRB2-20180309135532/J510FXXU2BRB2_J510FOJV2BRB2_J510FXXU2BQK1_HOME.tar". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Writing partition APNHLOS... Done. Writing partition MODEM... Done. Writing partition SBL1... Done. Writing partition ABOOT... Done. Writing partition RPM... Done. Writing partition QSEE... Done. Writing partition QHEE... Done. Writing partition BOOT... Done. Writing partition RECOVERY... Done. Writing partition SYSTEM... Done. Writing partition CACHE... Done. Writing partition HIDDEN... Done. Writing is finished. SW: 1.5.4; FW: 1.23. |
