08-10-2018, 18:23 | #1 (permalink) |
Freak Poster Join Date: Feb 2011 Location: Santa Cruz - Bolivia
Member: 1522403 Status: Offline Thanks Meter: 55 | Samsung SM-J510MN repair boot successfully done by Medusa Pro Welcome to Medusa Pro Software version 1.6.5. Started. Reader #0: Gemalto e-gate Smart Card 0 Reader #1: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC Q313BB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 1501005133313342420044F7DED7B3BB Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : Q313BB Product revision : 0.0 Product serial number : (hex) 44F7DED7 Manufacturing date : 11/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 393216 Number of sectors : 6144000 Device Manufacturer :samsung Device Platform :msm8916 Build ID :NMF26X Display Build ID :NMF26X.J510MNUBU2BQL2 Release ID :7.1.1 Device Model :SM-J510MN Device Name :j5xnlteub Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :j5xnlteub-user 7.1.1 NMF26X J510MNUBU2BQL2 release-keys Backup EXT_CSD saved to file D:/Archivos de programas/GsmServer/Medusa Pro Software/EXT_CSD Backups/Q313BB_10_08_2018_11_45_47.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.5; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: apnhlos (00002000, 00007800) 15 MB P02: modem (00009800, 0001C980) 57.19 MB P03: sbl1 (00026180, 00000400) 512 KB P04: ddr (00026580, 00000040) 32 KB P05: aboot (000265C0, 00001000) 2048 KB P06: rpm (000275C0, 00000400) 512 KB P07: qsee (000279C0, 00000600) 768 KB P08: qhee (00027FC0, 00000400) 512 KB P09: fsg (000283C0, 00001800) 3072 KB P10: sec (00029BC0, 00000020) 16 KB P11: pad (00029BE0, 00005420) 10.52 MB P12: param (0002F000, 00005000) 10 MB P13: efs (00034000, 00007000) 14 MB P14: modemst1 (0003B000, 00001800) 3072 KB P15: modemst2 (0003C800, 00001800) 3072 KB P16: boot (0003E000, 00006800) 13 MB P17: recovery (00044800, 00007800) 15 MB P18: fota (0004C000, 00005FFA) 12 MB P19: backup (00051FFA, 000037EE) 6.991 MB P20: fsc (000557E8, 00001800) 3072 KB P21: ssd (00056FE8, 00000010) 8 KB P22: persist (00056FF8, 00004000) 8 MB P23: persistent (0005AFF8, 00000800) 1024 KB P24: persdata (0005B7F8, 00004808) 9.004 MB P25: system (00060000, 005DC000) 3000 MB P26: cache (0063C000, 00064000) 200 MB P27: hidden (006A0000, 0001E000) 60 MB P28: userdata (006BE000, 0169BFD8) 11.3 GB Selected pit file: D:/SOFTWARE CELL/Samsung/Firmware/NsPRO/J510MN/J5XNLTE_EUR_OPEN.pit Open file "D:/SOFTWARE CELL/Samsung/Firmware/NsPRO/J510MN/J510MNUBU2BQL2_J510MNUUB2BRA1_J510MNUBU2BQK6_HOME. tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Writing partition APNHLOS... Done. Writing partition MODEM... Done. Writing partition SBL1... Done. Writing partition ABOOT... Done. Writing partition RPM... Done. Writing partition QSEE... Done. Writing partition QHEE... Done. Writing partition BOOT... Done. Writing partition RECOVERY... Done. Writing partition CACHE... Done. Writing partition HIDDEN... Done. Writing is finished. SW: 1.6.5; FW: 1.24. Disconnected. Last edited by Medusa Box; 08-11-2018 at 10:39. |
The Following 4 Users Say Thank You to UBunlock For This Useful Post: |
