12-30-2017, 12:06 | #1 (permalink) |
Freak Poster Join Date: May 2016 Location: India,Odisha Age: 27
Member: 2573604 Status: Offline Thanks Meter: 30 | samsung SM-J700F boot repair problem [Answered] Model Settings: Interface : eMMC Brand : Samsung Model : SM-J700F SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J700F_EMMC_400073.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 400073 Page size : 512 B Block size : 512 B Block count : 2097152 Size : 1024.00 MB --------------------------------------------------------------- CID Info CID : 1101003430303037330089814FA2A2F3 Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 400073 Product revision : 0.0 Product serial number : (hex) 89814FA2 Manufacturing date : 10/2015 --------------------------------------------------------------- CSD Info CSD : D07E00320F5903FFFFFFFFE78A4000D1 CSD structure : CSD version No. 1.0 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 8 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Erase block size : 33280 Kbytes Boot1 size : 15232 Kbytes Boot2 size : 15232 Kbytes RPMB size : 0 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Max enhanced data size: 0 Kbytes Partitions attribute : 0x20 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/400073_30_12_2017_16_33_17.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.0; FW: 1.22. Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J700F_EMMC_400073.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Write verification error 1. Possible reasons: damaged or write protected eMMC. Disconnected. Last edited by Medusa Box; 12-30-2017 at 12:33. |
12-30-2017, 12:32 | #2 (permalink) | ||
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. As You can see from your Software log, You have not connected the device correctly or eMMC has HW problems - eMMC size (capacity) can't be 1024.00 MB: Quote:
Don't forget to use pull-up resistors, mentioned at eMMC pinout picture. When the device will be corrected correctly, You can perform repair operation. | ||
