05-07-2019, 23:24 | #1 (permalink) |
Freak Poster Join Date: Sep 2006 Location: TRIPOLI
Member: 342175 Status: Offline Thanks Meter: 5 | Samsung SM-J701f issue during Read [Answered] Interface : eMMC Brand : Samsung Model : SM-J701M SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J701M_EMMC.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC AJTD4R Page size : 512 B Block size : 512 B Block count : 20967427 Size : 10.00 GB (10238.00 MB) --------------------------------------------------------------- CID Info CID : 150100414A5444345200CD83B408150D Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : AJTD4R Product revision : 0.0 Product serial number : (hex) CD83B408 Manufacturing date : 01/2018 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Erase block size : 98304 Kbytes Boot1 size : 1920 Kbytes Boot2 size : 1920 Kbytes RPMB size : 1920 Kbytes Partition config : (0x3F) 00111111 Boot partition enable : User area Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x07) 00000111 Boot bus width : Reset boot bus conditions : Retain BOOT_BUS_WIDTH and BOOT_MODE values after boot operation Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x03) Partitioning support : Device supports partitioning features Max enhanced data size: 1434550272 Kbytes Partitions attribute : 0x3F Part setting completed: 0xF0 GP partition 1 size : 1024 MB GP partition 2 size : 1024 MB GP partition 3 size : 2560 MB GP partition 4 size : 2560 MB Enhanced area size : (0x80000000) 2048 MB Enhanced area start : (0xFF801E00) 4088 MB Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/AJTD4R_08_05_2019_00_22_53.bin. Connect successful. |
05-07-2019, 23:33 | #2 (permalink) |
Member: 342175 Status: Offline Thanks Meter: 5 | SW: 1.7.6; FW: 1.24. Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J701M_EMMC.srf". Write data verification is disabled. Switch error!!! Writing BOOT1 partition... ERROR[012]: Write error. At sector 0 Attempting to write... Done. Switch error!!! Writing BOOT2 partition... ERROR[012]: Write error. At sector 0 Attempting to write... Disconnected. |
05-08-2019, 08:01 | #3 (permalink) | |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Hello. Quote:
P.S Try to use forum search, before create threads | |
The Following User Says Thank You to Medusa Box For This Useful Post: |
09-28-2019, 08:01 | #5 (permalink) |
No Life Poster Join Date: Dec 2009 Location: Laghouat, Algeria Age: 30
Member: 1191316 Status: Offline Thanks Meter: 900 | you've problem on eMMC Code: Device : Samsung eMMC AJTD4R Page size : 512 B Block size : 512 B Block count : 20967427 Size : 10.00 GB (10238.00 MB) Code: Erase block size : 98304 Kbytes Boot1 size : 1920 Kbytes Boot2 size : 1920 Kbytes RPMB size : 1920 Kbytes try to highlight voltage max 2.8v |
The Following User Says Thank You to starkrimes For This Useful Post: |
