Member: 2784835
Thanks Meter: 61 | Samsung SM-N7505 Dead Boot Repair Done Factory Files Write Done Quote: Model Settings: Interface : eMMC
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : Auto Connecting...
Device : Toshiba eMMC 016GE2
Page size : 512 B
Block size : 512 B
Block count : 30777344
Size : 14.68 GB (15028.00 MB)
--------------------------------------------------------------- CID Info
CID : 110100303136474532046599445F1177
Manufacturer ID : 0X11
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : 016GE2
Product revision : 0.4
Product serial number : (hex) 6599445F
Manufacturing date : 01/2014
--------------------------------------------------------------- CSD Info
CSD : D05E00320F5903FFFFFFFFEF924000D3
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 5 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
--------------------------------------------------------------- EXTCSD Info
Revision 1.7 (for MMC v5.0, v5.01)
Erase block size : 4096 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 4096 Kbytes
Partition config : (0x48) 01001000
Boot partition enable : Boot partition 1 (Bus width = 4Bit)
Boot ACK : Boot acknowledge sent during boot operation Bit
Boot bus conditions : (0x01) 00000001
Boot bus width : x4 (sdr/ddr) bus width in boot operation mode
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x00) RST_n signal is temporary disabled (default)
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 7700480 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/016GE2_08_08_2018_17_52_38.bin. Connect successful.
--------------------------------------------------------------- SW: 1.6.4; FW: 1.24.
P00: GPT (00000000, 00002000) 4 MB
P01: BOTA0 (00002000, 00002000) 4 MB
P02: BOTA1 (00004000, 00002000) 4 MB
P03: EFS (00006000, 0000A000) 20 MB
P04: m9kefs1 (00010000, 00002000) 4 MB
P05: m9kefs2 (00012000, 00002000) 4 MB
P06: m9kefs3 (00014000, 00002000) 4 MB
P07: CARRIER (00016000, 0000A000) 20 MB
P08: PARAM (00020000, 00004000) 8 MB
P09: BOOT (00024000, 00004000) 8 MB
P10: RECOVERY (00028000, 00004000) 8 MB
P11: OTA (0002C000, 00004000) 8 MB
P12: CDMA-RADIO (00030000, 00004000) 8 MB
P13: RADIO (00034000, 00018000) 48 MB
P14: TOMBSTONES (0004C000, 00080000) 256 MB
P15: TDATA (000CC000, 00002000) 4 MB
P16: PERSDATA (000CE000, 00006000) 12 MB
P17: RESERVED2 (000D4000, 00002000) 4 MB
P18: SYSTEM (000D6000, 00479000) 2290 MB
P19: CACHE (0054F000, 00064000) 200 MB
P20: HIDDEN (005B3000, 0000A000) 20 MB
P21: USERDATA (005BD000, 0179A000) 11.8 GB
Canceling process...
Selected pit file: I:/Flash Files/Samsung/Flash Files/N - Series/N-7505/N7505XXUCNH1_OXECNH1/N7505XXUCNH1_OXECNH1/HLLTE_EUR_OPEN_4G.pit
Open file "I:/Flash Files/Samsung/Flash Files/N - Series/N-7505/N7505XXUCNH1_OXECNH1/N7505XXUCNH1_OXECNH1/BL_N7505XXUCNH1_2244489_REV00_user_low_ship.tar.md 5".
Open file "I:/Flash Files/Samsung/Flash Files/N - Series/N-7505/N7505XXUCNH1_OXECNH1/N7505XXUCNH1_OXECNH1/AP_N7505XXUCNH1_2244489_REV00_user_low_ship.tar.md 5".
Open file "I:/Flash Files/Samsung/Flash Files/N - Series/N-7505/N7505XXUCNH1_OXECNH1/N7505XXUCNH1_OXECNH1/CP_N7505XXUCNG2_1653803_REV00_user_low_ship.tar.md 5".
Open file "I:/Flash Files/Samsung/Flash Files/N - Series/N-7505/N7505XXUCNH1_OXECNH1/N7505XXUCNH1_OXECNH1/CSC_OXE_N7505OXECNH1_2244489_REV00_user_low_ship.t ar.md5".
Writing MBR...Done.
Writing primary GPT...Done.
Writing secondary GPT...Done.
Writing PIT Write data verification is enabled.
Writing. Please wait...
Switched to boot area partition 1.
Writing partition BOOTLOADER... Done.
Switched to user area.
Writing partition PARAM... Done.
Writing partition BOOT... Done.
Writing partition RECOVERY... Done.
Writing partition RADIO... Done.
Writing partition SYSTEM... Done.
Writing partition CACHE... Done.
Writing partition HIDDEN... Done.
Writing is finished. SW: 1.6.4; FW: 1.24. Disconnected. | Pinout After SRF Creation Quote: Model Settings: Interface : eMMC
Brand : Samsung
Model : SM-N7505
SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/Samsung_SM-N7505.srf
Voltage : 2.8V
Bus Mode : 1 bit
Page size : 512 B
Block size : 512 B
TRAN speed : 26 MHz
Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/016GE2_08_08_2018_19_07_31.bin. Connect successful.
P01: bota0 (00002000, 00002000) 4 MB
P02: bota1 (00004000, 00002000) 4 MB
P03: efs (00006000, 0000A000) 20 MB
P07: carrier (00016000, 0000A000) 20 MB
P08: param (00020000, 00004000) 8 MB
P09: boot (00024000, 00004000) 8 MB
P10: recovery (00028000, 00004000) 8 MB
P11: ota (0002C000, 00004000) 8 MB
P12: cdma-radio (00030000, 00004000) 8 MB
P13: radio (00034000, 00018000) 48 MB
P14: tombstones (0004C000, 00080000) 256 MB
P15: tdata (000CC000, 00002000) 4 MB
P16: persdata (000CE000, 00006000) 12 MB
P17: reserved2 (000D4000, 00002000) 4 MB
P18: system (000D6000, 00479000) 2290 MB
P19: cache (0054F000, 00064000) 200 MB
P20: hidden (005B3000, 0000A000) 20 MB Disconnected. |
