04-23-2018, 17:39 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: algeria
Member: 242222 Status: Offline Thanks Meter: 54 | Samsung SM-T210 tablet driver question [Answered] after that the tablett t210 detected EMEI driver not instal pleas help Last edited by Medusa Box; 04-24-2018 at 04:58. |
04-24-2018, 04:58 | #2 (permalink) | ||
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Quote:
04-25-2018, 12:44 | #3 (permalink) |
Member: 242222 Status: Offline Thanks Meter: 54 | Welcome to Medusa Pro Software version 1.5.8. Started. Reader #0: AKS ifdh 0 Reader #1: AKS ifdh 1 Reader #2: AKS VR 0 Reader #3: FT SCR2000 0 Reader #4: FT SCR2000 1 Reader #5: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : T210 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_T210_THANKS_TO_MR_AGRSAT.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : T210 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_T210_THANKS_TO_MR_AGRSAT.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC 000000 Page size : 512 B Block size : 512 B Block count : 16776192 Size : 8.00 GB (8191.50 MB) --------------------------------------------------------------- CID Info CID : 1501003030303030305620110726589D Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 000000 Product revision : 5.6 Product serial number : (hex) 20110726 Manufacturing date : 05/2021 --------------------------------------------------------------- CSD Info CSD : 902701320F5903FFF6DBFFEF8A404023 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 512 Kbytes Boot2 size : 512 Kbytes RPMB size : 128 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 4026531840 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/000000_25_04_2018_12_44_17.bin. |
04-25-2018, 13:11 | #4 (permalink) | |||
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | 1. As I see eMMC name is damaged: Quote:
2. Quote:
3. Quote:
