10-09-2018, 08:37 | #1 (permalink) |
Freak Poster Join Date: Oct 2017
Member: 2773088 Status: Offline Thanks Meter: 24 | Samsung SM-T377P "dead" boot repair [Answered] Welcome to Medusa Pro Software version 1.6.4. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-T377P SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-T377P_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 400073 Page size : 512 B Block size : 512 B Block count : 2097152 Size : 1024.00 MB --------------------------------------------------------------- CID Info CID : 110100343030303733001FC744F943B1 Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 400073 Product revision : 0.0 Product serial number : (hex) 1FC744F9 Manufacturing date : 04/2016 --------------------------------------------------------------- CSD Info CSD : D07E00320F5903FFFFFFFFE78A4000D1 CSD structure : CSD version No. 1.0 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 8 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Erase block size : 2560 Kbytes Boot1 size : 28288 Kbytes Boot2 size : 28288 Kbytes RPMB size : 0 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Max enhanced data size: 0 Kbytes Partitions attribute : 0x80 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/400073_09_10_2018_10_31_37.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.4; FW: 1.24. Disconnected. Last edited by Medusa Box; 10-09-2018 at 08:47. |
10-09-2018, 08:38 | #2 (permalink) | |
Member: 2773088 Status: Offline Thanks Meter: 24 | Quote:
