12-24-2017, 09:24 | #1 (permalink) |
Freak Poster Join Date: Nov 2015 Location: pak Age: 39
Member: 2487963 Status: Offline Thanks Meter: 65 | Samsung tab SM-T377p Smart Repair done, but still show "Qualcomm...9008" [Answered] Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-T377P SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-T377P_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 400073 Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 11010034303030373300A33C2C6392FB Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 400073 Product revision : 0.0 Product serial number : (hex) A33C2C63 Manufacturing date : 09/2015 --------------------------------------------------------------- CSD Info CSD : D07E00320F5903FFFFFFFFE78A4000D1 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 8 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x16) 00010110 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Retain BOOT_BUS_WIDTH and BOOT_MODE values after boot operation Boot mode : Use dual data rate in boot operation RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7696384 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/400073_24_12_2017_13_22_11.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.0; FW: 1.22. P00: GPT (00000000, 00002000) 4 MB P01: apnhlos (00002000, 00007800) 15 MB P02: modem (00009800, 0001CB80) 57.44 MB P03: sbl1 (00026380, 00000400) 512 KB P04: ddr (00026780, 00000040) 32 KB P05: aboot (000267C0, 00001000) 2048 KB P06: rpm (000277C0, 00000400) 512 KB P07: qsee (00027BC0, 00000600) 768 KB P08: qhee (000281C0, 00000400) 512 KB P09: fsg (000285C0, 00001800) 3072 KB P10: sec (00029DC0, 00000020) 16 KB P11: pad (00029DE0, 00005220) 10.27 MB P12: param (0002F000, 00005000) 10 MB P13: efs (00034000, 00007000) 14 MB P14: modemst1 (0003B000, 00001800) 3072 KB P15: modemst2 (0003C800, 00001800) 3072 KB P16: boot (0003E000, 00006800) 13 MB P17: recovery (00044800, 00007800) 15 MB P18: fota (0004C000, 00002002) 4.001 MB P19: backup (0004E002, 000037EE) 6.991 MB P20: fsc (000517F0, 00001800) 3072 KB P21: ssd (00052FF0, 00000010) 8 KB P22: persist (00053000, 00004000) 8 MB P23: persistent (00057000, 00000800) 1024 KB P24: persdata (00057800, 00004800) 9 MB P25: system (0005C000, 004B0000) 2400 MB P26: cache (0050C000, 00064000) 200 MB P27: carrier (00570000, 00016800) 45 MB P28: userdata (00586800, 017D37D8) 11.91 GB Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-T377P_EMMC.srf". Write data verification is enabled. Writing GPT partition... Done. Writing apnhlos partition... Done. Writing modem partition... Done. Writing sbl1 partition... Done. Writing ddr partition... Done. Writing aboot partition... Done. Writing rpm partition... Done. Writing qsee partition... Done. Writing qhee partition... Done. Writing fsg partition... Done. Writing sec partition... Done. Writing pad partition... Done. Writing param partition... Done. Writing efs partition... Done. Writing boot partition... Done. Writing recovery partition... Done. Writing fota partition... Done. Writing backup partition... Done. Writing fsc partition... Done. Writing ssd partition... Done. Writing persist partition... Done. Writing persistent partition... Done. Writing persdata partition... Done. Smart Repair is successfully complete. SW: 1.5.0; FW: 1.22. Disconnected. Last edited by Octopus box; 12-24-2017 at 09:52. |
12-24-2017, 09:52 | #2 (permalink) | ||
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. As You can see from Software log: Quote:
12-24-2017, 10:23 | #3 (permalink) | |
Member: 2487963 Status: Offline Thanks Meter: 65 | Quote:
Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-T377P SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-T377P_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 400073 Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 11010034303030373300A33C2C6392FB Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 400073 Product revision : 0.0 Product serial number : (hex) A33C2C63 Manufacturing date : 09/2015 --------------------------------------------------------------- CSD Info CSD : D07E00320F5903FFFFFFFFE78A4000D1 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 8 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x16) 00010110 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Retain BOOT_BUS_WIDTH and BOOT_MODE values after boot operation Boot mode : Use dual data rate in boot operation RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7696384 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/400073_24_12_2017_13_57_17.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.0; FW: 1.22. P00: GPT (00000000, 00002000) 4 MB P01: apnhlos (00002000, 00007800) 15 MB P02: modem (00009800, 0001CB80) 57.44 MB P03: sbl1 (00026380, 00000400) 512 KB P04: ddr (00026780, 00000040) 32 KB P05: aboot (000267C0, 00001000) 2048 KB P06: rpm (000277C0, 00000400) 512 KB P07: qsee (00027BC0, 00000600) 768 KB P08: qhee (000281C0, 00000400) 512 KB P09: fsg (000285C0, 00001800) 3072 KB P10: sec (00029DC0, 00000020) 16 KB P11: pad (00029DE0, 00005220) 10.27 MB P12: param (0002F000, 00005000) 10 MB P13: efs (00034000, 00007000) 14 MB P14: modemst1 (0003B000, 00001800) 3072 KB P15: modemst2 (0003C800, 00001800) 3072 KB P16: boot (0003E000, 00006800) 13 MB P17: recovery (00044800, 00007800) 15 MB P18: fota (0004C000, 00002002) 4.001 MB P19: backup (0004E002, 000037EE) 6.991 MB P20: fsc (000517F0, 00001800) 3072 KB P21: ssd (00052FF0, 00000010) 8 KB P22: persist (00053000, 00004000) 8 MB P23: persistent (00057000, 00000800) 1024 KB P24: persdata (00057800, 00004800) 9 MB P25: system (0005C000, 004B0000) 2400 MB P26: cache (0050C000, 00064000) 200 MB P27: carrier (00570000, 00016800) 45 MB P28: userdata (00586800, 017D1800) 11.91 GB Boot config succesfully changed! Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-T377P SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-T377P_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 400073 Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 11010034303030373300A33C2C6392FB Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 400073 Product revision : 0.0 Product serial number : (hex) A33C2C63 Manufacturing date : 09/2015 --------------------------------------------------------------- CSD Info CSD : D07E00320F5903FFFFFFFFE78A4000D1 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 8 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x12) 00010010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use dual data rate in boot operation RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7696384 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/400073_24_12_2017_14_01_13.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.0; FW: 1.22. P00: GPT (00000000, 00002000) 4 MB P01: apnhlos (00002000, 00007800) 15 MB P02: modem (00009800, 0001CB80) 57.44 MB P03: sbl1 (00026380, 00000400) 512 KB P04: ddr (00026780, 00000040) 32 KB P05: aboot (000267C0, 00001000) 2048 KB P06: rpm (000277C0, 00000400) 512 KB P07: qsee (00027BC0, 00000600) 768 KB P08: qhee (000281C0, 00000400) 512 KB P09: fsg (000285C0, 00001800) 3072 KB P10: sec (00029DC0, 00000020) 16 KB P11: pad (00029DE0, 00005220) 10.27 MB P12: param (0002F000, 00005000) 10 MB P13: efs (00034000, 00007000) 14 MB P14: modemst1 (0003B000, 00001800) 3072 KB P15: modemst2 (0003C800, 00001800) 3072 KB P16: boot (0003E000, 00006800) 13 MB P17: recovery (00044800, 00007800) 15 MB P18: fota (0004C000, 00002002) 4.001 MB P19: backup (0004E002, 000037EE) 6.991 MB P20: fsc (000517F0, 00001800) 3072 KB P21: ssd (00052FF0, 00000010) 8 KB P22: persist (00053000, 00004000) 8 MB P23: persistent (00057000, 00000800) 1024 KB P24: persdata (00057800, 00004800) 9 MB P25: system (0005C000, 004B0000) 2400 MB P26: cache (0050C000, 00064000) 200 MB P27: carrier (00570000, 00016800) 45 MB P28: userdata (00586800, 017D1800) 11.91 GB Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-T377P_EMMC.srf". Write data verification is enabled. Writing GPT partition... Done. Writing apnhlos partition... Done. | |
12-24-2017, 11:17 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Have You read my previous post? At firs set proper eMMC boot config ("Partition config : 00000000" and "Boot bus conditions : 00000000"), and only then do "Smart Repair". |
12-24-2017, 13:15 | #5 (permalink) | |
Welcome to Medusa Pro Software version 1.5.0. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: Generic EMV Smartcard Reader 0 Reader #3: Generic EMV Smartcard Reader 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-T377P SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-T377P_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 400073 Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 11010034303030373300A33C2C6392FB Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 400073 Product revision : 0.0 Product serial number : (hex) A33C2C63 Manufacturing date : 09/2015 --------------------------------------------------------------- CSD Info CSD : D07E00320F5903FFFFFFFFE78A4000D1 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 8 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x50) 01010000 Boot partition enable : Boot partition 2 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x0C) 00001100 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Retain BOOT_BUS_WIDTH and BOOT_MODE values after boot operation Boot mode : Use single data rate + High Speed timings in boot operation RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7696384 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/400073_24_12_2017_17_09_34.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.0; FW: 1.22. P00: GPT (00000000, 00002000) 4 MB P01: apnhlos (00002000, 00007800) 15 MB P02: modem (00009800, 0001CB80) 57.44 MB P03: sbl1 (00026380, 00000400) 512 KB P04: ddr (00026780, 00000040) 32 KB P05: aboot (000267C0, 00001000) 2048 KB P06: rpm (000277C0, 00000400) 512 KB P07: qsee (00027BC0, 00000600) 768 KB P08: qhee (000281C0, 00000400) 512 KB P09: fsg (000285C0, 00001800) 3072 KB P10: sec (00029DC0, 00000020) 16 KB P11: pad (00029DE0, 00005220) 10.27 MB P12: param (0002F000, 00005000) 10 MB P13: efs (00034000, 00007000) 14 MB P14: modemst1 (0003B000, 00001800) 3072 KB P15: modemst2 (0003C800, 00001800) 3072 KB P16: boot (0003E000, 00006800) 13 MB P17: recovery (00044800, 00007800) 15 MB P18: fota (0004C000, 00002002) 4.001 MB P19: backup (0004E002, 000037EE) 6.991 MB P20: fsc (000517F0, 00001800) 3072 KB P21: ssd (00052FF0, 00000010) 8 KB P22: persist (00053000, 00004000) 8 MB P23: persistent (00057000, 00000800) 1024 KB P24: persdata (00057800, 00004800) 9 MB P25: system (0005C000, 004B0000) 2400 MB P26: cache (0050C000, 00064000) 200 MB P27: carrier (00570000, 00016800) 45 MB P28: userdata (00586800, 017D1800) 11.91 GB Boot config succesfully changed! Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-T377P SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-T377P_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 400073 Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 11010034303030373300A33C2C6392FB Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 400073 Product revision : 0.0 Product serial number : (hex) A33C2C63 Manufacturing date : 09/2015 --------------------------------------------------------------- CSD Info CSD : D07E00320F5903FFFFFFFFE78A4000D1 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 8 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7696384 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/400073_24_12_2017_17_11_05.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.0; FW: 1.22. P00: GPT (00000000, 00002000) 4 MB P01: apnhlos (00002000, 00007800) 15 MB P02: modem (00009800, 0001CB80) 57.44 MB P03: sbl1 (00026380, 00000400) 512 KB P04: ddr (00026780, 00000040) 32 KB P05: aboot (000267C0, 00001000) 2048 KB P06: rpm (000277C0, 00000400) 512 KB P07: qsee (00027BC0, 00000600) 768 KB P08: qhee (000281C0, 00000400) 512 KB P09: fsg (000285C0, 00001800) 3072 KB P10: sec (00029DC0, 00000020) 16 KB P11: pad (00029DE0, 00005220) 10.27 MB P12: param (0002F000, 00005000) 10 MB P13: efs (00034000, 00007000) 14 MB P14: modemst1 (0003B000, 00001800) 3072 KB P15: modemst2 (0003C800, 00001800) 3072 KB P16: boot (0003E000, 00006800) 13 MB P17: recovery (00044800, 00007800) 15 MB P18: fota (0004C000, 00002002) 4.001 MB P19: backup (0004E002, 000037EE) 6.991 MB P20: fsc (000517F0, 00001800) 3072 KB P21: ssd (00052FF0, 00000010) 8 KB P22: persist (00053000, 00004000) 8 MB P23: persistent (00057000, 00000800) 1024 KB P24: persdata (00057800, 00004800) 9 MB P25: system (0005C000, 004B0000) 2400 MB P26: cache (0050C000, 00064000) 200 MB P27: carrier (00570000, 00016800) 45 MB P28: userdata (00586800, 017D1800) 11.91 GB Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-T377P_EMMC.srf". Write data verification is enabled. Writing GPT partition... Done. Writing apnhlos partition... Done. Writing modem partition... Done. Writing sbl1 partition... Done. Writing ddr partition... Done. Writing aboot partition... Done. Writing rpm partition... Done. Writing qsee partition... Done. Writing qhee partition... Done. Writing fsg partition... Done. Writing sec partition... Done. Writing pad partition... Done. Writing param partition... Done. Writing efs partition... Done. Writing boot partition... Done. Writing recovery partition... Done. Writing fota partition... Done. Writing backup partition... Done. Writing fsc partition... Done. Writing ssd partition... Done. Writing persist partition... Done. Writing persistent partition... Done. Writing persdata partition... Done. Smart Repair is successfully complete. SW: 1.5.0; FW: 1.22. Disconnected. check sir | |
12-24-2017, 18:10 | #7 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Here can be two main reasons of this problem - device has HW issue(s) or boot loaders in SRF file that You have used for repairing, are not suitable (not compatible) with your phone (boot loaders are older (have lower version) than should be in your phone, thus the phone can't go into DM because of enabled boot downgrade protection). Try to perform "Factory Repair" operation ("Factory repair" tab in Software) using proper PIT file and the latest original Samsung firmware for this phone model. |
The Following 2 Users Say Thank You to Medusa Box For This Useful Post: |
