Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2007
Member: 567810 Status: Offline Thanks: 13
| SHV-E110s: Target device Core has disabled JTAG/EmbeddedICE Is it possible to repair? Code: Welcome to Medusa Box Software version 1.5.0.1 Selected device model: Samsung SHV-E110S Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. ERROR[034]: RTCK signal does not respond. Defaulting to 1 MHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. ERROR[032]: Target device Core has disabled JTAG/EmbeddedICE. MI: Halting target, attempt 1. MI: Halting target, attempt 2. JTAG speed : 1000 KHz. VREF level : 1.79 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 MI: Loading Medusa Device Server V1.2. MI: Failed to load. ERROR[002]: Failed to load Medusa Device Server to target RAM. Please connect the target device and power it on... MI: RTCK reaction time 189 ns, average speed 5291 KHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4F1F0F0F, IR Length = 4. Detected TAP ID: 106A10E1, IR Length = 11. MI: Halting target, attempt 1. MI: Halting target, attempt 2. JTAG speed : Auto (RTCK). VREF level : 1.79 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 MI: Loading Medusa Device Server V1.2. MI: Failed to load. ERROR[002]: Failed to load Medusa Device Server to target RAM. ERROR[034]: RTCK signal does not respond. Defaulting to 1 MHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. ERROR[032]: Target device Core has disabled JTAG/EmbeddedICE. MI: Halting target, attempt 1. MI: Halting target, attempt 2. MI: Halting target, attempt 3. JTAG speed : 1000 KHz. VREF level : 1.79 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 MI: Loading Medusa Device Server V1.2. MI: Failed to load. |
| | #3 (permalink) |
| This log - with battery and USB cable Code: Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 100 KHz. VREF level : 1.81 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[002]: Failed to load Medusa Device Server to target RAM. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 100 KHz. VREF level : 1.84 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. MI: Medusa JTAG init failed. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4F1F0F0F, IR Length = 4. Detected TAP ID: 106A10E1, IR Length = 11. ERROR[032]: Target device Core has disabled JTAG/EmbeddedICE. JTAG speed : 100 KHz. VREF level : 1.82 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. |
| | #4 (permalink) |
| This is with battery and various speed Code: Selected device model: Samsung SHV-E110S Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. MI: Medusa JTAG init failed. Please connect the target device and power it on... VREF = 0.10V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 000000E1, IR Length = 11. ERROR[016]: Selected device CPU ID mismatch. Core ID = 000000E1, expected ID = 106A10E1. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 100 KHz. VREF level : 1.81 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[002]: Failed to load Medusa Device Server to target RAM. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 100 KHz. VREF level : 1.84 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. MI: Medusa JTAG init failed. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4F1F0F0F, IR Length = 4. Detected TAP ID: 106A10E1, IR Length = 11. ERROR[032]: Target device Core has disabled JTAG/EmbeddedICE. JTAG speed : 100 KHz. VREF level : 1.82 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Selected device model: Samsung SHV-E110S Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 100 KHz. VREF level : 1.79 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[002]: Failed to load Medusa Device Server to target RAM. Please connect the target device and power it on... VREF = 0.14V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 100 KHz. VREF level : 1.79 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. ERROR[045]: Scan chain is too long or damaged. Scanned TAP ID's list: 0x4F1F0F0F 0x000010E1 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 MI: Medusa JTAG init failed. VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 100 KHz. VREF level : 1.79 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 100 KHz. VREF level : 1.80 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. ERROR[045]: Scan chain is too long or damaged. Scanned TAP ID's list: 0x4F1F0F0F 0x000010E1 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 MI: Medusa JTAG init failed. Selected device model: Samsung SHV-E110S Connecting. Please wait... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 400 KHz. VREF level : 1.79 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 400 KHz. VREF level : 1.80 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 400 KHz. VREF level : 1.80 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. ERROR[035]: Target device has been powered off during connect. Selected device model: Samsung SHV-E110S Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 400 KHz. VREF level : 1.79 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[002]: Failed to load Medusa Device Server to target RAM. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4F1F0F0F, IR Length = 4. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 400 KHz. VREF level : 1.80 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 400 KHz. VREF level : 1.79 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 Storage Device: Samsung eMMC KYL00M Device ID : 00150001 Block size : 512 bytes Blocks : 30777344 Storage size : 14.7 Gb Opening "C:\Downloads\SAMSUNG_SHVE110S_Repair.mf" file... Writting PARTITION section. Please wait... Done Writting BOOT section. Please wait... ERROR[018]: Logical block operation failed at 102416 Kb (Hex address 0x06404200). Reason: Connection lost. Selected device model: Samsung SHV-E110S Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 1000 KHz. VREF level : 1.79 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4F1F0F0F, IR Length = 4. Detected TAP ID: 17B360E1, IR Length = 5. Detected TAP ID: 4F1F0F0F, IR Length = 4. ERROR[016]: Selected device CPU ID mismatch. Core ID = 4F1F0F0F, expected ID = 106A10E1. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4F1F0F0F, IR Length = 4. Detected TAP ID: 17B360E1, IR Length = 5. Detected TAP ID: 4F1F0F0F, IR Length = 4. ERROR[016]: Selected device CPU ID mismatch. Core ID = 4F1F0F0F, expected ID = 106A10E1. VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 1000 KHz. VREF level : 1.79 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 Storage Device: Samsung eMMC KYL00M Device ID : 00150001 Block size : 512 bytes Blocks : 30777344 Storage size : 14.7 Gb Opening "C:\Downloads\SAMSUNG_SHVE110S_Repair.mf" file... Writting PARTITION section. Please wait... Done Writting BOOT section. Please wait... ERROR[018]: Logical block operation failed at 102400 Kb (Hex address 0x06400200). Reason: Synchronization failed. Selected device model: Samsung SHV-E110S Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 2400 KHz. VREF level : 1.79 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4F1F0F0F, IR Length = 4. Detected TAP ID: 106A10E1, IR Length = 11. ERROR[032]: Target device Core has disabled JTAG/EmbeddedICE. JTAG speed : 2400 KHz. VREF level : 1.80 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4F1F0F0F, IR Length = 4. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 2400 KHz. VREF level : 1.80 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 2400 KHz. VREF level : 1.79 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4F1F0F0F, IR Length = 4. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 2400 KHz. VREF level : 1.79 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4F1F0F0F, IR Length = 4. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 2400 KHz. VREF level : 1.80 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 2400 KHz. VREF level : 1.79 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4F1F0F0F, IR Length = 4. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 2400 KHz. VREF level : 1.80 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4F1F0F0F, IR Length = 4. Detected TAP ID: 106A10E1, IR Length = 11. ERROR[032]: Target device Core has disabled JTAG/EmbeddedICE. JTAG speed : 2400 KHz. VREF level : 1.80 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Selected device model: Samsung SHV-E110S Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 4000 KHz. VREF level : 1.80 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4F1F0F0F, IR Length = 4. Detected TAP ID: 106A10E1, IR Length = 11. ERROR[032]: Target device Core has disabled JTAG/EmbeddedICE. JTAG speed : 4000 KHz. VREF level : 1.80 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4F1F0F0F, IR Length = 4. Detected TAP ID: 106A10E1, IR Length = 11. ERROR[032]: Target device Core has disabled JTAG/EmbeddedICE. JTAG speed : 4000 KHz. VREF level : 1.80 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Selected device model: Samsung SHV-E110S Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 6000 KHz. VREF level : 1.79 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4F1F0F0F, IR Length = 4. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 6000 KHz. VREF level : 1.79 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 6000 KHz. VREF level : 1.79 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 6000 KHz. VREF level : 1.79 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4F1F0F0F, IR Length = 4. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 6000 KHz. VREF level : 1.80 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4F1F0F0F, IR Length = 4. ERROR[016]: Selected device CPU ID mismatch. Core ID = 4F1F0F0F, expected ID = 106A10E1. VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 6000 KHz. VREF level : 1.80 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4F1F0F0F, IR Length = 4. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 6000 KHz. VREF level : 1.80 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4F1F0F0F, IR Length = 4. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 6000 KHz. VREF level : 1.80 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Selected device model: Samsung SHV-E110S Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 8000 KHz. VREF level : 1.79 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. ERROR[045]: Scan chain is too long or damaged. Scanned TAP ID's list: 0x9E3E0F0F 0x00000000 0x883510E1 0x8000007F 0x8000007F 0x8000007F 0x8000007F 0x8000007F MI: Medusa JTAG init failed. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. MI: Medusa JTAG init failed. VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. JTAG speed : 8000 KHz. VREF level : 1.79 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. MI: Medusa JTAG init failed. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. ERROR[045]: Scan chain is too long or damaged. Scanned TAP ID's list: 0x9E3E0F0F 0x00000000 0x883510E1 0x8000007F 0x8000007F 0x8000007F 0x8000007F 0x8000007F MI: Medusa JTAG init failed. Selected device model: Samsung SHV-E110S Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. ERROR[032]: Target device Core has disabled JTAG/EmbeddedICE. JTAG speed : 9600 KHz. VREF level : 1.80 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 9E3E1E1F, IR Length = 2. Detected TAP ID: 00000000, IR Length = 0. Detected TAP ID: 106A10E1, IR Length = 0. JTAG speed : 9600 KHz. VREF level : 1.80 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 9E3E1E1F, IR Length = 2. Detected TAP ID: 00000000, IR Length = 0. Detected TAP ID: 106A10E1, IR Length = 0. ERROR[032]: Target device Core has disabled JTAG/EmbeddedICE. JTAG speed : 9600 KHz. VREF level : 1.79 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Selected device model: Samsung SHV-E110S Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. ERROR[032]: Target device Core has disabled JTAG/EmbeddedICE. JTAG speed : 12000 KHz. VREF level : 1.79 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. ERROR[045]: Scan chain is too long or damaged. Scanned TAP ID's list: 0x4F1F0F0F 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0xFC031803 MI: Medusa JTAG init failed. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. MI: Medusa JTAG init failed. VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. ERROR[032]: Target device Core has disabled JTAG/EmbeddedICE. JTAG speed : 12000 KHz. VREF level : 1.80 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. ERROR[030]: TDO is constant high. Please check target device connection. MI: Medusa JTAG init failed. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. ERROR[030]: TDO is constant high. Please check target device connection. MI: Medusa JTAG init failed. VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. ERROR[032]: Target device Core has disabled JTAG/EmbeddedICE. JTAG speed : 12000 KHz. VREF level : 1.80 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Please connect the target device and power it on... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. ERROR[045]: Scan chain is too long or damaged. Scanned TAP ID's list: 0x07421C23 0x00000FE3 0x00000000 0x00000000 0x00000000 0x00000000 0x000001FF 0x00000000 MI: Medusa JTAG init failed. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. ERROR[045]: Scan chain is too long or damaged. Scanned TAP ID's list: 0x07021C23 0x00000FE3 0x00000000 0x00000000 0x00000000 0x00000000 0x000001FF 0x00000000 MI: Medusa JTAG init failed. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| 5110 5.60 orange - anyone has partial flash ? | koax | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 5 | 02-06-2002 11:14 |
| Has somedody nokia ppm&mcu flasher? | davix | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 02-26-2001 12:57 |
| HAS ANYONE BOUGHT FROM http//gsm-technology.com Or www.software-gsm.prv.pl | max8108 | GSM Mobile Links | 0 | 12-17-2000 15:29 |
| Has someome tested this software Nokia New Series Tool? | Genata | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 1 | 09-20-2000 16:39 |
| "Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 06-28-1999 14:56 |
