05-14-2018, 17:23 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,127 | SM-G930A SBL error, need Test Point [Answered] As title says do anyone have solution for this , test point required for edl mode Thank you Last edited by Medusa Box; 05-15-2018 at 12:25. |
05-15-2018, 12:25 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. You can try to download and install SRF for SM-G930T from the Support Area and check, whether Test Point for SM-G930A is the same as for SM-G930T. If PCB of these devices are similar, try to connect your SM-G930A as SM-G930T using Test Point. If connection will be successful, try to do "Smart Repair" as SM-G930T. Post here the result. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
05-22-2018, 18:13 | #3 (permalink) |
No Life Poster Join Date: Apr 2010 Location: NYC/USA
Member: 1283129 Status: Offline Thanks Meter: 135 | I just did one of these G930A stuck in SBL mode. Super easy, you don't need to mess with pinouts. Just connect with EDL cable (to put in qualcomm model 9008). Then just connect as G930T and do smart repair. |
The Following User Says Thank You to cafonabob1 For This Useful Post: |
05-22-2018, 18:16 | #4 (permalink) |
Member: 1283129 Status: Offline Thanks Meter: 135 | Welcome to Octoplus Pro JTAG Software version 1.5.9. Started. Reader #0: Generic EMV Smartcard Reader 0 Model Settings: Interface : USB Brand : Samsung Model : SM-G930T SRF : C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/SAMSUNG_SM-G930T_USB_UFS.srf Core : Qualcomm MSM8996 UFS Loader : QLoader_v3_Samsung Connecting... Sending loader...OK. Loader successfully initialized. ACK loadSizeToTargetInBytes=49152 n=1 loadSizeToTargetInBytesSupported=49152 sionSupported=1 SizeInBytes=4096 me=Sep 28 2016 - 14:44:13 Name=UFS Name=MSM8996 loadSizeFromTargetInBytes=4096 Device Total Logical Blocks: 0x76f000 Device Block Size in Bytes: 0x1000 Device Total Physical Paritions: 0x4 Device Manufacturer ID: 0x1ce Device Serial Number: 0x0 UFS fInitialized: 0x1 UFS Current LUN Number: = 0xd0 UFS Total Active LU: 0x4 UFS wManufacturerID: 0x1ce UFS Boot Partition Enabled: 0x1 UFS Raw Device Capacity: = 0x3b9e000 UFS Min Block Size: 0x8 UFS Erase Block Size: 0x2000 UFS Allocation Unit Size: 0x1 UFS RPMB ReadWrite Size: = 0x20 UFS Number of Allocation Uint for This LU: 0x0 UFS Logical Block Size: 0x0 UFS Provisioning Type: 0x0 UFS LU Write Protect: 0x0 UFS Boot LUN ID: = 0x0 UFS Memory Type: 0x0 UFS LU Total Blocks: 0x0 UFS Supported Memory Types: 0x800f UFS dEnhanced1MaxNAllocU: 0x1dcf UFS wEnhanced1CapAdjFac: 0x200 UFS dEnhanced2MaxNAllocU: = 0x0 UFS wEnhanced2CapAdjFac: 0x200 UFS dEnhanced3MaxNAllocU: 0x0 UFS wEnhanced3CapAdjFac: 0x200 UFS dEnhanced4MaxNAllocU: 0x0 UFS wEnhanced4CapAdjFac: 0x0 UFS LUN Enable Bitmask: 0xf UFS Logical Block Count: 0x0 UFS bConfigDescrLock: 0x1 UFS iManufacturerName String Index: 0x0 UFS iProductName String Index: 0x1 UFS iSerialNumber String Index: 0x2 UFS iOemID String Index: 0x3 UFS Inquiry Command Output: SAMSUNG KLUBG4G1CE-B0B1 0009 ACK Device : SAMSUNG KLUBG4G1CE-B0B1 0009 Core : Qualcomm MSM8996 UFS Page size : 4096 B Block size : 4096 B Block count : 7812096 Size : 29.80 GB (30516.00 MB) Connect successful. --------------------------------------------------------------- SW: 1.5.9; FW: 1.23. Physical partition number: 0 Block count : 7794688 (0x76F000) Size : 29.73 GB (30448.00 MB) P00: GPT (00000000, 00000108) 1056 KB P01: modemst1 (00000108, 00000180) 1536 KB P02: modemst2 (00000288, 00000180) 1536 KB P03: fsc (00000408, 00000001) 4 KB P04: ssd (00000409, 00000002) 8 KB P05: persist (0000040B, 00002000) 32 MB P06: efs (0000240B, 00001400) 20 MB P07: param (0000380B, 00000A00) 10 MB P08: misc (0000420B, 00000100) 1024 KB P09: keystore (0000430B, 00000080) 512 KB P10: devcfg (0000438B, 00000020) 128 KB P11: frp (000043AB, 00000080) 512 KB P12: bota (0000442B, 00000C00) 12 MB P13: fota (0000502B, 00000400) 4 MB P14: persistent (0000542B, 00000100) 1024 KB P15: apnhlos (0000552B, 00005F00) 95 MB P16: modem (0000B42B, 00005500) 85 MB P17: boot (0001092B, 00004C00) 76 MB P18: recovery (0001552B, 00004C00) 76 MB P19: persdata (0001A12B, 00000900) 9 MB P20: system (0001AA2B, 0012C000) 4.688 GB P21: cache (00146A2B, 00040000) 1024 MB P22: userdata (00186A2B, 005E85D0) 23.63 GB Physical partition number: 1 Block count : 1024 (0x400) Size : 4.00 MB P00: GPT (00000000, 00000006) 24 KB P01: xbl (00000006, 00000300) 3072 KB Physical partition number: 2 Block count : 1024 (0x400) Size : 4.00 MB P00: GPT (00000000, 00000006) 24 KB P01: xbl (00000006, 00000300) 3072 KB Physical partition number: 3 Block count : 15360 (0x3C00) Size : 60.00 MB P00: GPT (00000000, 00000006) 24 KB P01: rpm (00000006, 00000080) 512 KB P02: tz (00000086, 00000200) 2048 KB P03: hyp (00000286, 00000080) 512 KB P04: fsg (00000306, 00000180) 1536 KB P05: sec (00000486, 00000004) 16 KB P06: pmic (0000048A, 00000080) 512 KB P07: dsp (0000050A, 00001000) 16 MB P08: dip (0000150A, 00000100) 1024 KB P09: mdtp (0000160A, 00002000) 32 MB P10: aboot (0000360A, 00000200) 2048 KB P11: devinfo (0000380A, 00000001) 4 KB P12: bluetooth (0000380B, 00000100) 1024 KB P13: lksecapp (0000390B, 00000060) 384 KB P14: keymaster (0000396B, 00000040) 256 KB P15: cmnlib (000039AB, 00000040) 256 KB P16: cmnlib64 (000039EB, 00000040) 256 KB P17: apdp (00003A2B, 00000020) 128 KB P18: msadp (00003A4B, 00000020) 128 KB P19: dpo (00003A6B, 00000001) 4 KB P20: ddr (00003A6C, 00000100) 1024 KB P21: pad (00003B6C, 0000008F) 572 KB Repairing from file "C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/SAMSUNG_SM-G930T_USB_UFS.srf". Write data verification is enabled. Physical partition number: 0 Writing GPT partition... Done. Physical partition number: 0 Writing fsc partition... Done. Physical partition number: 0 Writing ssd partition... Done. Physical partition number: 0 Writing persist partition... Done. Physical partition number: 0 Writing param partition... Done. Physical partition number: 0 Writing misc partition... Done. Physical partition number: 0 Writing keystore partition... Done. Physical partition number: 0 Writing devcfg partition... Done. Physical partition number: 0 Writing frp partition... Done. Physical partition number: 0 Writing bota partition... Done. Physical partition number: 0 Writing fota partition... Done. Physical partition number: 0 Writing persistent partition... Done. Physical partition number: 0 Writing apnhlos partition... Done. Physical partition number: 0 Writing modem partition... Done. Physical partition number: 0 Writing boot partition... Done. Physical partition number: 0 Writing recovery partition... Done. Physical partition number: 0 Writing persdata partition... Done. Physical partition number: 1 Writing GPT partition... Done. Physical partition number: 1 Writing xbl partition... Done. Physical partition number: 2 Writing GPT partition... Done. Physical partition number: 2 Writing xbl partition... Done. Physical partition number: 3 Writing GPT partition... Done. Physical partition number: 3 Writing rpm partition... Done. Physical partition number: 3 Writing tz partition... Done. Physical partition number: 3 Writing hyp partition... Done. Physical partition number: 3 Writing fsg partition... Done. Physical partition number: 3 Writing sec partition... Done. Physical partition number: 3 Writing pmic partition... Done. Physical partition number: 3 Writing dsp partition... Done. Physical partition number: 3 Writing dip partition... Done. Physical partition number: 3 Writing mdtp partition... Done. Physical partition number: 3 Writing aboot partition... Done. Physical partition number: 3 Writing devinfo partition... Done. Physical partition number: 3 Writing bluetooth partition... Done. Physical partition number: 3 Writing lksecapp partition... Done. Physical partition number: 3 Writing keymaster partition... Done. Physical partition number: 3 Writing cmnlib partition... Done. Physical partition number: 3 Writing cmnlib64 partition... Done. Physical partition number: 3 Writing apdp partition... Done. Physical partition number: 3 Writing msadp partition... Done. Physical partition number: 3 Writing dpo partition... Done. Physical partition number: 3 Writing ddr partition... Done. Physical partition number: 3 Writing pad partition... Done. Smart Repair is successfully complete. SW: 1.5.9; FW: 1.23. Disconnected. |
The Following 3 Users Say Thank You to cafonabob1 For This Useful Post: |
05-23-2018, 03:32 | #5 (permalink) |
Member: 1283129 Status: Offline Thanks Meter: 135 | When I went to flash stock it gave an error about file size. Just repartition and profit. |
05-26-2018, 05:22 | #7 (permalink) |
Member: 1283129 Status: Offline Thanks Meter: 135 | G930A. When I did the Octopus Jtag repair I downloaded the SBL (SCF? I don't remember) file for G930T and it completed but it was stuck on the android screen. When I initially flashed G930A firmware it failed flashing the cache partition so I found a pit file on the internet for G930A and flashed stock G930A firmware with the pit file and profit Anyway, play and learn. =) |
05-26-2018, 05:26 | #8 (permalink) |
Member: 1283129 Status: Offline Thanks Meter: 135 | Anyway after you do with Octopus JTag tool with the G930T file you will be able to get into download mode so you can figure it out from there. Flash whatever you want. You can flash now so solution is near =) |
