10-02-2017, 14:55 | #1 (permalink) |
No Life Poster Join Date: Nov 2011 Location: Student
Member: 1686564 Status: Offline Sonork: PM me Thanks Meter: 157 | SM-J100H Boot repair ok but not powe on 1st - I tray smart repair , smart repair ok but not power on 2nd - tray to factory repair by pit file & boot file repair ok but no power on Connect ok Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J100H SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J100H_EMMC_H4G2B.srf Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A4834473262110131B7157F8235 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) 31B7157F Manufacturing date : 08/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H4G2b_02_10_2017_19_21_01.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.4; FW: 1.22. Smart Repair ok SW: 1.4.4; FW: 1.22. Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J100H_EMMC_H4G2B.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to user area. Writing GPT partition... Done. Writing SBOOT partition... Done. Writing SBOOT2 partition... Done. Writing wfixnv1 partition... Done. Writing wfixnv2 partition... Done. Writing tdfixnv1 partition... Done. Writing tdfixnv2 partition... Done. Writing WDSP partition... Done. Writing MODEM partition... Done. Writing MODEM2 partition... Done. Writing TDDSP partition... Done. Writing wruntimenv1 partition... Done. Writing wruntimenv2 partition... Done. Writing tdruntimenv1 partition... Done. Writing tdruntimenv2 partition... Done. Writing PARAM partition... Done. Writing efs partition... Done. Smart Repair is successfully complete. SW: 1.4.4; FW: 1.22. Disconnected. Use This file fore factory repair J100HXCU0AOA1_LUX0AOA1 |
The Following User Says Thank You to unlock in nepal For This Useful Post: |
10-04-2017, 06:12 | #5 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Hello. Fully charge phone's battery and then try to put the phone into Download Mode (DM) manually. If the device doesn't go into DM, here can be two main reasons of this problem - device has HW issue or boot loaders in SRF files which You have used for repairing could be not suitable (not compatible) with your phone (boot loaders are older (has lower version) than should be in your phone, thus the phone can't go into Download Mode because of enabled boot downgrade protection). Try to perform "Factory Repair" operation ("Factory repair" tab in Software) using proper PIT file and different latest original Samsung firmwares for this phone model. Also please note, that here exist different HW revisions of this device, maybe your device has another HW, that the supported one and repair file on the Support Area is not compatible for your phone. To repair the phone try to do the following: 1. Download "Boot Area Partition 1" file "BOOT1_SAMSUNG SM-J100H) HYNIX EMMC H4G2B.BIN" via "Download *.srf" button. 2. Connect the phone and erase "Boot Area Partition 1" (select "Boot Area Partition 1" option in Software and press "Erase" button). 3. Disconnect the phone. 4. Connect the phone and write "Boot Area Partition 1" file "BOOT1_SAMSUNG SM-J100H) HYNIX EMMC H4G2B.BIN" (select "Boot Area Partition 1" option and press "Write" button). 5. Disconnect the phone. 6. Connect the phone and do "Factory Repair" ("Factory repair" tab in Software) using PIT file and original Samsung firmware from here: [ Post here Latest Original Firmwares ] For Repair Boot in [ Factory Mode ] - Page 5 - GSM-Forum. 7. Disconnect the phone and try to power it on or put it into Download Mode. Also, look here: http://forum.gsmhosting.com/vbb/f664.../#post12541224, http://forum.gsmhosting.com/vbb/f664.../#post12335114, http://forum.gsmhosting.com/vbb/f664.../#post12611783. |
10-04-2017, 10:21 | #6 (permalink) |
Member: 1686564 Status: Offline Sonork: PM me Thanks Meter: 157 | I use latest file but no power on this IS nepal purchage mobile i use nepal natest flash file from************** but write ok but no power on Model SM-J100H Model name Galaxy J1 Country Version Android 4.4.4 Changelist 1170438 Build date Tue, 14 Feb 2017 04:06:23 +0000 Security Patch Level 2017-02-01 Product code NPL PDA J100HDDS0AQB1 CSC J100HODD0AQA2 |
10-04-2017, 11:20 | #8 (permalink) |
Member: 1686564 Status: Offline Sonork: PM me Thanks Meter: 157 | Selected pit file: C:/Users/HP/Desktop/J100H Now power/Pro/J13G.pit Selected firmware file: C:/Users/HP/Desktop/J100H Now power/Pro/J100HDDS0AQB1_J100HODD0AQA2_J100HDDU0APH1_HOME.tar .md5 Open file "C:/Users/HP/Desktop/J100H Now power/Pro/J100HDDS0AQB1_J100HODD0AQA2_J100HDDU0APH1_HOME.tar .md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Writing partition BOOT... Done. Writing partition SBOOT... Done. Writing partition SBOOT2... Done. Writing partition WDSP... Done. Writing partition MODEM... Done. Writing partition KERNEL... Done. Writing partition RECOVERY... Done. Writing partition CSC... Done. Writing partition system... Done. Writing partition HIDDEN... Done. Writing is finished. SW: 1.4.4; FW: 1.22. |
10-04-2017, 12:04 | #10 (permalink) |
Member: 1686564 Status: Offline Sonork: PM me Thanks Meter: 157 | Model Settings: Interface : eMMC Brand : Samsung Model : SM-J100H SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J100H_EMMC_H4G2B.srf Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A4834473262110131B7157F8235 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) 31B7157F Manufacturing date : 08/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H4G2b_04_10_2017_16_48_12.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.4; FW: 1.22. |
10-04-2017, 13:31 | #11 (permalink) | ||||
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Quote:
Also, as I see from your previous Software log: Quote:
10-04-2017, 14:13 | #12 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Why You don't read carefully, what I have written above? 1. You need to change "Boot partition enable" value to "Boot partition 1 (Bus width = 1Bit)". To change "Boot partition enable", do the following steps: 1). Connect the device. 2). Go to "eMMC service" tab in Software. 3). Press "Boot operation mode" button and set "Boot partition enable" value to "Boot partition 1". 4). Re-connect the device and check, whether proper value was set. 2. Download "Boot Area Partition 1" file "BOOT1_SAMSUNG SM-J100H) HYNIX EMMC H4G2B.BIN" via "Download *.srf" button. 3. Connect the phone and erase "Boot Area Partition 1" (select "Boot Area Partition 1" option in Software and press "Erase" button). 4. Disconnect the phone. 5. Connect the phone and write "Boot Area Partition 1" file "BOOT1_SAMSUNG SM-J100H) HYNIX EMMC H4G2B.BIN" (select "Boot Area Partition 1" option and press "Write" button). 6. Disconnect the phone. 7. Connect the phone and do "Factory Repair" ("Factory repair" tab in Software) using PIT file and original Samsung firmware from here: [ Post here Latest Original Firmwares ] For Repair Boot in [ Factory Mode ] - Page 5 - GSM-Forum. 8. Disconnect the phone and try to power it on or put it into Download Mode. Post here full Software log with all of these performed operations, we will check. |
10-04-2017, 15:40 | #14 (permalink) |
Member: 1686564 Status: Offline Sonork: PM me Thanks Meter: 157 | Sir not solve Model Settings: Interface : eMMC Brand : Samsung Model : SM-J100H SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J100H_EMMC_H4G2B.srf Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A4834473262110131B7157F8235 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) 31B7157F Manufacturing date : 08/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H4G2b_04_10_2017_20_23_39.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.4; FW: 1.22.S |
