01-10-2018, 22:21 | #1 (permalink) |
Insane Poster Join Date: May 2015 Location: TR Age: 34
Member: 2396411 Status: Offline Thanks Meter: 31 | SM-J700F repair question [Answered] factory repair not work Code: Welcome to Medusa Pro Software version 1.5.1. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Reader #2: FT SCR2000 1 Reader #3: FT SCR2000 2 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J700F SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J700F_EMMC_400073.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J700F SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J700F_EMMC_400073.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J700F SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J700F_EMMC_400073.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 400073 Page size : 512 B Block size : 512 B Block count : 2097152 Size : 1024.00 MB --------------------------------------------------------------- CID Info CID : 110100343030303733008FAA1AF3A28F Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 400073 Product revision : 0.0 Product serial number : (hex) 8FAA1AF3 Manufacturing date : 10/2015 --------------------------------------------------------------- CSD Info CSD : D07E00320F5903FFFFFFFFE78A4000D1 CSD structure : CSD version No. 1.0 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 8 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Erase block size : 66560 Kbytes Boot1 size : 30464 Kbytes Boot2 size : 30464 Kbytes RPMB size : 0 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Max enhanced data size: 0 Kbytes Partitions attribute : 0x40 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/400073_10_01_2018_23_23_01.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.1; FW: 1.22. FRP was not found! FRP was not found! Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J700F_EMMC_400073.srf". Write data verification is enabled. Switch error!!! Writing BOOT1 partition... Write verification error 1. Possible reasons: damaged or write protected eMMC. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J700F SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J700F_EMMC_400073.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 400073 Page size : 512 B Block size : 512 B Block count : 2097152 Size : 1024.00 MB --------------------------------------------------------------- CID Info CID : 110100343030303733008FAA1AF3A28F Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 400073 Product revision : 0.0 Product serial number : (hex) 8FAA1AF3 Manufacturing date : 10/2015 --------------------------------------------------------------- CSD Info CSD : D07E00320F5903FFFFFFFFE78A4000D1 CSD structure : CSD version No. 1.0 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 8 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Erase block size : 66560 Kbytes Boot1 size : 30464 Kbytes Boot2 size : 30464 Kbytes RPMB size : 0 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Max enhanced data size: 0 Kbytes Partitions attribute : 0x40 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/400073_10_01_2018_23_23_20.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.1; FW: 1.22. Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J700F_EMMC_400073.srf". Write data verification is enabled. Switch error!!! Writing BOOT1 partition... Write verification error 1. Possible reasons: damaged or write protected eMMC. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J700F SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J700F_EMMC_400073.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 400073 Page size : 512 B Block size : 512 B Block count : 2097152 Size : 1024.00 MB --------------------------------------------------------------- CID Info CID : 110100343030303733008FAA1AF3A28F Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 400073 Product revision : 0.0 Product serial number : (hex) 8FAA1AF3 Manufacturing date : 10/2015 --------------------------------------------------------------- CSD Info CSD : D07E00320F5903FFFFFFFFE78A4000D1 CSD structure : CSD version No. 1.0 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 8 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Erase block size : 66560 Kbytes Boot1 size : 30464 Kbytes Boot2 size : 30464 Kbytes RPMB size : 0 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Max enhanced data size: 0 Kbytes Partitions attribute : 0x40 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/400073_10_01_2018_23_23_32.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.1; FW: 1.22. Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J700F_EMMC_400073.srf". Write data verification is enabled. Switch error!!! Writing BOOT1 partition... Write verification error 1. Possible reasons: damaged or write protected eMMC. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J700F SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J700F_EMMC_400073.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 400073 Page size : 512 B Block size : 512 B Block count : 2097152 Size : 1024.00 MB --------------------------------------------------------------- CID Info CID : 110100343030303733008FAA1AF3A28F Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 400073 Product revision : 0.0 Product serial number : (hex) 8FAA1AF3 Manufacturing date : 10/2015 --------------------------------------------------------------- CSD Info CSD : D07E00320F5903FFFFFFFFE78A4000D1 CSD structure : CSD version No. 1.0 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 8 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Erase block size : 66560 Kbytes Boot1 size : 30464 Kbytes Boot2 size : 30464 Kbytes RPMB size : 0 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Max enhanced data size: 0 Kbytes Partitions attribute : 0x40 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/400073_10_01_2018_23_24_05.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.1; FW: 1.22. Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J700F_EMMC_400073.srf". Write data verification is disabled. Switch error!!! Writing BOOT1 partition... ERROR[012]: Write error. At sector 0 Attempting to write... Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J700F SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J700F_EMMC_400073.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 400073 Page size : 512 B Block size : 512 B Block count : 2097152 Size : 1024.00 MB --------------------------------------------------------------- CID Info CID : 110100343030303733008FAA1AF3A28F Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 400073 Product revision : 0.0 Product serial number : (hex) 8FAA1AF3 Manufacturing date : 10/2015 --------------------------------------------------------------- CSD Info CSD : D07E00320F5903FFFFFFFFE78A4000D1 CSD structure : CSD version No. 1.0 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 8 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Erase block size : 66560 Kbytes Boot1 size : 30464 Kbytes Boot2 size : 30464 Kbytes RPMB size : 0 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Max enhanced data size: 0 Kbytes Partitions attribute : 0x40 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/400073_10_01_2018_23_24_35.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.1; FW: 1.22. Erasing. Please wait... error! ERROR[013]: Erase error. Attempting to erase... error! Smart report info: Hash code: 0000000000000000000000000000000000000000000000000000000000000000 Super block size : 0x00000000 Bytes Super page size : 0x00000000 Bytes Optima write size : 0x00000000 Bytes Number of banks : 0 Bank0 init bad block : 0 Bank0 runtime bad block : 0 Bank0 remain reserved block : 0 Max erase count : 0 Min erase count : 0 Avg erase count : 0 Read reclaim count : 0 Optimal trim size : 0x00000000 Bytes Max erase count (SCL) : 0 Min erase count (SCL) : 0 Avg erase count (SCL) : 0 Max erase count (MLC) : 0 Min erase count (MLC) : 0 Avg erase count (MLC) : 0 SW: 1.5.1; FW: 1.22. Last edited by Medusa Box; 01-12-2018 at 06:33. |
01-10-2018, 22:25 | #2 (permalink) |
Member: 2396411 Status: Offline Thanks Meter: 31 | Code: SW: 1.5.1; FW: 1.22. Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J700F_EMMC_400073.srf". Write data verification is disabled. Switch error!!! Writing BOOT1 partition... ERROR[012]: Write error. At sector 0 Attempting to write... Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J700F SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J700F_EMMC_400073.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 400073 Page size : 512 B Block size : 512 B Block count : 2097152 Size : 1024.00 MB --------------------------------------------------------------- CID Info CID : 110100343030303733008FAA1AF3A28F Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 400073 Product revision : 0.0 Product serial number : (hex) 8FAA1AF3 Manufacturing date : 10/2015 --------------------------------------------------------------- CSD Info CSD : D07E00320F5903FFFFFFFFE78A4000D1 CSD structure : CSD version No. 1.0 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 8 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Erase block size : 66560 Kbytes Boot1 size : 30464 Kbytes Boot2 size : 30464 Kbytes RPMB size : 0 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Max enhanced data size: 0 Kbytes Partitions attribute : 0x40 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/400073_10_01_2018_23_30_38.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.1; FW: 1.22. Remove write protect successfully completed. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J700F SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J700F_EMMC_400073.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 400073 Page size : 512 B Block size : 512 B Block count : 2097152 Size : 1024.00 MB --------------------------------------------------------------- CID Info CID : 110100343030303733008FAA1AF3A28F Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 400073 Product revision : 0.0 Product serial number : (hex) 8FAA1AF3 Manufacturing date : 10/2015 --------------------------------------------------------------- CSD Info CSD : D07E00320F5903FFFFFFFFE78A4000D1 CSD structure : CSD version No. 1.0 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 8 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Erase block size : 66560 Kbytes Boot1 size : 30464 Kbytes Boot2 size : 30464 Kbytes RPMB size : 0 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Max enhanced data size: 0 Kbytes Partitions attribute : 0x40 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/400073_10_01_2018_23_31_02.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.1; FW: 1.22. Please select file. Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J700F_EMMC_400073.srf". Write data verification is enabled. Switch error!!! Writing BOOT1 partition... Write verification error 1. Possible reasons: damaged or write protected eMMC. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J700F SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J700F_EMMC_400073.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 400073 Page size : 512 B Block size : 512 B Block count : 2097152 Size : 1024.00 MB --------------------------------------------------------------- CID Info CID : 110100343030303733008FAA1AF3A28F Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 400073 Product revision : 0.0 Product serial number : (hex) 8FAA1AF3 Manufacturing date : 10/2015 --------------------------------------------------------------- CSD Info CSD : D07E00320F5903FFFFFFFFE78A4000D1 CSD structure : CSD version No. 1.0 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 8 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Erase block size : 66560 Kbytes Boot1 size : 30464 Kbytes Boot2 size : 30464 Kbytes RPMB size : 0 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Max enhanced data size: 0 Kbytes Partitions attribute : 0x40 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/400073_10_01_2018_23_31_20.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.1; FW: 1.22. Please select file. Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J700F_EMMC_400073.srf". Write data verification is disabled. Switch error!!! Writing BOOT1 partition... ERROR[012]: Write error. At sector 0 Attempting to write... Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J700F SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J700F_EMMC_400073.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 400073 Page size : 512 B Block size : 512 B Block count : 2097152 Size : 1024.00 MB --------------------------------------------------------------- CID Info CID : 110100343030303733008FAA1AF3A28F Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 400073 Product revision : 0.0 Product serial number : (hex) 8FAA1AF3 Manufacturing date : 10/2015 --------------------------------------------------------------- CSD Info CSD : D07E00320F5903FFFFFFFFE78A4000D1 CSD structure : CSD version No. 1.0 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 8 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Erase block size : 66560 Kbytes Boot1 size : 30464 Kbytes Boot2 size : 30464 Kbytes RPMB size : 0 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Max enhanced data size: 0 Kbytes Partitions attribute : 0x40 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/400073_10_01_2018_23_31_41.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.1; FW: 1.22. Smart report info: Hash code: 0000000000000000000000000000000000000000000000000000000000000000 Super block size : 0x00000000 Bytes Super page size : 0x00000000 Bytes Optima write size : 0x00000000 Bytes Number of banks : 0 Bank0 init bad block : 0 Bank0 runtime bad block : 0 Bank0 remain reserved block : 0 Max erase count : 0 Min erase count : 0 Avg erase count : 0 Read reclaim count : 0 Optimal trim size : 0x00000000 Bytes Max erase count (SCL) : 0 Min erase count (SCL) : 0 Avg erase count (SCL) : 0 Max erase count (MLC) : 0 Min erase count (MLC) : 0 Avg erase count (MLC) : 0 SW: 1.5.1; FW: 1.22. Erasing. Please wait... error! ERROR[013]: Erase error. Attempting to erase... error! Erasing. Please wait... error! ERROR[013]: Erase error. Attempting to erase... error! Erasing. Please wait... error! ERROR[013]: Erase error. Attempting to erase... error! FRP was not found! Factory Format will erase all eMMC data! Do you want to continue? Yes. Formating...Done. SW: 1.5.1; FW: 1.22. Disconnected. |
01-11-2018, 09:37 | #5 (permalink) | |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Quote:
You shouldn't connect the device with such high (2.8V) voltage level, this can damage the device. Connect the device with lower voltage level (2.0V-2.4V) and check, whether eMMC is detected (connected) correctly. | |
01-11-2018, 12:04 | #6 (permalink) | |
Member: 2396411 Status: Offline Thanks Meter: 31 | Quote:
Code: Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 400073 Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 110100343030303733008FAA1AF3A28F Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 400073 Product revision : 0.0 Product serial number : (hex) 8FAA1AF3 Manufacturing date : 10/2015 --------------------------------------------------------------- CSD Info CSD : D07E00320F5903FFFFFFFFE78A4000D1 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 8 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7696384 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/400073_11_01_2018_00_32_54.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.1; FW: 1.22. Factory Format will erase all eMMC data! Do you want to continue? Yes. Formating...Done. SW: 1.5.1; FW: 1.22. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 400073 Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 110100343030303733008FAA1AF3A28F Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 400073 Product revision : 0.0 Product serial number : (hex) 8FAA1AF3 Manufacturing date : 10/2015 --------------------------------------------------------------- CSD Info CSD : D07E00320F5903FFFFFFFFE78A4000D1 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 8 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 4Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7696384 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/400073_11_01_2018_00_33_24.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.1; FW: 1.22. Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J700F_EMMC_400073.SRF". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to boot area partition 2. Writing BOOT2 partition... Done. Switched to user area. Writing GPT partition... Done. Writing BOTA0 partition... Done. Writing BOTA1 partition... Done. Writing EFS partition... Done. Writing CPEFS partition... Done. Writing m9kefs1 partition... Done. Writing m9kefs2 partition... Done. Writing m9kefs3 partition... Done. Writing CARRIER partition... Done. Writing PARAM partition... Done. Writing BOOT partition... Done. Writing RECOVERY partition... Done. Writing OTA partition... Done. Writing CDMA-RADIO partition... Done. Writing RADIO partition... Done. Writing TOMBSTONES partition... Done. Writing DNT partition... Done. Writing PERSISTENT partition... Done. Writing PERSDATA partition... Done. Writing RESERVED2 partition... Done. Smart Repair is successfully complete. SW: 1.5.1; FW: 1.22. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 400073 Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 110100343030303733008FAA1AF3A28F Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 400073 Product revision : 0.0 Product serial number : (hex) 8FAA1AF3 Manufacturing date : 10/2015 --------------------------------------------------------------- CSD Info CSD : D07E00320F5903FFFFFFFFE78A4000D1 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 8 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 4Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7696384 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/400073_11_01_2018_00_36_20.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.1; FW: 1.22. P00: GPT (00000000, 00002000) 4 MB P01: BOTA0 (00002000, 00002000) 4 MB P02: BOTA1 (00004000, 00002000) 4 MB P03: EFS (00006000, 0000A000) 20 MB P04: CPEFS (00010000, 00004000) 8 MB P05: m9kefs1 (00014000, 00002000) 4 MB P06: m9kefs2 (00016000, 00002000) 4 MB P07: m9kefs3 (00018000, 00002000) 4 MB P08: CARRIER (0001A000, 00000800) 1024 KB P09: PARAM (0001A800, 00004000) 8 MB P10: BOOT (0001E800, 00010000) 32 MB P11: RECOVERY (0002E800, 00013000) 38 MB P12: OTA (00041800, 00004000) 8 MB P13: CDMA-RADIO (00045800, 00002000) 4 MB P14: RADIO (00047800, 0002C000) 88 MB P15: TOMBSTONES (00073800, 00000800) 1024 KB P16: DNT (00074000, 00000800) 1024 KB P17: PERSISTENT (00074800, 00000400) 512 KB P18: PERSDATA (00074C00, 00006000) 12 MB P19: RESERVED2 (0007AC00, 00001400) 2560 KB P20: SYSTEM (0007C000, 0041C000) 2104 MB P21: CACHE (00498000, 00064000) 200 MB P22: HIDDEN (004FC000, 00014000) 40 MB P23: USERDATA (00510000, 01848000) 12.14 GB Selected pit file: C:/Users/OznTeknik/Desktop/Download/J700FXXU1AOFJ_OJV1AOFJ_Arabic_v5.1.1_Repair_Firmware_FULL_4Files_by.reda@gem-flash.com/J700FXXU1AOFJ_OJV1AOFJ_Arabic_v5.1.1_Repair_Firmware/J7ELTE_EUR_OPEN.pit Open file "C:/Users/OznTeknik/Desktop/Download/J700FXXU1AOFJ_OJV1AOFJ_Arabic_v5.1.1_Repair_Firmware_FULL_4Files_by.reda@gem-flash.com/J700FXXU1AOFJ_OJV1AOFJ_Arabic_v5.1.1_Repair_Firmware/AP_J700FXXU1AOFJ_CL679261_QB5476082_REV00_user_low_ship_.tar.md5". Open file "C:/Users/OznTeknik/Desktop/Download/J700FXXU1AOFJ_OJV1AOFJ_Arabic_v5.1.1_Repair_Firmware_FULL_4Files_by.reda@gem-flash.com/J700FXXU1AOFJ_OJV1AOFJ_Arabic_v5.1.1_Repair_Firmware/BL_J700FXXU1AOFJ_CL679261_QB5476082_REV00_user_low_ship.tar.md5". Open file "C:/Users/OznTeknik/Desktop/Download/J700FXXU1AOFJ_OJV1AOFJ_Arabic_v5.1.1_Repair_Firmware_FULL_4Files_by.reda@gem-flash.com/J700FXXU1AOFJ_OJV1AOFJ_Arabic_v5.1.1_Repair_Firmware/CP_J700FXXU1AOFJ_CL679261_QB5476082_REV00_user_low_ship.tar.md5". Open file "C:/Users/OznTeknik/Desktop/Download/J700FXXU1AOFJ_OJV1AOFJ_Arabic_v5.1.1_Repair_Firmware_FULL_4Files_by.reda@gem-flash.com/J700FXXU1AOFJ_OJV1AOFJ_Arabic_v5.1.1_Repair_Firmware/CSC_OJV_J700FOJV1AOFJ_CL679261_QB5476082_REV00_user_low_ship.tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition BOOTLOADER... Done. Switched to boot area partition 2. Writing partition CM... Done. Switched to user area. Writing partition PARAM... Done. Writing partition BOOT... Done. Writing partition RECOVERY... Done. Writing partition RADIO... Done. Writing partition SYSTEM... Done. Writing partition CACHE... Done. Writing partition HIDDEN... Done. Writing is finished. SW: 1.5.1; FW: 1.22. Disconnected. | |
01-12-2018, 06:32 | #9 (permalink) | ||
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Yes, probably, the problem is with eMMC, but also, as You can see from your Software log, Partition config in your devices is the following: Quote:
Please set correct Partition config settings accordingly to "Live Log" ("eMMC service" tab, "Boot operation mode" button), then re-connect eMMC and do "Smart Repair" again. Also try to do "Factory Repair". Post here the result. | ||
