07-18-2017, 12:27 | #1 (permalink) |
No Life Poster Join Date: Dec 2013 Location: Uzbekistan/Tashkent
Member: 2082192 Status: Offline Sonork: not Thanks Meter: 1,119 | SM-T211 Boot repair via eMMC Factory repair Done! Code: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 Bus speed : 10 Connecting... Device : Samsung eMMC M8G1WA Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB --------------------------------------------------------------- CID Info CID : 1501004D3847315741006DE797A5A021 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : M8G1WA Product revision : 0.0 Product serial number : (hex) 6DE797A5 Manufacturing date : 10/2013 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFE18E404029 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 2544640 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 212992 Number of sectors : 2945024 Device Manufacturer : samsung Device Platform : mrvl Build ID : JZO54K Display Build ID : JZO54K.T211XXAML1 Release ID : 4.1.2 Device Model : SM-T211 Device Name : lt023gxx Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Build Description : lt023gxx-user 4.1.2 JZO54K T211XXAML1 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/M8G1WA_18_07_2017_15_23_55.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.9; FW: 1.19. P00: GPT (00000000, 00002000) P01: MRD (00002000, 00000800) P02: MRD_BK (00002800, 00000800) P03: BOTA0 (00003000, 00002000) P04: SBL2 (00005000, 00002000) P05: SBL (00007000, 00002000) P06: EFS (00009000, 00006000) P07: PARAM (0000F000, 00004000) P08: MODEM (00013000, 00006000) P09: KERNEL (00019000, 00006000) P10: RECOVERY (0001F000, 00006000) P11: MISC (00025000, 00005000) P12: NVM (0002A000, 00008000) P13: MEP (00032000, 00002000) P14: SYSTEM (00034000, 002CF000) P15: CACHE (00303000, 00064000) P16: HIDDEN (00367000, 00064000) P17: USER (003CB000, 00AC2000) Selected pit file: C:/TEMP/T211XXBNI1/LT02.pit Open file "C:/TEMP/T211XXBNI1/BL_T211XXBNI1_2667930_REV00_user_low_ship.tar.md5". Open file "C:/TEMP/T211XXBNI1/AP_T211XXBNI1_2667930_REV00_user_low_ship.tar.md5". Open file "C:/TEMP/T211XXBNI1/CP_T211XXBNI1_2667930_REV00_user_low_ship.tar.md5". Open file "C:/TEMP/T211XXBNI1/CSC_OXE_T211OXEBNI1_2667930_REV00_user_low_ship.tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition PBL... Done. Switched to user area. Writing partition SBL2... Done. Writing partition SBL... Done. Writing partition PARAM... Done. Writing partition MODEM... Done. Writing partition KERNEL... Done. Writing partition RECOVERY... Done. Writing partition NVM... Done. Writing partition CACHE... Done. Writing partition HIDDEN... Done. Writing is finished. SW: 1.3.9; FW: 1.19. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 Bus speed : 10 Connecting... Device : Samsung eMMC M8G1WA Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB --------------------------------------------------------------- CID Info CID : 1501004D3847315741006DE797A5A021 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : M8G1WA Product revision : 0.0 Product serial number : (hex) 6DE797A5 Manufacturing date : 10/2013 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFE18E404029 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 2544640 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 212992 Number of sectors : 2945024 Device Manufacturer : samsung Device Platform : mrvl Build ID : JZO54K Display Build ID : JZO54K.T211XXAML1 Release ID : 4.1.2 Device Model : SM-T211 Device Name : lt023gxx Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Build Description : lt023gxx-user 4.1.2 JZO54K T211XXAML1 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/M8G1WA_18_07_2017_15_59_43.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.9; FW: 1.19. P00: GPT (00000000, 00002000) P01: mrd (00002000, 00000800) P02: mrd_bk (00002800, 00000800) P03: bota0 (00003000, 00002000) P04: sbl2 (00005000, 00002000) P05: sbl (00007000, 00002000) P06: efs (00009000, 00006000) P07: param (0000F000, 00004000) P08: modem (00013000, 00006000) P09: kernel (00019000, 00006000) P10: recovery (0001F000, 00006000) P11: misc (00025000, 00005000) P12: nvm (0002A000, 00008000) P13: mep (00032000, 00002000) P14: system (00034000, 002CF000) P15: cache (00303000, 00064000) P16: hidden (00367000, 00064000) P17: user (003CB000, 00AC3000) Disconnected. |
The Following 3 Users Say Thank You to ddilshod93 For This Useful Post: |
01-23-2018, 16:56 | #3 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,395 | Hello. To repair this device via eMMC, do the following: 1. Install the latest version of Medusa Pro Software (http://medusabox.com/eng/download/software). 2. Download and install SRF (Smart Repair File) "SAMSUNG_SM-T211_EMMC.srf" from the Support Area (via "Download *.srf" button in Software). 3. Select "eMMC" option in Software. 4. Select Samsung SM-T211 in Software list (model will appear in Software list after SRF installation). 5. Solder all necessary wires for eMMC (ISP) connection accordingly to Software manual (press "Pinout" button in Software). 6. Press "Connect" button to connect the device. 7. When device will be connected successfully, do "Smart Repair" ("Smart repair" button). 8. Post here the result. Also You can try to do "Factory Repair" ("Factory repair" tab in Software) as in the log above, using proper PIT file for SM-T211 and the latest original Samsung firmware. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
