Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 07-23-2017, 16:17   #1 (permalink)
Member: 1867244
Thanks Meter: 63
Smile Sony E5633 dead boot repair [Solved]
hello
i have a E5633 dead after flash in my hand but i can not find any dump file for this
besides is this chipset in normal condition ?
Model Settings: Interface : eMMC
Voltage : 1.8V
Bus Mode : 1
Bus speed : Auto
Connecting...
Device : Toshiba eMMC 016G72
Page size : 512 B
Block size : 512 B
Block count : 30777344
CID Info
CID : 110100303136473732009FC9A7EA5247
Manufacturer ID : 0X11
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : 016G72
Product revision : 0.0
Product serial number : (hex) 9FC9A7EA
Manufacturing date : 05/2015
CSD Info
CSD : D02700320F5903FFFFFFFFE78640009B
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.7 (for MMC v5.0, v5.01)
Erase block size : 4096 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 4096 Kbytes
Partition config : 01010000
Boot partition enable : Boot partition 2 (Bus width = 1Bit)
Boot ACK : Boot acknowledge sent during boot operation Bit
Boot bus conditions : 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 7696384 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...Ok
Disk/Image size : ab400000 bytes
Device sector size : 512 bytes
Partition offset : 24952832
Number of sectors : 5549056
Device Manufacturer : alps
Device Platform : mt6795
Build ID : 30.1.B.1.55
Display Build ID : 30.1.B.1.55
Release ID : 5.1
Device Model : E5633
Device Name : Xperia M5 Dual
Architecture ABI : arm64-v8a
Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi
Build Description : hollyds-user 5.1 2.0.J.0.0 1457498714 test-keys
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/016G72_23_07_2017_19_45_10.bin.
Connect successful.
SW: 1.4.0; FW: 1.20.
P00: GPT (00000000, 00000400)
P01: ta (00000400, 00001000)
P02: proinfo (00001400, 00001800)
P03: nvram (00002C00, 00002800)
P04: protect1 (00005400, 00005000)
P05: protect2 (0000A400, 00005000)
P06: seccfg (0000F400, 00000400)
P07: lk (0000F800, 00000800)
P08: ltalabel (00010000, 00008000)
P09: fotakernel (00018000, 00014000)
P10: boot (0002C000, 00014000)
P11: secro (00040000, 00003000)
P12: para (00043000, 00000400)
P13: logo (00043400, 00004000)
P14: expdb (00047400, 00005000)
P15: tee1 (0004C400, 00002800)
P16: tee2 (0004EC00, 00002800)
P17: metadata (00051400, 00010000)
P18: gen (00061400, 00000800)
P19: apps_log (00064000, 00008000)
P20: diag (0006C000, 00008000)
P21: oem (00074000, 00094000)
P22: cache (00108000, 00064000)
P23: userdata (0016C000, 01660000)
P24: system (017CC000, 0054AC00)
P25: flashinfo (01D16C00, 00008000)
Backuping TA partition...
Opening C:/Program Files (x86)/Medusa Pro Software/Backups/016G72_TA_0x400_0x1000_23_07_2017_19_45_10.bin file...
Reading. Please wait... Done.
Elapsed time 00:00:00
Analyzing Trim Area (TA)... Ok
TA IMEI: sfsf
Lock status: locked
if u any one have dump file i would be appriciated to share it with me
i need both
ROM 2
ROM 3
dump files
Old 07-24-2017, 06:00   #2 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 2,812
Hello.
Try to do "Factory Repair" using original Sony firmware in "*.FTF" or "*.SIN_FILE_SET" format. Post here the result.
The Following User Says Thank You to Medusa Box For This Useful Post:
Old 07-24-2017, 10:29   #3 (permalink)
Member: 1867244
Thanks Meter: 63
the phone just work fine after repair . i write only rom 3 partition and flash with the latest firmware here is the log
Welcome to Medusa Pro Software version 1.4.0.
Started.
Reader #0: FT SCR2000 0
Reader #1: FT SCR2000 1
Reader #2: Generic EMV Smartcard Reader 0
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 1
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
Release ID : 5.1
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/016G72_23_07_2017_21_59_24.bin.
Connect successful.
Opening C:/Program Files (x86)/Medusa Pro Software/Backups/016G72_TA_0x400_0x1000_23_07_2017_21_59_24.bin file...
TA IMEI: asdasdasd
Lock status: locked
Switched to boot area partition 2.
Opening C:/Users/Omid/Desktop/Sony_E5633_mt6795_mmcblk0boot1_ROM3.bin file...
Write data verification is enabled.
Writing. Please wait... Done.
Disconnected.
The Following 2 Users Say Thank You to mastershex For This Useful Post:
Old 07-24-2017, 10:30   #4 (permalink)
Member: 1867244
Thanks Meter: 63
Originally Posted by Medusa Box View Post
Hello.
thread can be closed now thanks
Page generated in 0.25449 seconds with 7 queries
