Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 06-21-2012, 17:35   #376 (permalink)
Member: 718432
lg lu2300 done.
Connecting. Please wait...
Medusa JTAG Firmware version 1.1.0.
Medusa JTAG Hardware S64 revision B.
Detected TAP ID: 1BA000E1, IR Length = 4.
Detected TAP ID: 202800E1, IR Length = 4.
JTAG speed : Auto (RTCK).
VREF level : 2.65 V
CPU : Qualcomm QSD8650
Core ID : 202800E1
Flash device: Hynix H8BES0UQ0MCR
Flash ID : 00AD55BC
Page size : 2048 bytes
Block size : 64 pages (128 Kb)
Block count: 4096
Flash size : 512 Mb
Opening "D:\medusa\file repair\lg\LG_LU2300_Repair.mf" file...
Writting BOOT section. Please wait... Done
Writting APPBOOT section. Please wait... Done
Disconnected
Repair done.
Phone hang logo.
I nead file dump full.
The Following User Says Thank You to nguyenmanhcuong For This Useful Post:
Old 06-25-2012, 14:33   #377 (permalink)
Member: 1293050
Sonork: 100.1625975
Log started at 24.06.2012 16:54:17 ...
Welcome to Medusa Box Software version 1.5.0.1
Selected device model: Samsung SPH-W2400
MI: RTCK reaction time 189 ns, average speed 5291 KHz.
ERROR[030]: TDO is constant high. Please check target device connection.
MI: Medusa JTAG init failed.
Please connect the target device and power it on...
VREF = 0.80V is less than required level. Please check target device power supply.
Detected TAP ID: 300600E1, IR Length = 4.
MI: Halting target, attempt 1.
VREF level : 2.60 V
CPU : Qualcomm MSM6275
Core ID : 300600E1
MI: Loading Medusa Device Server V1.2.
MI: Starting...
MI: Received status 0x0000F00F, cycle 0.
MI: Received server capabilities 0x00000035.
MI: Detailed server caps: FLASH, ECC, WDOG, DWP
MI: Watchdog are preconfigured.
MI: Server init.
MI: Received flash ID 0xA0EC0071.
MI: Flash geometry set.
MI: Recheking settings... ok
Server caps : 00000035
Flash device: Samsung KBE00S00AM
Flash ID : 00EC0071
Page size : 512 bytes
Block size : 32 pages (16 Kb)
Block count: 16384
Flash size : 256 Mb
Write protection disabled.
Opening "D:\Program Files\GsmServer\Medusa\Firmware\SAMSUNG_SPHW2400_R epair.mf" file...
Disconnected
The Following User Says Thank You to Namangan For This Useful Post:
Old 06-25-2012, 20:24   #378 (permalink)
Dr_Wolodya's Avatar
Member: 75408
Sonork: 100.1588890
Repair dead Sony Ericsson WT19i:
25.06.2012 21:02:39 > --------------------------------------------------------------------------------
25.06.2012 21:02:39 > Platform: SE Qualcomm
25.06.2012 21:02:39 > Selected model: WT19i
25.06.2012 21:02:39 > Prepairing loaders...25.06.2012 21:02:40 > OK
25.06.2012 21:02:40 > Please, reconnect battery, attach testpoint and connect USB cable...25.06.2012 21:02:55 > OK
25.06.2012 21:02:55 > Please, disconnect testpoint.
25.06.2012 21:02:55 > Sending loader...25.06.2012 21:02:55 > OK
25.06.2012 21:02:55 > Waiting for loader...25.06.2012 21:03:02 > OK
25.06.2012 21:03:02 > Reading info...25.06.2012 21:03:02 > OK
25.06.2012 21:03:02 > Initializing flash...25.06.2012 21:03:02 > OK
25.06.2012 21:03:02 > Flash type : NAND
25.06.2012 21:03:02 > Flash ID : 6690B398
25.06.2012 21:03:02 > NAND page size: 4096 b
25.06.2012 21:03:02 > NAND pages per block: 64 b
25.06.2012 21:03:02 > NAND spare size: 64 b
25.06.2012 21:03:02 > NAND blocks count: 4096
25.06.2012 21:03:02 > Flash size: 1024 MB
25.06.2012 21:03:02 > Calculating security...25.06.2012 21:03:04 > OK
25.06.2012 21:03:04 > Erasing entire flash...25.06.2012 21:03:19 > OK
25.06.2012 21:03:19 > Detected bad blocks: 0
25.06.2012 21:03:19 > Repairing SBL...25.06.2012 21:03:24 > OK
25.06.2012 21:03:24 > Writing TA...25.06.2012 21:03:25 > OK
25.06.2012 21:03:25 > Writing TA_MISC...25.06.2012 21:03:26 > OK
25.06.2012 21:03:26 > Phone succesfully repaired.
25.06.2012 21:03:26 > To complete the operation, please write firmware.
25.06.2012 21:03:39 > --------------------------------------------------------------------------------
25.06.2012 21:33:55 > Platform: SE Qualcomm
25.06.2012 21:33:55 > Selected model: WT19i
25.06.2012 21:33:55 > Opening "WT19i_4_0_2_A_0_69.APP_SW_Coconut_GENERIC_1250_5829_S1_SW_LIVE_883F_PID1_0001.oct"...25.06.2012 21:33:55 > OK
25.06.2012 21:33:55 > Please, reconnect battery, hold "Vol-" key and connect USB cable...25.06.2012 21:34:06 > OK
25.06.2012 21:34:06 > Reading info...
25.06.2012 21:34:06 > Chipset: S1 MSM8255
25.06.2012 21:34:06 > IMEI: 000000-00-000000-0
25.06.2012 21:34:06 > MSN: CB5A1FDYH2
25.06.2012 21:34:06 > Sending loader...25.06.2012 21:34:08 > OK
25.06.2012 21:34:08 > Writing Firmware...
25.06.2012 21:34:08 > Writing AMSS...25.06.2012 21:34:16 > OK
25.06.2012 21:34:16 > Writing AMSS_FS...25.06.2012 21:34:16 > OK
25.06.2012 21:34:16 > Writing APPS...25.06.2012 21:34:16 > OK
25.06.2012 21:34:16 > Writing CACHE...25.06.2012 21:34:17 > OK
25.06.2012 21:34:17 > Writing ADSP...25.06.2012 21:34:20 > OK
25.06.2012 21:34:20 > Writing FOTA0...25.06.2012 21:34:20 > OK
25.06.2012 21:34:20 > Writing FOTA1...25.06.2012 21:34:21 > OK
25.06.2012 21:34:21 > Writing KERNEL...25.06.2012 21:34:23 > OK
25.06.2012 21:34:23 > Writing SYSTEM...25.06.2012 21:36:16 > OK
25.06.2012 21:36:16 > Writing USERDATA...25.06.2012 21:36:21 > OK
25.06.2012 21:36:21 > Shutting down...25.06.2012 21:36:21 > OK
Phone now alive!
The Following User Says Thank You to Dr_Wolodya For This Useful Post:
Old 06-25-2012, 23:12   #379 (permalink)
Member: 71290
I9003 done
Detected TAP ID: 2B89102F, IR Length = 6.
MI: Found ICEPick TAP Router 2B89102F.
MI: Enabling ARM Cortex core.
Velocidad de JTAG : 1000 KHz.
Nivel de VREF : 1.78 V
Tipo del núcleo : Texas Instruments OMAP3630
ID del núcleo: 0B6D602F
MI: Starting...
MI: Received server capabilities 0x00000135.
MI: Detailed server caps: FLASH, ECC, WDOG, DWP, IOCTL
MI: Server init.
MI: Received flash ID 0xB0EC0050.
Iconos del servidor : 00000135
Tipo de la flash: Samsung OneNAND KFG4GH6Q4M
ID de la flash: 00EC0050
Tamaño de la página: 4096 bytes
Tamaño del bloque: 64 páginas (256 Kb)
Cantidad de los bloques : 2048
Tamaño total de la flash : 512 Mb
L a protección contra escritura está desactivada.
Está abierto el archivo "C:\Archivos de programa\GsmServer\Medusa\Firmware\SAMSUNG_GTI9003 _Repair.mf"...
Repair restarted at last fail position.
Escritura de la sección BOOT. Por favor, espere... Terminado
Escritura de la sección UPCH. Por favor, espere... Terminado
Desconectado.
The Following 2 Users Say Thank You to francoo For This Useful Post:
Old 06-27-2012, 00:14   #380 (permalink)
Member: 679135
Sonork: 100.1606448
Selected device model: Samsung SGH-T499
Medusa JTAG Hardware S64 revision C.
Detected TAP ID: 203C00E1, IR Length = 4.
JTAG speed  : 12000 KHz.
VREF level  : 2.59 V
CPU         : Qualcomm MSM7227
Core ID     : 203C00E1
Flash device: Samsung OneNAND KFG4GH6Q4M
Flash ID    : 00EC0050
 Page size  : 4096 bytes
 Block size : 64 pages (256 Kb)
 Block count: 2048
 Flash size : 512 Mb
Opening "E:\boxes\Medusa\Phone Firmware\SAMSUNG\SCHT499\SAMSUNG_SGHT499_Repair.mf" file...
Writting EFS section. Please wait... Done
Writting UPCH section. Please wait... Done
Disconnected
Repair done.
The Following User Says Thank You to hvalero2001 For This Useful Post:
Old 06-28-2012, 09:01   #381 (permalink)
amyll's Avatar
Member: 502507
Sonork: 100.1620541
Selected device model: Sony Ericsson XPERIA SO-01B
VREF = 0.0V is less than required level. Please check target device power supply.
Detected TAP ID: 202400E1, IR Length = 4.
ERROR[000]: Unable to halt core.
VREF level : 2.62 V
CPU : Qualcomm QSD8250
Core ID : 202400E1
Flash device: Micron 1024Mb
Flash ID : 002C55B3
Block count: 8192
Flash size : 1024 Mb
Connect successful.
Reading TA section. Please wait... Done
TA section has been backed up to "C:\Program Files\GsmServer\Medusa\Firmware\Sony Ericsson XPERIA SO-01B TA Backup 28-06-2012 13_46_36.mf".
Unlocking. Please wait... Done
The Following User Says Thank You to amyll For This Useful Post:
Old 07-02-2012, 10:10   #382 (permalink)
ady1975's Avatar
Member: 143635
Smile I5500
Detected TAP ID: 203C10E1, IR Length = 4.
JTAG speed : 1000 KHz.
VREF level : 2.60 V
CPU : Qualcomm MSM7227T
Core ID : 203C10E1
Flash ID : 00EC0050
Block count: 2048
Flash size : 512 Mb
Opening "D:\Service\medusa\firmware\samsung\i5500\SAMSUNG_ GTI5500_Repair.mf" file...
Disconnected
Repair done.
The Following User Says Thank You to ady1975 For This Useful Post:
Old 07-03-2012, 16:04   #383 (permalink)
yassyass's Avatar
Member: 260998
Sonork: 100.1581802
I9003 Repair done.
Selected device model: Samsung GT-I9003
VREF level : 1.82 V
CPU : Texas Instruments OMAP3630
Core ID : 0B6D602F
Flash ID : 00EC0050
Block count: 2048
Flash size : 512 Mb
Opening "C:\Program Files\GsmServer\Medusa\Firmware\SAMSUNG_GTI9003_Re pair.mf" file...
ERROR[018]: Logical block operation failed at 9696 Kb (Hex address 0x00978000). Reason: Connection lost.
VREF level : 1.82 V
Core ID : 0B6D602F
Flash ID : 00EC0050
Block count: 2048
Flash size : 512 Mb
Disconnected
Repair done.
The Following User Says Thank You to yassyass For This Useful Post:
Old 07-07-2012, 13:30   #384 (permalink)
Member: 1293050
Sonork: 100.1625975
SE E15i done
thanks Meduza team
Log started at 07.07.2012 17:08:35 ...
Selected device model: Sony Ericsson E15i
MI: RTCK reaction time 126 ns, average speed 7936 KHz.
VREF level : 2.59 V
Core ID : 203C00E1
MI: Starting...
MI: Received server capabilities 0x00000037.
MI: Detailed server caps: FLASH, CFG, ECC, WDOG, DWP
MI: Watchdog configuration: 0xB800010C, 0x00000001... ok
MI: Server init.
MI: Received flash ID 0xA02C55BC.
Server caps : 00000037
Flash device: Micron 512Mb
Flash ID : 002C55BC
Block count: 4096
Flash size : 512 Mb
MI: Setting configuration: 0xAAD400DA, 0x0044747E, 0x0000000D
MI: Configuration done.
TA section has been backed up to "D:\Program Files\GsmServer\Medusa\Firmware\Sony Ericsson E15i TA Backup 07-07-2012 17_10_59.mf".
Erasing TA section. Please wait... Done
Repairing. Please wait... Done
Disconnected
Old 07-09-2012, 05:18   #385 (permalink)
Member: 1293050
Sonork: 100.1625975
S5230 boot done
Log started at 08.07.2012 18:15:04 ...
Selected device model: Samsung GT-S5230
Detected TAP ID: 07926F0F, IR Length = 4.
VREF level : 2.98 V
CPU : Broadcom BCM2133
Core ID : 07926F0F
MI: Starting...
MI: Server init.
MI: Received flash ID 0xA0EC55BA.
Flash device: Samsung KF92G16
Flash ID : 00EC55BA
Block count: 2048
Flash size : 256 Mb
Opening "D:\Program Files\GsmServer\Medusa\Firmware\SAMSUNG_GTS5230_Re pair.mf" file...
Repairing IMEI... Done
Disconnected
Old 07-12-2012, 14:45   #386 (permalink)
ady1975's Avatar
Member: 143635
X10i erase,repair and full flash done !
Selected device model: Sony Ericsson XPERIA X10i
VREF level : 2.61 V
Core ID : 202400E1
Flash ID : 002C55B3
Block count: 8192
Connect successful.
Erasing BOOT section. Please wait... Done
Erasing FIRMWARE section. Please wait... Done
Disconnected
VREF level : 2.62 V
Core ID : 202400E1
Flash ID : 002C55B3
Block count: 8192
TA section has been backed up to "C:\Program Files\GsmServer\Medusa\Firmware\Sony Ericsson XPERIA X10i TA Backup 12-07-2012 13_46_19.mf".
Disconnected
Repair done.
VREF level : 2.62 V
Core ID : 202400E1
Flash ID : 002C55B3
Block count: 8192
Connect successful.
ECC Mode enabled.
Opening "D:\Service\medusa\firmware\sony\x10i\SE_XPERIAX10 I_FullFlash.mf" file...
Writting FIRMWARE section. Please wait...
ERROR[018]: Logical block operation failed at 192240 Kb (Hex address 0x0BBBC000). Reason: Connection lost.
Disconnected
VREF level : 2.3 V
Core ID : 202400E1
Flash ID : 002C55B3
Block count: 8192
Connect successful.
ECC Mode enabled.
Skipping BOOT section.
Writting FIRMWARE section. Please wait... Done
Disconnected
Old 07-14-2012, 13:26   #387 (permalink)
yassyass's Avatar
Member: 260998
Sonork: 100.1581802
s8530 Repair done.
Detected TAP ID: 1BA00477, IR Length = 4.
JTAG speed : 8000 KHz.
VREF level : 2.81 V
CPU : Samsung S5PC110
Core ID : 1BA00477
Flash ID : 00EC0050
Block count: 2048
Flash size : 512 Mb
Opening "C:\Program Files\GsmServer\Medusa\Firmware\SAMSUNG_GTS8530_Re pair.mf" file...
Disconnected
Repair done.
Old 07-14-2012, 14:36   #388 (permalink)
yassyass's Avatar
Member: 260998
Sonork: 100.1581802
i9000 Repair done.
Selected device model: Samsung GT-I9000
VREF level : 2.83 V
Core ID : 1BA00477
Flash ID : 00EC0050
Block count: 2048
Flash size : 512 Mb
Opening "C:\Program Files\GsmServer\Medusa\Firmware\SAMSUNG_GTI9000_Re pair.mf" file...
Disconnected
Repair done.
Old 07-14-2012, 15:55   #389 (permalink)
yassyass's Avatar
Member: 260998
Sonork: 100.1581802
N7000 Repair done.
Detected TAP ID: 4BA00477, IR Length = 4.
VREF level : 2.86 V
CPU : Samsung S5PC210
Core ID : 4BA00477
Storage Device: Samsung eMMC VYL00M
Device ID : 00150001
Block size : 512 bytes
Blocks : 30777344
Storage size : 14.7 Gb
Opening "C:\Program Files\GsmServer\Medusa\Firmware\SAMSUNG_GTN7000_Re pair.mf" file...
Old 07-15-2012, 06:40   #390 (permalink)
hfreire's Avatar
Member: 1459662
Modelo del dispositivo seleccionado: Samsung GT-S5560i
Conexión...
Velocidad JTAG : Auto (RTCK)
Nivel de VREF : 3.9 V
Tipo del núcleo : Broadcom BCM2133
ID del núcleo: 07926F0F
MI: Starting...
MI: Server init.
MI: Received flash ID 0xB0EC0040.
Tipo de la flash: Samsung OneNAND KFH2G16Q2M
ID de la flash: 00EC0040
Tamaño de la página: 2048 bytes
Tamaño del bloque: 64 páginas (128 Kb)
Tamaño total de la flash : 256 Mb
Conexión exitosa
ECC Mode enabled.
Corrigiendo IMEI... Terminado
The Following User Says Thank You to hfreire For This Useful Post:
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
NHE_8 wont work with NHEK5689.dll v3 steve Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 07-23-1999 15:48
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 07-16-1999 00:44
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 06-09-1999 17:04
Page generated in 1.83862 seconds with 12 queries
