02-28-2018, 07:35 | #901 (permalink) |
No Life Poster Join Date: Dec 2016 Location: Pakistan Age: 27
Member: 2665080 Status: Offline Thanks Meter: 63 | Samsung SM-A500FU Repair Dead Boot Successfully Done Code: Welcome to Medusa Pro Software version 1.5.4. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Reader #2: FT SCR2000 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-A50FU SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-A500FU_EMMC_R311MB.srf Voltage : 2.2V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC Q313MB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 150100513331334D42000C73C2B282AB Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : Q313MB Product revision : 0.0 Product serial number : (hex) C73C2B2 Manufacturing date : 08/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 376832 Number of sectors : 5029888 Device Manufacturer :samsung Device Platform :msm8916 Build ID :KTU84P Display Build ID :KTU84P.FA44_A500FUXXU1ANL2 Release ID :4.4.4 Device Model :SM-A500FU Device Name :a5ultexx Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Build Description :a5ultexx-user 4.4.4 KTU84P FA44_A500FUXXU1ANL2 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/Q313MB_28_02_2018_11_16_27.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.4; FW: 1.23. P00: GPT (00000000, 00002000) 4 MB P01: apnhlos (00002000, 00007800) 15 MB P02: modem (00009800, 0001CB80) 57.44 MB P03: sbl1 (00026380, 00000400) 512 KB P04: ddr (00026780, 00000040) 32 KB P05: aboot (000267C0, 00001000) 2048 KB P06: rpm (000277C0, 00000400) 512 KB P07: qsee (00027BC0, 00000400) 512 KB P08: qhee (00027FC0, 00000400) 512 KB P09: fsg (000283C0, 00001800) 3072 KB P10: sec (00029BC0, 00000020) 16 KB P11: pad (00029BE0, 00005420) 10.52 MB P12: param (0002F000, 00005000) 10 MB P13: efs (00034000, 00007000) 14 MB P14: modemst1 (0003B000, 00001800) 3072 KB P15: modemst2 (0003C800, 00001800) 3072 KB P16: boot (0003E000, 00006800) 13 MB P17: recovery (00044800, 00007800) 15 MB P18: fota (0004C000, 00002802) 5.001 MB P19: backup (0004E802, 000037EE) 6.991 MB P20: fsc (00051FF0, 00001800) 3072 KB P21: ssd (000537F0, 00000010) 8 KB P22: persist (00053800, 00004000) 8 MB P23: persdata (00057800, 00004800) 9 MB P24: system (0005C000, 004CC000) 2456 MB P25: cache (00528000, 00064000) 200 MB P26: hidden (0058C000, 00019000) 50 MB P27: userdata (005A5000, 017B4FD8) 11.85 GB Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-A500FU_EMMC_R311MB.srf". Write data verification is enabled. Writing GPT partition... Done. Writing apnhlos partition... Done. Writing modem partition... Done. Writing sbl1 partition... Done. Writing ddr partition... Done. Writing aboot partition... Done. Writing rpm partition... Done. Writing qsee partition... Done. Writing qhee partition... Done. Writing fsg partition... Done. Writing sec partition... Done. Writing pad partition... Done. Writing param partition... Done. Writing efs partition... Done. Writing modemst1 partition... Done. Writing modemst2 partition... Done. Writing boot partition... Done. Writing recovery partition... Done. Writing fota partition... Done. Writing backup partition... Done. Writing fsc partition... Done. Writing ssd partition... Done. Writing persist partition... Done. Writing persdata partition... Done. Smart Repair is successfully complete. SW: 1.5.4; FW: 1.23. Disconnected. Last edited by Medusa Box; 02-28-2018 at 08:27. |
The Following User Says Thank You to imeilock For This Useful Post: |
03-01-2018, 00:44 | #902 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Ukraine Age: 44
Member: 75408 Status: Offline Thanks Meter: 1,190 | Success unbrick by USB LG D380 Success unbrick by USB LG D380: Code: Welcome to Medusa Pro Software version 1.5.4. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Reader #2: FT SCR2000 1 Reader #3: Gemalto e-gate Smart Card 0 Reader #4: USB CCID Smart Card Reader 0 Model Settings: Interface : USB Brand : LG Model : D380 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/LG_D380_USB.srf Core : Qualcomm MSM8610 Loader : LG_loader_v1 Connecting... CPU name : Qualcomm MSM8610 Flash Id : 909201 Device : Hynix eMMC H4G1d Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB Connect successful. --------------------------------------------------------------- SW: 1.5.4; FW: 1.23. P00: PART_0B (00000001, FFFFFFFF) 2048 GB Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/LG_D380_USB.srf". Write data verification is enabled. Writing GPT partition... Done. Writing modem partition... Done. Writing sbl1 partition... Done. Writing rpm partition... Done. Writing tz partition... Done. Writing sdi partition... Done. Writing aboot partition... Done. Writing rpmb partition... Done. Writing tzb partition... Done. Writing abootb partition... Done. Writing pad partition... Done. Writing modemst1 partition... Done. Writing modemst2 partition... Done. Writing misc partition... Done. Writing persist partition... Done. Writing laf partition... Done. Writing boot partition... Done. Smart Repair is successfully complete. SW: 1.5.4; FW: 1.23. Disconnected. Last edited by Medusa Box; 03-01-2018 at 06:22. |
The Following User Says Thank You to Dr_Wolodya For This Useful Post: |
03-04-2018, 00:05 | #903 (permalink) |
Insane Poster Join Date: Sep 2010
Member: 1394213 Status: Offline Thanks Meter: 11 | Succefull repair GT-I8200 Succefull repair GT-I8200 Welcome to Medusa Pro Software version 1.5.5. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Downloaded and installed file C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-I8190_EMMC.srf. Downloaded and installed file C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-I8200N_EMMC.srf. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : GT-I8200N SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-I8200N_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 008GE0 Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 1101003030384745300492F37432A15F Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 008GE0 Product revision : 0.4 Product serial number : (hex) 92F37432 Manufacturing date : 10/2014 --------------------------------------------------------------- CSD Info CSD : D05E00320F5903FFFFFFFFEF924000D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 5 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 1392640 Number of sectors : 3115008 Device Manufacturer :samsung Device Platform :mrvl Build ID :JDQ39 Display Build ID :JDQ39.I8200NXXUAOC1 Release ID :4.2.2 Device Model :GT-I8200N Device Name :goldenve3gxx Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Build Description :goldenve3gxx-user 4.2.2 JDQ39 I8200NXXUAOC1 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/008GE0_03_03_2018_18_01_10.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.5; FW: 1.23. P00: GPT (00000000, 00002000) 4 MB P01: MRD (00002000, 00001000) 2048 KB P02: MRD_BK (00003000, 00001000) 2048 KB P03: MEP2 (00004000, 00001000) 2048 KB P04: EFS (00005000, 0000A000) 20 MB P05: Reserved (0000F000, 00007000) 14 MB P06: LOKE_2ND (00016400, 00000C00) 1536 KB P07: LOKE_1ST (00017400, 00000C00) 1536 KB P08: PARAM (00018000, 00008000) 16 MB P09: RECOVERY (00020000, 00008000) 16 MB P10: KERNEL (00028000, 00008000) 16 MB P11: MODEM (00030000, 0000C000) 24 MB P12: NVM (0003C000, 00008000) 16 MB P13: HIDDEN (00044000, 00064000) 200 MB P14: CACHE (000A8000, 000AC000) 344 MB P15: SYSTEM (00154000, 002F8800) 1521 MB P16: USER (0044C800, 00A43000) 5.131 GB Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-I8200N_EMMC.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to user area. Writing CustomPart partition... Done. Smart Repair is successfully complete. SW: 1.5.5; FW: 1.23. Disconnected. Last edited by Medusa Box; 03-04-2018 at 09:58. |
The Following User Says Thank You to plmosqueda For This Useful Post: |
03-04-2018, 00:12 | #904 (permalink) |
Member: 1394213 Status: Offline Thanks Meter: 11 | Succefull reapair Samsung SM-J110H Succefull reapair Samsung SM-J110H Welcome to Medusa Pro Software version 1.5.5. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J110H SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J110H_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A483447326211014353BA9FC203 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) 4353BA9F Manufacturing date : 12/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/H4G2b_03_03_2018_19_07_39.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.5; FW: 1.23. P00: GPT (00000000, 00005000) 10 MB P01: tdfixnv1 (00005000, 00000800) 1024 KB P02: tdfixnv2 (00005800, 00000800) 1024 KB P03: WDSP (00006000, 00002000) 4 MB P04: MODEM (00008000, 00004000) 8 MB P05: MODEM2 (0000C000, 00004000) 8 MB P06: TDDSP (00010000, 00002000) 4 MB P07: FOTA_SIG (00012000, 00000800) 1024 KB P08: wruntimenv1 (00012800, 00000800) 1024 KB P09: wruntimenv2 (00013000, 00000800) 1024 KB P10: tdruntimenv1 (00013800, 00000800) 1024 KB P11: tdruntimenv2 (00014000, 00000800) 1024 KB P12: PARAM (00014800, 00001000) 2048 KB P13: EFS (00015800, 0000A000) 20 MB P14: PRODNV (0001F800, 00002800) 5 MB P15: RESERVED2 (00022000, 00000800) 1024 KB P16: KERNEL (00022800, 00008000) 16 MB P17: RECOVERY (0002A800, 00008000) 16 MB P18: PERSDATA (00032800, 00004800) 9 MB P19: CSC (00037000, 00064000) 200 MB P20: SYSTEM (0009B000, 00203000) 1030 MB P21: HIDDEN (0029E000, 0001D000) 58 MB P22: USERDATA (002BB000, 00486000) 2316 MB Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J110H_EMMC.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to boot area partition 2. Writing BOOT2 partition... Done. Switched to user area. Writing GPT partition... Done. Writing SBOOT partition... Done. Writing SBOOT2 partition... Done. Writing wfixnv1 partition... Done. Writing wfixnv2 partition... Done. Writing tdfixnv1 partition... Done. Writing tdfixnv2 partition... Done. Writing WDSP partition... Done. Writing MODEM partition... Done. Writing MODEM2 partition... Done. Writing TDDSP partition... Done. Writing FOTA_SIG partition... Done. Writing wruntimenv1 partition... Done. Writing wruntimenv2 partition... Done. Writing tdruntimenv1 partition... Done. Writing tdruntimenv2 partition... Done. Writing PARAM partition... Done. Writing EFS partition... Done. Writing PRODNV partition... Done. Writing RESERVED2 partition... Done. Writing KERNEL partition... Done. Writing RECOVERY partition... Done. Writing PERSDATA partition... Done. Writing CSC partition... Done. Smart Repair is successfully complete. SW: 1.5.5; FW: 1.23. Disconnected Last edited by Medusa Box; 03-04-2018 at 09:59. |
03-06-2018, 08:58 | #905 (permalink) | |
Freak Poster Join Date: May 2012 Location: Turkey Age: 36
Member: 1754273 Status: Offline Thanks Meter: 32 | LG K350K Dead Boot Repair OK with Medusa Pro LG K350K Dead Boot Repair OK with Medusa Pro Connetct isp pinout, repair with KDZ file. Quote:
The Following User Says Thank You to Asiatic Rebel For This Useful Post: |
03-06-2018, 12:13 | #906 (permalink) |
No Life Poster Join Date: May 2009 Location: mumbai wadala
Member: 1037372 Status: Offline Thanks Meter: 557 | Samsung SM-G316HU dead boot repair successfully done Code: Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A483447326211015626E6C19213 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) 5626E6C1 Manufacturing date : 09/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H4G2b_06_03_2018_15_58_15.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.5; FW: 1.23. Erasing. Please wait... Done. SW: 1.5.5; FW: 1.23. Disconnected. Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A483447326211015626E6C19213 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) 5626E6C1 Manufacturing date : 09/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H4G2b_06_03_2018_16_16_14.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.5; FW: 1.23. No General Purpose Partition 1 enhanced attribute is not set write reliablity is set No General Purpose Partition 2 enhanced attribute is not set write reliablity is set No General Purpose Partition 3 enhanced attribute is not set write reliablity is set No General Purpose Partition 4 enhanced attribute is not set write reliablity is set No enhanced user data area write reliablity is set Creating HW partitions succesfully complete! Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A483447326211015626E6C19213 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) 5626E6C1 Manufacturing date : 09/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x1 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H4G2b_06_03_2018_16_17_40.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.5; FW: 1.23. Writing EXT_CSD succesfully complete! Disconnected. Please disconnect battery and USB cable. Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A483447326211015626E6C19213 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) 5626E6C1 Manufacturing date : 09/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x1 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H4G2b_06_03_2018_16_18_26.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.5; FW: 1.23. Please select file. Selected pit file: G:/samsung/g316hu/SM-G316HU_1_20170419084413_xd5ck8k1s1/VIVALTO_SWA_4GB_20140828.pit Open file "G:/samsung/g316hu/SM-G316HU_1_20170419084413_xd5ck8k1s1/G316HUDDS0AQD1_G316HUODD0APB1_G316HUDDU0APC1_HOME.tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition BOOT... Done. Switched to user area. Writing partition SBOOT... Done. Writing partition SBOOT2... Done. Writing partition WDSP... Done. Writing partition MODEM... Done. Writing partition KERNEL... Done. Writing partition RECOVERY... Done. Writing partition CSC... Done. Writing partition system... Done. Writing partition HIDDEN... Done. Writing is finished. SW: 1.5.5; FW: 1.23. Disconnected. Please disconnect battery and USB cable. Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A483447326211015626E6C19213 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) 5626E6C1 Manufacturing date : 09/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x1 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : e9000000 bytes Device sector size : 512 bytes Partition offset : 616448 Number of sectors : 2457600 Device Manufacturer :samsung Device Platform :sc8830 Build ID :KTU84P Display Build ID :KTU84P.G316HUDDS0AQD1 Release ID :4.4.4 Device Model :SM-G316HU Device Name :vivalto5mve3gdd Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Build Description :vivalto5mve3gdd-user 4.4.4 KTU84P G316HUDDS0AQD1 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H4G2b_06_03_2018_16_25_59.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.5; FW: 1.23. P00: GPT (00000000, 00002000) 4 MB P01: sboot (00002000, 00001000) 2048 KB P02: sboot2 (00003000, 00001000) 2048 KB P03: wfixnv1 (00004000, 00000800) 1024 KB P04: wfixnv2 (00004800, 00000800) 1024 KB P05: tdfixnv1 (00005000, 00000800) 1024 KB P06: tdfixnv2 (00005800, 00000800) 1024 KB P07: wdsp (00006000, 00002000) 4 MB P08: modem (00008000, 00004000) 8 MB P09: modem2 (0000C000, 00004000) 8 MB P10: tddsp (00010000, 00002000) 4 MB P11: fota_sig (00012000, 00000800) 1024 KB P12: wruntimenv1 (00012800, 00000800) 1024 KB P13: wruntimenv2 (00013000, 00000800) 1024 KB P14: tdruntimenv1 (00013800, 00000800) 1024 KB P15: tdruntimenv2 (00014000, 00000800) 1024 KB P16: param (00014800, 00001000) 2048 KB P17: efs (00015800, 0000A000) 20 MB P18: prodnv (0001F800, 00002800) 5 MB P19: reserved2 (00022000, 00000800) 1024 KB P20: kernel (00022800, 00008000) 16 MB P21: recovery (0002A800, 00008000) 16 MB P22: csc (00032800, 00064000) 200 MB P23: system (00096800, 00258000) 1200 MB P24: hidden (002EE800, 00040000) 128 MB P25: userdata (0032E800, 00417800) 2095 MB Last edited by Medusa Box; 03-06-2018 at 12:20. |
The Following 3 Users Say Thank You to royalnasim For This Useful Post: |
03-12-2018, 16:38 | #907 (permalink) |
Freak Poster Join Date: Nov 2013 Location: San Fernando La Union Age: 34
Member: 2068959 Status: Offline Thanks Meter: 252 | Huawei Honor H30-U10 DeadBoot Vibrates Only Recovers Done World's Firsts By Medusa Pr Huawei Honor H30-U10 DeadBoot Vibrates Only Recovers Done World's First Huawei H30-U10 DeadBoot After Flashing Using My Tested Firmware Result Vibrate Only Revived Done By Medusa Pro Go To eMMC Service Choose Hardware Partition Follow My ScreenShots After Repair Emmc Using Direct EMMC ISP Flash Again Firmware https://www.needrom.com/download/honor-3c-h30-u10/ Code:
The Following User Says Thank You to omairlee01 For This Useful Post: |
03-13-2018, 15:41 | #908 (permalink) |
No Life Poster Join Date: Sep 2013 Location: Kotla Arab Ali Khan(PAK)
Member: 2016954 Status: Offline Thanks Meter: 345 | SM-T210 Succesfull Emmc Repair Done My First Job done with Great box Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 212992 Number of sectors : 2945024 Device Manufacturer :samsung Device Platform :mrvl Build ID :JZO54K Display Build ID :JZO54K.T210XXAMKF Release ID :4.1.2 Device Model :SM-T210 Device Name :lt02wifixx Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Build Description :lt02wifixx-user 4.1.2 JZO54K T210XXAMKF release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/8WMB3R_12_03_2018_14_44_14.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.5; FW: 1.23. P00: GPT (00000000, 00002000) 4 MB P01: MRD (00002000, 00000800) 1024 KB P02: MRD_BK (00002800, 00000800) 1024 KB P03: BOTA0 (00003000, 00002000) 4 MB P04: SBL2 (00005000, 00002000) 4 MB P05: SBL (00007000, 00002000) 4 MB P06: EFS (00009000, 00006000) 12 MB P07: PARAM (0000F000, 00004000) 8 MB P08: MODEM (00013000, 00006000) 12 MB P09: KERNEL (00019000, 00006000) 12 MB P10: RECOVERY (0001F000, 00006000) 12 MB P11: MISC (00025000, 00005000) 10 MB P12: NVM (0002A000, 00008000) 16 MB P13: MEP (00032000, 00002000) 4 MB P14: SYSTEM (00034000, 002CF000) 1438 MB P15: CACHE (00303000, 00064000) 200 MB P16: HIDDEN (00367000, 00064000) 200 MB P17: USER (003CB000, 00AC2000) 5.379 GB Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_T210_THANKS_TO_MR_AGRSAT.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to boot area partition 2. Writing BOOT2 partition... Done. Switched to user area. Writing GPT partition... Done. Writing MRD partition... Done. Writing MRD_BK partition... Done. Writing BOTA0 partition... Done. Writing SBL2 partition... Done. Writing SBL partition... Done. Writing EFS partition... Done. Writing PARAM partition... Done. Writing MODEM partition... Done. Writing KERNEL partition... Done. Writing RECOVERY partition... Done. Writing MISC partition... Done. Writing NVM partition... Done. Writing MEP partition... Done. Smart Repair is successfully complete. SW: 1.5.5; FW: 1.23. Disconnected. |
The Following User Says Thank You to GsmKotla For This Useful Post: |
03-14-2018, 16:36 | #909 (permalink) |
Freak Poster Join Date: Oct 2007 Location: colombia
Member: 603138 Status: Offline Thanks Meter: 100 | SM-G532M successfully repaired Code: Welcome to Octoplus Pro JTAG Software version 1.5.5. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Alcor Micro USB Smart Card Reader 1 Reader #2: FT SCR2000 0 Reader #3: FT SCR2000 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-G532M SRF : C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/SAMSUNG_SM-G532M_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H8G4u Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A48384734759201053644C234D7 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4u Product revision : 0.1 Product serial number : (hex) 53644C2 Manufacturing date : 03/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFE78A40002B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/H8G4u_14_03_2018_10_29_46.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.5; FW: 1.23. P00: GPT (00000000, 00002000) 4 MB P01: BOTA0 (00002000, 00002000) 4 MB P02: nvram (00004000, 00004000) 8 MB P03: lk (00008000, 00001000) 2048 KB P04: BOTA1 (00009000, 00001000) 2048 KB P05: secro (0000A000, 00003800) 7 MB P06: seccfg (0000D800, 00000400) 512 KB P07: efuse (0000DC00, 00000400) 512 KB P08: tee1 (0000E000, 00003000) 6 MB P09: BOTA2 (00011000, 00003000) 6 MB P10: EFS (00014000, 00004000) 8 MB P11: nvdata (00018000, 00010000) 32 MB P12: PARAM (00028000, 00004000) 8 MB P13: recovery (0002C000, 00008000) 16 MB P14: boot (00034000, 00008000) 16 MB P15: md1img (0003C000, 00010000) 32 MB P16: md1dsp (0004C000, 00002000) 4 MB P17: keystore (0004E000, 00004000) 8 MB P18: omekeystore (00052000, 00001C00) 3584 KB P19: proinfo (00053C00, 00001400) 2560 KB P20: para (00055000, 00000400) 512 KB P21: PERSISTENT (00055400, 00000400) 512 KB P22: STEADY (00055800, 00000800) 1024 KB P23: protect1 (00056000, 00004000) 8 MB P24: protect2 (0005A000, 00004000) 8 MB P25: RESERVE2 (0005E000, 00002000) 4 MB P26: system (00060000, 00604000) 3080 MB P27: cache (00664000, 000C8000) 400 MB P28: hidden (0072C000, 0001E000) 60 MB P29: userdata (0074A000, 00744000) 3720 MB Repairing from file "C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/SAMSUNG_SM-G532M_EMMC.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to boot area partition 2. Writing BOOT2 partition... Done. Switched to user area. Writing GPT partition... Done. Writing bota0 partition... Done. Writing lk partition... Done. Writing secro partition... Done. Writing efuse partition... Done. Writing tee1 partition... Done. Writing param partition... Done. Writing recovery partition... Done. Writing boot partition... Done. Writing md1img partition... Done. Writing md1dsp partition... Done. Smart Repair is successfully complete. SW: 1.5.5; FW: 1.23. Disconnected. |
The Following User Says Thank You to jeilyscell For This Useful Post: |
03-15-2018, 09:37 | #910 (permalink) |
Freak Poster Join Date: Jul 2012 Location: karachi Age: 31
Member: 1779651 Status: Offline Sonork: 100.1603336 Thanks Meter: 97 | LG F600L V10i "dead" successfully repaired LG F600L V10i "dead" successfully repaired Here logs: Parsing file... Opening C:/Users/usmansoftware1/Downloads/F600L30e_00_0517.kdz file... File parsing finished. Write data verification is enabled. Writing. Please wait... Writing partition PrimaryGPT... Done. Writing partition modem... Done. Writing partition pmic... Done. Writing partition sbl1... Done. Writing partition tz... Done. Writing partition sdi... Done. Writing partition hyp... Done. Writing partition rpm... Done. Writing partition aboot... Done. Writing partition sbl1bak... Done. Writing partition pmicbak... Done. Writing partition hypbak... Done. Writing partition tzbak... Done. Writing partition rpmbak... Done. Writing partition abootbak... Done. Writing partition sdibak... Done. Writing partition persist... Done. Writing partition sec... Done. Writing partition rct... Done. Writing partition laf... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition raw_resources... Done. Writing partition raw_resourcesbak... Done. Writing partition factory... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition BackupGPT... Done. Writing is finished. SW: 1.5.5; FW: 1.23. #blue BR. USMAN SOFTWARE Last edited by Octopus box; 03-15-2018 at 10:09. |
The Following 2 Users Say Thank You to s a dot com For This Useful Post: |
03-15-2018, 17:36 | #911 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,103 | Huawei S7-721u Read USB SRF file successfully done Code: Welcome to Octoplus Pro JTAG Software version 1.5.5. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Alcor Micro USB Smart Card Reader 1 Reader #2: FT SCR2000 0 Reader #3: FT SCR2000 1 Model Settings: Interface : USB Core : Qualcomm MSM8x10 Loader : QLoader_v1 Connecting... Sending loader...OK. Loader successfully initialized. Device : CoreID_008140E1 Core : Qualcomm MSM8x10 Page size : 512 B Block size : 512 B Block count : 7569408 Size : 3696.00 MB Connect successful. --------------------------------------------------------------- SW: 1.5.5; FW: 1.23. P00: GPT (00000000, 00000022) 17 KB P01: sbl1 (00000022, 00000400) 512 KB P02: sdi (00000422, 00000040) 32 KB P03: DDR (00002000, 00000040) 32 KB P04: rpm (00004000, 000003E8) 500 KB P05: tz (000043E8, 000003E8) 500 KB P06: aboot (000047D0, 00002BB0) 5.461 MB P07: pad (00007380, 00000800) 1024 KB P08: oeminfo (00007B80, 00020000) 64 MB P09: modemst1 (00027B80, 00002000) 4 MB P10: modemst2 (00029B80, 00002000) 4 MB P11: modem (0002C000, 00030000) 96 MB P12: fsg (0005C000, 00002000) 4 MB P13: fsc (0005E000, 00000002) 1024 b P14: ssd (0005E002, 00000010) 8 KB P15: log (0005E012, 00010000) 32 MB P16: bkbootup (00070000, 00020000) 64 MB P17: persist (00090000, 00004000) 8 MB P18: boot (00094000, 00006000) 12 MB P19: recovery (0009A000, 00008000) 16 MB P20: cust (000A2000, 00100000) 512 MB P21: cache (001A2000, 00080000) 256 MB P22: misc (00222000, 00002000) 4 MB P23: system (00224000, 00100000) 512 MB P24: tmpdata (00324000, 00008000) 16 MB P25: vrcb (0032C000, 00002000) 4 MB P26: reserve (0032E000, 00008000) 16 MB P27: data (00336000, 00429FDF) 2132 MB Partition table has been found on device. Added partition GPT to constructor file. Added partition sbl1 to constructor file. Added partition sdi to constructor file. Added partition DDR to constructor file. Added partition rpm to constructor file. Added partition tz to constructor file. Added partition aboot to constructor file. Added partition pad to constructor file. Added partition oeminfo to constructor file. Added partition modemst1 to constructor file. Added partition modemst2 to constructor file. Added partition modem to constructor file. Added partition fsg to constructor file. Added partition fsc to constructor file. Added partition ssd to constructor file. Added partition log to constructor file. Added partition bkbootup to constructor file. Added partition persist to constructor file. Added partition boot to constructor file. Added partition recovery to constructor file. Added partition cust to constructor file. Added partition misc to constructor file. Added partition tmpdata to constructor file. Added partition vrcb to constructor file. Added partition reserve to constructor file. SRF "C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/Huawei_S7-721u_usb .srf" has been installed successfully. Disconnected. |
The Following User Says Thank You to rebainoor For This Useful Post: |
03-15-2018, 17:40 | #912 (permalink) |
Member: 231728 Status: Offline Thanks Meter: 2,103 | Stream System_B1 Create usb srf file successefully done Code: Welcome to Octoplus Pro JTAG Software version 1.5.5. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Alcor Micro USB Smart Card Reader 1 Reader #2: FT SCR2000 0 Reader #3: FT SCR2000 1 Model Settings: Interface : USB Core : Qualcomm MSM8x10 Loader : QLoader_v1 Connecting... Sending loader...OK. Loader successfully initialized. Device : CoreID_008110E1 Core : Qualcomm MSM8x10 Page size : 512 B Block size : 512 B Block count : 7569408 Size : 3696.00 MB Connect successful. --------------------------------------------------------------- SW: 1.5.5; FW: 1.23. P00: GPT (00000000, 00000022) 17 KB P01: sbl1 (00000022, 00000400) 512 KB P02: sdi (00000422, 00000100) 128 KB P03: aboot (00000522, 00000400) 512 KB P04: rpm (00000922, 000003E8) 500 KB P05: tz (00000D0A, 000003E8) 500 KB P06: pad (000010F2, 00000800) 1024 KB P07: modemst1 (000018F2, 00000C00) 1536 KB P08: modemst2 (000024F2, 00000C00) 1536 KB P09: misc (000030F2, 00000800) 1024 KB P10: fsc (000038F2, 00000002) 1024 b P11: ssd (000038F4, 00000010) 8 KB P12: diag (00003904, 00000800) 1024 KB P13: logo (00004104, 00002800) 5 MB P14: cdrom (00006904, 0000F000) 30 MB P15: modem (00020000, 00020000) 64 MB P16: DDR (00040000, 00000040) 32 KB P17: boot (00040040, 00005000) 10 MB P18: persist (00045040, 00010000) 32 MB P19: cache (00055040, 00010000) 32 MB P20: recovery (00065040, 00005000) 10 MB P21: fsg (0006A040, 00000C00) 1536 KB P22: system (0006AC40, 001C2000) 900 MB P23: userdata (0022CC40, 004D33C0) 2470 MB P24: grow (00700000, 00047FDF) 144 MB Added partition GPT to constructor file. Added partition sbl1 to constructor file. Added partition sdi to constructor file. Added partition aboot to constructor file. Added partition rpm to constructor file. Added partition tz to constructor file. Added partition pad to constructor file. Added partition modemst1 to constructor file. Added partition modemst2 to constructor file. Added partition misc to constructor file. Added partition fsc to constructor file. Added partition ssd to constructor file. Added partition diag to constructor file. Added partition logo to constructor file. Added partition cdrom to constructor file. Added partition modem to constructor file. Added partition DDR to constructor file. Added partition boot to constructor file. Added partition persist to constructor file. Added partition cache to constructor file. Added partition recovery to constructor file. Added partition fsg to constructor file. Added partition grow to constructor file. SRF "C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/Stream System_B1_usb.srf" has been installed successfully. Disconnected. |
03-16-2018, 13:08 | #913 (permalink) |
Member: 1037372 Status: Offline Thanks Meter: 557 | Coolpad dozen 1 boot repair done Code: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : 15 MHz Connecting... Device : Hynix eMMC H8G1e Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A4838473165050756D288A75231 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G1e Product revision : 0.7 Product serial number : (hex) 56D288A7 Manufacturing date : 05/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G1e_12_03_2018_13_33_20.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.5; FW: 1.23. Please select file. Please select file. Writing EXT_CSD succesfully complete! Disconnected. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : 15 MHz Connecting... Device : Hynix eMMC H8G1e Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A4838473165050756D288A75231 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G1e Product revision : 0.7 Product serial number : (hex) 56D288A7 Manufacturing date : 05/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G1e_12_03_2018_13_35_04.bin. Connect successful. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... Device : Hynix eMMC H8G1e Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A4838473165050756D288A75231 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G1e Product revision : 0.7 Product serial number : (hex) 56D288A7 Manufacturing date : 05/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G1e_12_03_2018_13_38_37.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.5; FW: 1.23. No General Purpose Partition 1 enhanced attribute is not set write reliablity is set No General Purpose Partition 2 enhanced attribute is not set write reliablity is set No General Purpose Partition 3 enhanced attribute is not set write reliablity is set No General Purpose Partition 4 enhanced attribute is not set write reliablity is set No enhanced user data area write reliablity is set Creating HW partitions succesfully complete! Disconnected. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... Device : Hynix eMMC H8G1e Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A4838473165050756D288A75231 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G1e Product revision : 0.7 Product serial number : (hex) 56D288A7 Manufacturing date : 05/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x1 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G1e_12_03_2018_13_38_58.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.5; FW: 1.23. Selected rawprogram XML file: H:/COOLPAD/8297l-100/8297L_I00/rawprogram0.xml. Backuping. Please wait... Reading partition modemst1... Done. Reading partition modemst2... Done. Backuping finished. #grenWriting. Please wait... Writing partition modem... Done. Writing partition sbl1... Done. Writing partition sbl1bak... Done. Writing partition aboot... Done. Writing partition abootbak... Done. Writing partition rpm... Done. Writing partition rpmbak... Done. Writing partition tz... Done. Writing partition tzbak... Done. Writing partition hyp... Done. Writing partition hypbak... Done. Writing partition misc... Done. Writing partition fsg... Done. Writing partition sec... Done. Writing partition boot... Done. Writing partition params... Done. Writing partition panic... Done. Writing partition system... Done. Writing partition persist... Done. Writing partition cache... Done. Writing partition recovery... Done. Writing MBR...Done. Writing primary GPT...Done. Writing partition BackupGPT... Done. Writing finished. SW: 1.5.5; FW: 1.23. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... Device : Hynix eMMC H8G1e Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A4838473165050756D288A75231 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G1e Product revision : 0.7 Product serial number : (hex) 56D288A7 Manufacturing date : 05/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x1 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G1e_12_03_2018_13_54_24.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.5; FW: 1.23. P00: GPT (00000000, 00010000) 32 MB P01: modem (00010000, 00020000) 64 MB P02: sbl1 (00030000, 00000400) 512 KB P03: sbl1bak (00030400, 00000400) 512 KB P04: aboot (00030800, 00007800) 15 MB P05: abootbak (00038000, 00007800) 15 MB P06: rpm (0003F800, 00000400) 512 KB P07: rpmbak (0003FC00, 00000400) 512 KB P08: tz (00040000, 00000400) 512 KB P09: tzbak (00040400, 00000400) 512 KB P10: hyp (00040800, 00000400) 512 KB P11: hypbak (00040C00, 00000400) 512 KB P12: pad (00041000, 00000800) 1024 KB P13: modemst1 (00041800, 00000C00) 1536 KB P14: modemst2 (00042400, 00000C00) 1536 KB P15: misc (00043000, 00000800) 1024 KB P16: fsc (00043800, 00000002) 1024 b P17: ssd (00043802, 00000010) 8 KB P18: DDR (00050000, 00000040) 32 KB P19: fsg (00050040, 00000C00) 1536 KB P20: sec (00050C40, 00000020) 16 KB P21: boot (00050C60, 0000A000) 20 MB P22: params (00060000, 00000800) 1024 KB P23: panic (00060800, 0000A000) 20 MB P24: autobak (0006A800, 00005000) 10 MB P25: system (00070000, 00400000) 2048 MB P26: persist (00470000, 00005000) 10 MB P27: cache (00475000, 00040000) 128 MB P28: recovery (004B5000, 0000A000) 20 MB P29: userdata (004BF000, 00000000) 0 b Last edited by Medusa Box; 03-16-2018 at 13:29. |
The Following User Says Thank You to royalnasim For This Useful Post: |
03-21-2018, 08:41 | #914 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Online Sonork: 100.1661890 Thanks Meter: 8,074 | Samsung Galaxy Grand Prime Plus SM-G532F Dead Boot Repair Via eMMC Done By Medusa PRO Samsung Galaxy Grand Prime Plus SM-G532F Dead Boot Repair Via eMMc Successfully Done, .::By::. .::: Medusa PRO :::. Last edited by Medusa Box; 03-21-2018 at 08:48. |
The Following 3 Users Say Thank You to kabul For This Useful Post: |
03-22-2018, 10:23 | #915 (permalink) | |
No Life Poster Join Date: May 2011 Location: ..:Inside UR Brain:.. Age: 34
Member: 1586370 Status: Offline Sonork: 100.1618206 Thanks Meter: 154 | SM-G532F J2 Prime Successfully Boot Repaired SM-G532F J2 Prime Successfully Boot Repaired...with Medusa Pro Via Factory Repair Method Quote:
The Following 3 Users Say Thank You to shaikh_shoeb50 For This Useful Post: |
NHE_8 wont work with NHEK5689.dll v3 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-1999 15:48 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
