08-28-2018, 22:52 | #1 (permalink) |
Freak Poster Join Date: Jul 2018 Location: Your sisterīs room
Member: 2854680 Status: Offline Thanks Meter: 63 | TUTORIAL Fix 0xb0000007 on Medusa software So i just use google as i can, and i find correct way to fix that issue (only if theres no virus, bad c++ etc and still error) The problem its thanks to Libusb0. dll x64! Must use that .dll but in x86 format (Download from google its easy, try it) replace libusb0 .dll (x64) to libusb0. dll (x86) and will open the software If that dont work you can try this software, its called "depends22_x86" 1)Download and open as admin 2)Open Medusa pro exe in software (may take a while, its reading some stuff) 3) When file its loaded u will see a LOT of stuff but that its not the point, find the "Module" section in software and scroll, in the right side u will see columns with names like "Checksum Sub System", find the one with "CPU" name 4)Find the x86 or x64 with red letters, if u see some of those red, it mean its wrong dll installed, select the red one and scroll to left in module apart, u will see a lot of SOMETHING. Dll So, the something. dll that its x64 and the "x64" its red, u must replace the dll of x64 to x86 or viceverse and done! software will run good and fast! Remember all dll are on /system32 or /SYSWoW64 |
The Following User Says Thank You to GSMTEAGER For This Useful Post: |
