11-15-2017, 10:46 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ropar
Member: 358277 Status: Offline Thanks Meter: 476 | urgent help need i have samsung i897 it was ok . only i want to repair imei of it . i wrongly flash it with i9003 firmware . after flashing its dead. now i a doingits boot repair via medusa. it always says Checking data... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. Detected TAP ID: 1BA00477, IR Length = 4. JTAG speed : 8000 KHz. VREF level : 2.82 V CPU : Samsung S5PC110 Core ID : 1BA00477 ERROR[002]: Failed to load Medusa Device Server to target RAM. Checking data... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. Detected TAP ID: 1BA00477, IR Length = 4. JTAG speed : 8000 KHz. VREF level : 2.82 V CPU : Samsung S5PC110 Core ID : 1BA00477 ERROR[002]: Failed to load Medusa Device Server to target RAM. plz send me solution . i need it badly . |
11-15-2017, 12:27 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Hello. Please check soldering of all JTAG wires, make them as short as possible (max 3-5 CM length) and try to connect again. To power the device use both - USB cable and fully charged battery. To connect the device, do the next steps: 1. Disconnect phone's battery, micro USB cable and Jtag wires. 2. Connect soldered Jtag wires to Box and press "Connect" button in Software. 3. Connect fully charged battery and press "Power On" button (try also with USB cable). 4. If the phone not connects, You can (should) try to connect it a few times by the same way. Try to connect the device with different JTAG speed values (including "Auto" option). Also, look here: http://forum.gsmhosting.com/vbb/f664...8/#post9877899, http://forum.gsmhosting.com/vbb/f664...4/#post8281409. |
