07-02-2018, 13:59 | #1 (permalink) |
Freak Poster Join Date: Oct 2017
Member: 2773088 Status: Offline Thanks Meter: 24 | Writing 1 partition only question [Answered] thanks great team Last edited by Medusa Box; 07-02-2018 at 14:29. |
07-02-2018, 14:29 | #2 (permalink) | |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Quote:
07-02-2018, 14:59 | #3 (permalink) |
Member: 2773088 Status: Offline Thanks Meter: 24 | Welcome to Medusa Pro Software version 1.5.9. Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : US550 SRF : C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/LG_US550_EMMC.srf Voltage : 2.2V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QN1SMB Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 150100514E31534D420147A157CD721F Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QN1SMB Product revision : 0.1 Product serial number : (hex) 47A157CD Manufacturing date : 07/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 594944 Number of sectors : 4697088 Device Manufacturer :lge Device Platform :msm8916 Build ID :LRX22G Display Build ID :LRX22G Release ID :5.0.2 Device Model :LGUS550 Device Name :c70_usc_us Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :c70_usc_us-user 5.0.2 LRX22G 151661123274e release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/QN1SMB_02_07_2018_15_48_42.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.9; FW: 1.23. P00: GPT (00000000, 00000400) 512 KB P01: sbl1 (00000400, 00000400) 512 KB P02: tz (00000800, 00000400) 512 KB P03: hyp (00000C00, 00000400) 512 KB P04: rpm (00001000, 00000400) 512 KB P05: aboot (00001400, 00001000) 2048 KB P06: pad (00002400, 00000C00) 1536 KB P07: sbl1bak (00003000, 00000400) 512 KB P08: tzbak (00003400, 00000400) 512 KB P09: hypbak (00003800, 00000400) 512 KB P10: rpmbak (00003C00, 00000400) 512 KB P11: abootbak (00004000, 00001000) 2048 KB P12: misc (00005000, 00008000) 16 MB P13: persist (0000D000, 00008000) 16 MB P14: metadata (00015000, 00000400) 512 KB P15: modemst1 (00015400, 00000C00) 1536 KB P16: modemst2 (00016000, 00000C00) 1536 KB P17: laf (00016C00, 0000C000) 24 MB P18: boot (00022C00, 0000C000) 24 MB P19: recovery (0002EC00, 0000C000) 24 MB P20: fsg (0003AC00, 00000C00) 1536 KB P21: fsc (0003B800, 00000400) 512 KB P22: ssd (0003BC00, 00000400) 512 KB P23: DDR (0003C000, 00000400) 512 KB P24: sec (0003C400, 00000400) 512 KB P25: encrypt (0003C800, 00000400) 512 KB P26: eksst (0003CC00, 00000400) 512 KB P27: rct (0003D000, 00000400) 512 KB P28: sns (0003D400, 00004000) 8 MB P29: factory (00041400, 00010000) 32 MB P30: fota (00051400, 00010000) 32 MB P31: drm (00061400, 00004000) 8 MB P32: mpt (00065400, 0000C000) 24 MB P33: modem (00071400, 00020000) 64 MB P34: system (00091400, 0047AC00) 2294 MB P35: cache (0050C000, 000C8000) 400 MB P36: userdata (005D4000, 008B3000) 4.35 GB P37: grow (00E87000, 00008FDF) 17.98 MB Partition table has been found on device. Partition table has been found on device. Save to C:/Users/HASHASH/Desktop folder... Reading partition DDR... Done. Reading is finished. SW: 1.5.9; FW: 1.23. Partition table has been found on device. Save to C:/Users/HASHASH/Desktop folder... Reading partition GPT... ERROR[011]: Read error. At sector 0 Attempting to read... Done. Reading partition sbl1... Done. Reading partition tz... Done. Reading partition hyp... Done. Reading partition rpm... Done. Reading partition aboot... Done. Reading partition pad... Done. Reading partition sbl1bak... Done. Reading partition tzbak... Done. Reading partition hypbak... Done. Reading partition rpmbak... Done. Reading partition abootbak... Done. Reading partition misc... Done. Reading partition persist... Done. Reading partition metadata... Done. Reading partition modemst1... Done. Reading partition modemst2... Done. Reading partition laf... Done. Reading partition boot... Done. Reading partition recovery... Done. Reading partition fsg... Done. Reading partition fsc... Done. Reading partition ssd... Done. Reading partition DDR... Done. Reading partition sec... Done. Reading partition encrypt... Done. Reading partition eksst... Done. Reading partition rct... Done. Reading partition sns... Done. Reading partition factory... Cancelling operation. Please wait...Done. Reading is canceled. SW: 1.5.9; FW: 1.23. Switched to user area. Save to C:/Users/HASHASH/Desktop folder... Reading partition DDR... Done. Reading is finished. SW: 1.5.9; FW: 1.23. Partition table has been found on device. Please select file. Partition table has been found on device. |
07-02-2018, 15:47 | #5 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Do the following: connect then device to which You want to write data, press "Partition manager" button to open "Partition manager" window, then press "Open file" button and select "GPT" binary file, from "C:/Users/HASHASH/Desktop" folder to which You have read out partitions backups. After opening GPT binary file, will appear table, like this: Now just click on necessary partition name on "Click to open file" and select necessary partitions, which you want to write. Press "Write partitions" button to write selected partitions. |
