11-25-2011, 21:17 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: N/A
Member: 109335 Status: Offline Thanks Meter: 27 | x10i, x10a, u20i, u20a my personal experience, i bought 2 boxes r.. and med.., since 3 weeks now i already fixed 1 hd2 with vref trace damaged with riff, and unlocked a htmega, as well killed a rhod300. but hoping in repairing sony with medusa, hasn't been as expected, nor htc, mytouch4g(xtc "clip"), rhod300(jrt supposed to do it), hd2 with no vref trace. "i know its my personal experience and no disrespect intended", but for me both havent been as pleaseant as expected. but i really want to say thanks for the fact that you pay atention to your customers, answering most of times. thank you very much indeed atv Last edited by atv; 11-25-2011 at 21:26. |
11-26-2011, 09:13 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. For yuor x10i, x10a, u20i, u20a please perform the next steps: 1. Connect device in Advanced Mode and make Erase of full flash. 2. Connect device in EasyRepair Mode and make Repair of the device by following the Wizard instructions. 3. After successful Repair of your device You have to put it to "Emergency Mode" to re-flash: i). Reconnect the battery; ii). Press and hold "Back" key; iii). Connect the USB Cable. 4. Look at the PC Device Manager and write here what the device appears when You put your X10a into Emergency mode. 5. Re-flash your device with Medusa Flasher. 6. Post here full software log with all of your actions. |
12-02-2011, 20:12 | #3 (permalink) |
Member: 109335 Status: Offline Thanks Meter: 27 | hi again sorry for the delay, but here its an example of the phones that i have that are dead, more than 6, with the same issue. Log started at 11/29/2011 8:19:38 PM ... Welcome to Medusa Box Software version 1.2.7 Selected device model: Sony Ericsson U20i Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. ERROR[035]: Target device has been powered off during connect. VREF = 0.0V is less than required level. Please check target device power supply. MI: RTCK reaction time 126 ns. Detected Core ID: 203C00E1 ERROR[000]: Unable to halt core. MI: RTCK reaction time 126 ns. Detected Core ID: 203C00E1 VREF level : 2.55 V CPU : Qualcomm MSM7227 Core ID : 203C00E1 MI: P15,C0,C0: 0x41069265 MI: Loading server. MI: Starting server. MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000037. MI: Detailed server caps: FLASH, CFG, ECC, WDOG, DWP MI: Watchdog configuration: 0xB800010C, 0x00000001... ok MI: Server init. MI: Received flash ID 0xA02055BC. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 00000037 Flash device: ST Micro 512Mb Flash ID : 002055BC Page size : 2048 bytes Block size : 64 pages (128 Kb) Block count: 4096 Flash size : 512 Mb Write protection disabled. MI: Setting configuration: 0xAAD400DA, 0x0044747E, 0x0000000D MI: Configuration done. Connect successful. Erasing BOOT section. Please wait... Done Erasing BOOT section. Please wait... Done Erasing FIRMWARE section. Please wait... Done Reading TA section. Please wait... Done TA section has been backed up to "C:\Program Files\GsmServer\Medusa\Firmware\Sony Ericsson U20i TA Backup 29-11-2011 20_31_19.mf". Erasing TA section. Please wait... Done Repairing. Please wait... Done Reading TA section. Please wait... Done TA section has been backed up to "C:\Program Files\GsmServer\Medusa\Firmware\Sony Ericsson U20i TA Backup 29-11-2011 20_32_24.mf". Unlocking. Please wait... Done Disconnected Selected device model: Sony Ericsson U20i Connecting. Please wait... MI: RTCK reaction time 126 ns. Detected Core ID: 203C00E1 ERROR[000]: Unable to halt core. MI: RTCK reaction time 126 ns. Detected Core ID: 203C00E1 VREF level : 2.55 V CPU : Qualcomm MSM7227 Core ID : 203C00E1 MI: P15,C0,C0: 0x41069265 MI: Loading server. MI: Starting server. MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000037. MI: Detailed server caps: FLASH, CFG, ECC, WDOG, DWP MI: Watchdog configuration: 0xB800010C, 0x00000001... ok MI: Server init. MI: Received flash ID 0xA02055BC. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 00000037 Flash device: ST Micro 512Mb Flash ID : 002055BC Page size : 2048 bytes Block size : 64 pages (128 Kb) Block count: 4096 Flash size : 512 Mb Write protection disabled. MI: Setting configuration: 0xAAD400DA, 0x0044747E, 0x0000000D MI: Configuration done. Reading TA section. Please wait... Done TA section has been backed up to "C:\Program Files\GsmServer\Medusa\Firmware\Sony Ericsson U20i TA Backup 29-11-2011 20_34_42.mf". Erasing TA section. Please wait... Done Repairing. Please wait... MI: Server status 0xFFFFFFFF (not STAT_IDLE). ERROR[018]: Logical block operation failed at 1024 Kb (Hex address 0x00100000). Reason: Connection lost. MI: Server status 0xFFFFFFFF (not STAT_IDLE). ERROR[018]: Logical block operation failed at 1152 Kb (Hex address 0x00120000). Reason: Connection lost. MI: Server status 0xFFFFFFFF (not STAT_IDLE). ERROR[018]: Logical block operation failed at 0 Kb (Hex address 0x00000000). Reason: Connection lost. Selected device model: Sony Ericsson U20i Connecting. Please wait... MI: RTCK reaction time 189 ns. Detected Core ID: 203C00E1 ERROR[000]: Unable to halt core. MI: RTCK reaction time 189 ns. Detected Core ID: 203C00E1 ERROR[000]: Unable to halt core. MI: RTCK reaction time 189 ns. Detected Core ID: 203C00E1 VREF level : 2.55 V CPU : Qualcomm MSM7227 Core ID : 203C00E1 MI: P15,C0,C0: 0x41069265 MI: Loading server. MI: Starting server. MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000037. MI: Detailed server caps: FLASH, CFG, ECC, WDOG, DWP MI: Watchdog configuration: 0xB800010C, 0x00000001... ok MI: Server init. MI: Received flash ID 0xA02055BC. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 00000037 Flash device: ST Micro 512Mb Flash ID : 002055BC Page size : 2048 bytes Block size : 64 pages (128 Kb) Block count: 4096 Flash size : 512 Mb Write protection disabled. MI: Setting configuration: 0xAAD400DA, 0x0044747E, 0x0000000D MI: Configuration done. Reading TA section. Please wait... Done TA section has been backed up to "C:\Program Files\GsmServer\Medusa\Firmware\Sony Ericsson U20i TA Backup 29-11-2011 20_40_37.mf". Erasing TA section. Please wait... Done Repairing. Please wait... Done Disconnected Log file "C:\Program Files\GsmServer\Medusa\LOG\29-11-2011_21-35-34.log" created. 11/29/2011 9:35:37 PM > Welcome to Medusa Box Flasher version 1.0.2 11/29/2011 9:35:53 PM > -------------------------------------------------------------------------------- 11/29/2011 9:35:53 PM > Platform: SE Qualcomm 11/29/2011 9:35:53 PM > Selected model: U20i 11/29/2011 9:35:53 PM > Opening "U20i_2.1.1.A.0.6_WORLD.oct"...11/29/2011 9:35:53 PM > OK 11/29/2011 9:35:53 PM > Please, reconnect battery, hold "back" key and connect USB cable...11/29/2011 9:36:10 PM > OK 11/29/2011 9:36:10 PM > Reading info... 11/29/2011 9:36:10 PM > Chipset: S1 MSM7227 11/29/2011 9:36:10 PM > IMEI: 012342-00-573508-1 11/29/2011 9:36:10 PM > MSN: BX902BT4AW 11/29/2011 9:36:10 PM > Sending loader...11/29/2011 9:36:11 PM > OK 11/29/2011 9:36:11 PM > Writing Firmware... 11/29/2011 9:36:11 PM > Writing AMSS...11/29/2011 9:36:21 PM > OK 11/29/2011 9:36:21 PM > Writing AMSS_FS...11/29/2011 9:36:22 PM > OK 11/29/2011 9:36:22 PM > Writing CACHE...11/29/2011 9:36:22 PM > OK 11/29/2011 9:36:22 PM > Writing FOTA0...11/29/2011 9:36:23 PM > OK 11/29/2011 9:36:23 PM > Writing FOTA1...11/29/2011 9:36:23 PM > OK 11/29/2011 9:36:23 PM > Writing KERNEL...11/29/2011 9:36:26 PM > OK 11/29/2011 9:36:26 PM > Writing SYSTEM...11/29/2011 9:38:03 PM > OK 11/29/2011 9:38:03 PM > Writing USERDATA...11/29/2011 9:38:06 PM > OK 11/29/2011 9:38:06 PM > Shutting down...11/29/2011 9:38:06 PM > OK as you see advance procedures, easy repair, and full flash, successful, but phone remains the same, just vibrates and thats it. even using pc companion, seus or flash tool, i can think that it is hardware, but most of all phones, no water damage, no cracks, look like new, all with the same issue, i think software or definitely, coincidence that i received all 7 phones with hardware damage. 1 u20a 1 u20i 3 x10a and 2 x10i thank you. |
12-02-2011, 23:58 | #4 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | i have more 4pcs X10i All phone error when flashing by setool i have riff, erase,repair,full dump = just vibre after power on i have medusa too , erase,reapir TA, full flash = just vibra.. i think only H/W problem...like CPU or Flash Chip... i have question: why write 1GB full dump at 10h.........riff write full dump only on 1h,40m...why not suppoerted more than 1mhz speed on medusa? |
04-21-2012, 01:25 | #7 (permalink) |
Junior Member Join Date: Jun 2008
Member: 794702 Status: Offline Thanks Meter: 1 | Sir, I bought the jellyfish at 1 week and I'm exactly the same problem. I boot the recovery of 100% More So flashes the green power and vibrates no more. Will I have a definitive solution to this problem? in waiting. |
01-22-2013, 02:35 | #9 (permalink) |
No Life Poster Join Date: Oct 2004 Age: 47
Member: 86579 Status: Offline Thanks Meter: 70 | x10a only vibrate hello i came across this problem also.i have a x10a that came in today for flash.the problem with the phone is that it doesnt power on it just vibrates. i performed erase full flash,easy recovery, and than flashed phone with medusa flasher flash was successful.but phone still just vibrates when i try to power it on and green light comes on.when connected to USB phone goes into flash mode.if i power the phone on only vibrate and then connect usb cable it is not detected at all in device mananger.but when i just connect the usb cable phone goes straight into flash mode.no water damage.and looks like a new set.i cannot post log now cuz im not in the shop.i will post log tomorrow.i also have a u20a that i performed full erase,easy repair and flash via medusa flasher and no power on at all.pcb looks good.i changed flex and display also just to make sure that wasnt the problem but set is still dead.no power on.i can only get it into flash mode.will post log for that set also tomorrow. best regards gee4234 |
01-22-2013, 09:47 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Repair solution is tested many times, so this can be HW problem. Anyway, please post here full software logs with Repair and Write firmware procedures. |
08-28-2013, 04:00 | #11 (permalink) |
Registered User Join Date: Mar 2008 Location: riyadh,saudi arabia
Member: 721890 Status: Offline Thanks Meter: 35 | For yuor x10i, x10a, u20i, u20a please perform the next steps: 1. Connect device in Advanced Mode and make Erase of full flash. 2. Connect device in EasyRepair Mode and make Repair of the device by following the Wizard instructions. 3. After successful Repair of your device You have to put it to "Emergency Mode" to re-flash: i). Reconnect the battery; ii). Press and hold "Back" key; iii). Connect the USB Cable. 4. Look at the PC Device Manager and write here what the device appears when You put your X10a into Emergency mode. SEMC FLASH DEVICE on device manager after repair boot. i try this solution but still error on sending loader in flashing in octopus suite after repair boot in easy repair and erase flash on advance mode....!! still the same error,.. is this still software or is it a hardware problem..??? thanks and advance MEDUSA BOX and OCTOPUS BOX |
08-28-2013, 06:22 | #12 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Post here full software log with Repair procedure. Also have You re-flashed the phone by using Medusa Flasher after You have Repaired the device? Last edited by Octopus box; 08-28-2013 at 10:49. |
08-31-2013, 06:32 | #13 (permalink) |
Member: 721890 Status: Offline Thanks Meter: 35 | erase boot erase full flash easy repair device manager detection sending loader failed in octopus suite is this still software or is it hardware problem..?? thanks medusa box and octopus box.. |
how to unlock xperia x10i? | vadimv | Sony Android based phones | 2 | 06-20-2010 07:18 |
Please help X10i reboot use of camera!!! | IMQ | Sony Android based phones | 0 | 05-13-2010 08:54 |
can we unlock x10i??? | peter829 | SETool2 | 0 | 05-04-2010 23:37 |
Can I debrand Xperia X10a ? | cracker_jack | Cruiser Suite | 5 | 04-30-2010 07:03 |
X10i Unlock ???? | justmegt | Cruiser Suite | 1 | 04-21-2010 11:44 |
