01-27-2018, 13:05 | #1 (permalink) |
Freak Poster Join Date: Mar 2015 Location: Uzbekistan/ Namangan Age: 32
Member: 2365156 Status: Offline Thanks Meter: 112 | Xiaomi MI 5X (A1) can't erase phone [Answered] Last edited by Medusa Box; 01-28-2018 at 08:33. |
01-28-2018, 08:32 | #3 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. What do You want to erase exactly? Maybe, do You want to repair the device (boot)? Post here full Software log with all of perfromed operations with the device, we will check. Also read and always follow these rules: http://forum.gsmhosting.com/vbb/f664...leted-2165828/, http://forum.gsmhosting.com/vbb/f62/...rules-1591101/. |
01-28-2018, 14:06 | #4 (permalink) |
Member: 2365156 Status: Offline Thanks Meter: 112 | I try repair boot but not helped! Still same dead Device : CoreID_000460E1 Core : Qualcomm MSM8953 Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) Connect successful. --------------------------------------------------------------- SW: 1.5.2; FW: 1.1.0. P00: GPT (00000000, 00020000) 64 MB P01: modem (00020000, 0002A000) 84 MB P02: fsc (00060000, 00000002) 1024 b P03: ssd (00060002, 00000010) 8 KB P04: sbl1 (00060012, 00000400) 512 KB P05: sbl1bak (00060412, 00000400) 512 KB P06: rpm (00060812, 00000400) 512 KB P07: rpmbak (00060C12, 00000400) 512 KB P08: tz (00061012, 00001000) 2048 KB P09: tzbak (00062012, 00001000) 2048 KB P10: devcfg (00063012, 00000200) 256 KB P11: devcfgbak (00063212, 00000200) 256 KB P12: dsp (00063412, 00008000) 16 MB P13: modemst1 (0006B412, 00000C00) 1536 KB P14: modemst2 (0006C012, 00000C00) 1536 KB P15: DDR (00080000, 00000040) 32 KB P16: fsg (00080040, 00000C00) 1536 KB P17: sec (00080C40, 00000020) 16 KB P18: splash (000A0000, 00005800) 11 MB P19: aboot (000C0000, 00000800) 1024 KB P20: abootbak (000C0800, 00000800) 1024 KB P21: boot (000C1000, 00020000) 64 MB P22: recovery (000E1000, 00020000) 64 MB P23: devinfo (00101000, 00000800) 1024 KB P24: system (00101800, 00600000) 3072 MB P25: cache (00720000, 00080000) 256 MB P26: persist (007A0000, 00010000) 32 MB P27: misc (007B0000, 00000800) 1024 KB P28: keystore (007B0800, 00000400) 512 KB P29: config (007B0C00, 00000040) 32 KB P30: oem (007B0C40, 00080000) 256 MB P31: limits (00840000, 00000040) 32 KB P32: mota (00860000, 00000400) 512 KB P33: dip (00860400, 00000800) 1024 KB P34: mdtp (00860C00, 00010000) 32 MB P35: syscfg (00870C00, 00000400) 512 KB P36: mcfg (00871000, 00002000) 4 MB P37: lksecapp (00880000, 00000100) 128 KB P38: lksecappbak (00880100, 00000100) 128 KB P39: cmnlib (00880200, 00000200) 256 KB P40: cmnlibbak (00880400, 00000200) 256 KB P41: cmnlib64 (00880600, 00000200) 256 KB P42: cmnlib64bak (00880800, 00000200) 256 KB P43: keymaster (00880A00, 00000200) 256 KB P44: keymasterbak (00880C00, 00000200) 256 KB P45: apdp (008A0000, 00000200) 256 KB P46: msadp (008A0200, 00000200) 256 KB P47: dpo (008A0400, 00000010) 8 KB P48: logdump (008A0410, 00020000) 64 MB P49: cust (008C0410, 001A0000) 832 MB P50: userdata (00A60410, 06A1BBCF) 53.05 GB Repairing from file "C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/XIAOMI_MI_5X(A1)_USB.srf". Write data verification is enabled. Writing GPT partition... Done. Writing modem_a partition... Done. Writing modem_b partition... Done. Writing fsc partition... Done. Writing ssd partition... Done. Writing sbl1 partition... Done. Writing sbl1bak partition... Done. Writing rpm partition... Done. Writing rpmbak partition... Done. Writing tz partition... Done. Writing tzbak partition... Done. Writing devcfg partition... Done. Writing devcfgbak partition... Done. Writing dsp partition... Done. Writing DDR partition... Done. Writing fsg partition... Done. Writing sec partition... Done. Writing splash partition... Done. Writing aboot partition... Done. Writing abootbak partition... Done. Writing boot_a partition... Done. Writing boot_b partition... Done. Writing devinfo partition... Done. Writing persist partition... Done. Writing misc partition... Done. Writing keystore partition... Done. Writing config partition... Done. Writing limits partition... Done. Writing mota partition... Done. Writing dip partition... Done. Writing mdtp partition... Done. Writing syscfg partition... Done. Writing mcfg partition... Done. Writing lksecapp partition... Done. Writing lksecappbak partition... Done. Writing cmnlib partition... Done. Writing cmnlibbak partition... Done. Writing cmnlib64 partition... Done. Writing cmnlib64bak partition... Done. Writing keymaster partition... Done. Writing keymasterbak partition... Done. Writing apdp partition... Done. Writing msadp partition... Done. Writing dpo partition... Done. Writing logdump partition... Done. Smart Repair is successfully complete. SW: 1.5.2; FW: 1.1.0. Disconnected. |
01-28-2018, 18:13 | #6 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | To erase full flash try to do the following: connect the device, select "Full" option in Software and press "Erase" button. Also You can try to do "Factory Repair" ("Factory repair" tab in Software) using original "*.xml" firmware for this device - probably, boot loader in used SRF file is not compatible to your device and writing original firmware will help to solve the problem. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
