05-11-2020, 16:30 | #1 (permalink) |
Freak Poster Join Date: Feb 2009 Location: Uruguay
Member: 980958 Status: Offline Thanks Meter: 16 | Xiaomi Redmi 7A QUALCOMM HS-USB QDLOADER 9008 mode [Answered] https://drive.google.com/file/d/1HD2...ew?usp=sharing |
05-11-2020, 16:42 | #2 (permalink) | |
No Life Poster Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Quote:
The Following User Says Thank You to hitech care For This Useful Post: |
05-12-2020, 15:29 | #5 (permalink) |
Member: 980958 Status: Offline Thanks Meter: 16 | Welcome to Medusa Pro Software version 2.0.5. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Broadcom Corp Contacted SmartCard 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC HAG4a2 Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484147346132A53C59D063362D Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HAG4a2 Product revision : 10.5 Product serial number : (hex) 3C59D063 Manufacturing date : 03/2019 --------------------------------------------------------------- CSD Info CSD : D02701328F5903FFFFFFFFE78A400017 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 1703936 Number of sectors : 6291456 Device Manufacturer : Xiaomi Build ID : PKQ1.190319.001 Display Build ID : ZQL1533-pine-build-20200208215833 Release ID : 9 Device Model : Redmi 7A Device Name : pine Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : pine-user 9 PKQ1.190319.001 V11.0.6.0.PCMMIXM release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/HAG4a2_12_05_2020_11_27_49.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.5; FW: 1.24. P00: GPT (00000000, 00000028) 20 KB P01: fsc (00000028, 00000010) 8 KB P02: ssd (00000038, 00000010) 8 KB P03: dpo (00000048, 00000010) 8 KB P04: sec (00000058, 00000020) 16 KB P05: DDR (00000078, 00000040) 32 KB P06: limits (000000B8, 00000040) 32 KB P07: config (000000F8, 00000040) 32 KB P08: bk1 (00000138, 00000048) 36 KB P09: bk2 (00000180, 00000080) 64 KB P10: vbmeta (00000200, 00000080) 64 KB P11: vbmetabak (00000280, 00000080) 64 KB P12: bk3 (00000300, 00000100) 128 KB P13: devcfg (00000400, 00000200) 256 KB P14: devcfgbak (00000600, 00000200) 256 KB P15: apdp (00000800, 00000200) 256 KB P16: msadp (00000A00, 00000200) 256 KB P17: sbl1 (00000C00, 00000400) 512 KB P18: sbl1bak (00001000, 00000400) 512 KB P19: rpm (00001400, 00000400) 512 KB P20: rpmbak (00001800, 00000400) 512 KB P21: mota (00001C00, 00000400) 512 KB P22: keystore (00002000, 00000400) 512 KB P23: syscfg (00002400, 00000400) 512 KB P24: cmnlib (00002800, 00000800) 1024 KB P25: cmnlibbak (00003000, 00000800) 1024 KB P26: cmnlib64 (00003800, 00000800) 1024 KB P27: cmnlib64bak (00004000, 00000800) 1024 KB P28: keymaster (00004800, 00000800) 1024 KB P29: keymasterbak (00005000, 00000800) 1024 KB P30: misc (00005800, 00000800) 1024 KB P31: aboot (00006000, 00000800) 1024 KB P32: abootbak (00006800, 00000800) 1024 KB P33: dip (00007000, 00000800) 1024 KB P34: bk4 (00007800, 00000800) 1024 KB P35: tz (00008000, 00001000) 2048 KB P36: tzbak (00009000, 00001000) 2048 KB P37: mcfg (0000A000, 00002000) 4 MB P38: devinfo (0000C000, 00004000) 8 MB P39: dtbo (00010000, 00004000) 8 MB P40: dtbobak (00014000, 00004000) 8 MB P41: modemst1 (00018000, 00004000) 8 MB P42: modemst2 (0001C000, 00004000) 8 MB P43: fsg (00020000, 00004000) 8 MB P44: bk5 (00024000, 00004000) 8 MB P45: splash (00028000, 00008000) 16 MB P46: dsp (00030000, 00008000) 16 MB P47: dspbak (00038000, 00008000) 16 MB P48: persist (00040000, 00010000) 32 MB P49: persistbak (00050000, 00010000) 32 MB P50: mdtp (00060000, 00010000) 32 MB P51: mdtpbak (00070000, 00010000) 32 MB P52: boot (00080000, 00020000) 64 MB P53: recovery (000A0000, 00020000) 64 MB P54: logdump (000C0000, 00020000) 64 MB P55: cache (000E0000, 00080000) 256 MB P56: modem (00160000, 00040000) 128 MB P57: system (001A0000, 00600000) 3072 MB P58: vendor (007A0000, 00200000) 1024 MB P59: cust (009A0000, 00100000) 512 MB P60: userdata (00AA0000, 012B9FDF) 9.363 GB Backuping modemst1 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/HAG4a2_modemst1_0x18000_0x4000_12_05_2020_11_27_49 .bin file... Reading. Please wait... Done. Elapsed time 00:00:03 SW: 2.0.5; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/HAG4a2_modemst2_0x1c000_0x4000_12_05_2020_11_27_49 .bin file... Reading. Please wait... Done. Elapsed time 00:00:03 SW: 2.0.5; FW: 1.24. Backuping fsg partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/HAG4a2_fsg_0x20000_0x4000_12_05_2020_11_27_49.bin file... Reading. Please wait... Done. Elapsed time 00:00:03 SW: 2.0.5; FW: 1.24. |
