Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 06-11-2012, 15:51   #1 (permalink)
LuisinhoCell's Avatar
Member: 264903
Sonork: 1584531
Xperia X10A repair 100% but not connecting
I have an X10 that only vibrates
easy repair ok
write to flash ok
And the phone will not turn on only vibrates
Old 06-11-2012, 15:55   #2 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Hello.
Please try to do the next:
1. Connect the phone in Advanced Mode and make Erase Full flash.
2. Connect the phone in EasyRepair Mode and make Repair again.
3. Fully charge phone's battery and write firmware.
Old 06-11-2012, 16:48   #3 (permalink)
Member: 264903
Sonork: 1584531
Originally Posted by Medusa Box View Post
Hello.
Welcome to Medusa Box Flasher version 1.0.6
Platform: SE Qualcomm
Selected model: X10a
Opening "X10a_3.0.1.G.0.75_CUST-US GENERIC 1233-8200.oct"...OK
Please, reconnect battery, hold "back" key and connect USB cable...OK
Reading info...
Chipset: S1 QSD8250
IMEI: 359420-03-028135-3
MSN: CB511LGRA4
Sending loader...OK
Writing Firmware...
Writing AMSS...OK
Writing AMSS_FS...OK
Writing CACHE...OK
Writing DSP1...OK
Writing FOTA0...OK
Writing FOTA1...OK
Writing KERNEL...OK
Writing SYSTEM...OK
Writing USERDATA...OK
Shutting down...OK
still did not work
Old 06-11-2012, 17:55   #4 (permalink)
Member: 468656
Maybe your phone hardware! CPU chip has problem...
The Following User Says Thank You to duyphuong3000 For This Useful Post:
Old 09-05-2012, 19:13   #5 (permalink)
PILONCILLO's Avatar
Member: 26692
i have one same problem.follow those steps and flash failed
Welcome to Medusa Box Flasher version 1.1.0
Opening "X10a_2.0.A.0.504_WORLD_GENERIC.oct"...OK
Reading info...
Chipset: S1 QSD8250
IMEI: 359420-03-294826-4
MSN: CB511LGRA4
Sending loader...Failed!
Reading info...
Chipset: S1 QSD8250
MSN: CB511LGRA4
Reading info...
Chipset: S1 QSD8250
MSN: CB511LGRA4
Reading info...
Chipset: S1 QSD8250
MSN: CB511LGRA4
Reading info...
Chipset: S1 QSD8250
MSN: CB511LGRA4
Selected model: X10i
Reading info...
Chipset: S1 QSD8250
MSN: CB511LGRA4
its hw fault?
Old 09-06-2012, 07:03   #6 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
What si the state of your phone? What is the battery level exactly?
Old 09-08-2012, 06:08   #7 (permalink)
zorgy_1979's Avatar
Member: 1331464
I have done a lot of se phones by full erase and easy repair solution. All software problem phones was done only by medusa box and medusa flasher. Think you have problem with damage flash chip. Because jtag see it correctly, but really cant erase it and write recovery zone.
The Following User Says Thank You to zorgy_1979 For This Useful Post:
Old 09-08-2012, 20:49   #8 (permalink)
PILONCILLO's Avatar
Member: 26692
i have another x10a.
Medusa JTAG Hardware S64 revision C.
TAP ID. detectado: 1BA000E1, Largo de IR= 4.
TAP ID. detectado: 202400E1, Largo de IR= 4.
Velocidad de JTAG: Auto (RTCK)
Nivel de VREF: 2.59 V.
Tipo de procesador: Qualcomm QSD8250
ID. del núcleo: 202400E1
Flash Chip: Micron 1024Mb
ID. de la flash: 002C55B3
Tamaño de la pagina: 2048 bytes
Tamaño del bloque: 64 páginas (128 Kb)
Cantidad de bloques: 8192
Tamaño total de la flash: 1024 Mb
Leyendo la sección TA. Por favor espere... Terminado.
La sección TA ha sido guardada en "C:\Archivos de programa\GsmServer\Medusa\Firmware\Sony Ericsson XPERIA X10a TA Backup 08-09-2012 14_40_21.mf".
Borrando la sección TA. Por favor espere... Terminado.
Por favor espere, reparando... Terminado.
Desconectado.
Reparación terminada.
i do that:
Hello.
-tryng whit medusa flasher.:-------------------------------------------------------------------------------
Reading info...
Chipset: S1 QSD8250
IMEI: 359420-03-227373-9
MSN: CB511LGRA4
Sending loader...OK
Writing Firmware...Failed!
all x10a make same error why?
conect phone to medussa rj and usb only .they dont have any other pwr source its that all right?.
when flash battery its allmost full chargued.
Old 09-10-2012, 06:41   #9 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Please use fully charged battery (at least to 4.2V)! Uninstall all BB software, modem dashboard software and PC Suite software. Also please don't use USB hubs or PCI USB ports, You need to use motherboard USB ports only!
Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing!
Also please try to write firmware on another PC.
Old 09-10-2012, 18:01   #10 (permalink)
PILONCILLO's Avatar
Member: 26692
i think repair process its bad even when say its ok.
i see unlock whit medussa its ok for many users,but repair its bad.
that all suggestions clean pc no hub are innecessary.
any way i do that but same situation.
then you need work about x10a repair.
Old 09-10-2012, 18:09   #11 (permalink)
Member: 1438954
change the power ic problem solved 10000000% no need to flash .........
The Following User Says Thank You to manyonga For This Useful Post:
Old 09-12-2012, 19:03   #12 (permalink)
PILONCILLO's Avatar
Member: 26692
can you post a pic for that?
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 04-10-2013 02:07
winlock wintesla m2bus do not work Bigbrothers2000 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 01-26-2000 13:31
Nokia Datasuite Connection Failure Judesp Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 12-27-1999 08:36
100% unlock1 for Nokia 6150 v5.17 ------,......... cIVIc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 11-10-1999 01:00
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-28-1999 14:56
Page generated in 0.65519 seconds with 11 queries
