10-28-2017, 08:46 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Colombia
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | xt1681 dead by frp [Solved] Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.2V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC HBG4a2 Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB --------------------------------------------------------------- CID Info CID : 90014A484247346132A529649899148D Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HBG4a2 Product revision : 10.5 Product serial number : (hex) 29649899 Manufacturing date : 01/2017 --------------------------------------------------------------- CSD Info CSD : D02701328F5903FFFFFFFFE78A400017 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15265792 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/HBG4a2_28_10_2017_02_12_13.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.6; FW: 1.22. P00: GPT (00000000, 00000100) P01: sbl1 (00000100, 00000400) P02: rpm (00000500, 00000200) P03: tz (00000900, 00000E00) P04: devcfg (00001900, 00000080) P05: aboot (00001B00, 00000C00) P06: cmnlib (00002700, 00000200) P07: cmnlib64 (00002900, 00000200) P08: keymaster (00002B00, 00000200) P09: prov (00002D00, 00000180) P10: sbl1bak (00002F00, 00000400) P11: rpmbak (00003300, 00000200) P12: tzbak (00003700, 00000E00) P13: devcfgbak (00004700, 00000080) P14: abootbak (00004900, 00000C00) P15: cmnlibbak (00005500, 00000200) P16: cmnlib64bak (00005700, 00000200) P17: keymasterbak (00005900, 00000200) P18: provbak (00005B00, 00000180) P19: modem (00005D00, 00032000) P20: fsc (00037D00, 00000002) P21: ssd (00037D02, 00000010) P22: dsp (00037D12, 00008000) P23: DDR (0003FE00, 00000040) P24: sec (0003FE40, 00000020) P25: utags (0003FF00, 00000400) P26: utagsBackup (00040300, 00000400) P27: modemst1 (00040700, 00001000) P28: modemst2 (00041700, 00001000) P29: fsg (00042700, 00004000) P30: persist (00046700, 00010000) P31: frp (00056700, 00000400) P32: cid (00056B00, 00000100) P33: logo (00056C00, 00008000) P34: carrier (0005EC00, 00008000) P35: metadata (00066C00, 00000400) P36: kpan (00067000, 00004000) P37: boot (0006B000, 00008000) P38: recovery (00073000, 0000A0C8) P39: misc (0007D100, 00000800) P40: limits (0007D900, 00000040) P41: mota (0007DA00, 00000400) P42: dip (0007DE00, 00000800) P43: syscfg (0007E600, 00000400) P44: logs (0007EA00, 00001000) P45: apdp (0007FA00, 00000200) P46: msadp (0007FC00, 00000200) P47: dpo (0007FE00, 00000010) P48: padA (0007FF00, 00000100) P49: sp (00080000, 00004000) P50: hw (00084000, 00004000) P51: oem (00088000, 00148000) P52: cache (001D0000, 00080000) P53: system (00250000, 006C0000) P54: userdata (00910000, 0312DFDF) Backuping Gpt partition... Opening C:/Program Files/Medusa Pro Software/Backups/HBG4a2_Gpt_0x0_0x100_28_10_2017_02_12_13.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.4.6; FW: 1.22. Backuping Cid partition... Opening C:/Program Files/Medusa Pro Software/Backups/HBG4a2_Cid_0x56b00_0x100_28_10_2017_02_12_13.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.4.6; FW: 1.22. Erasing. Please wait... Erasing partition frp... Done. Done Disconnected. SW: 1.4.6; FW: 1.22 Last edited by Medusa Box; 10-29-2017 at 13:52. |
10-29-2017, 13:25 | #4 (permalink) | |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Quote:
If You have created backup of FRP partition before erasing it (but I don't see read/backup operation in your Software log), You can try to write this backup back into your phone. Also, You can try to find an original firmware with "flashfile.xml" for this phone and do "Factory Repair". BTW, why You not perfromed "Reset FRP" operation, but erase FRP partition manually? Software automatically create all necessary backups before reseting FRP. | |
