11-13-2017, 10:37 | #1 (permalink) |
No Life Poster Join Date: Jun 2011 Location: pakistan
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | y530-u00 after repaired successfully imei null/null help Code: Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Huawei Model : Y530-U00 SRF : C:/Users/GSM City/Downloads/Huawei_Y530-U00/Huawei_Y530-U00_EMMC_H4G1D.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H4G1d Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A4834473164040303A56CC891A7 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G1d Product revision : 0.3 Product serial number : (hex) 3A56CC8 Manufacturing date : 09/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : e9000000 bytes Device sector size : 512 bytes Partition offset : 1589248 Number of sectors : 2097152 Device Manufacturer : Huawei Device Platform : msm8610 Build ID : HuaweiY530-U00 Display Build ID : Y530-U00V100R001C900B511 Release ID : 4.3 Device Model : HUAWEI Y530-U00 Device Name : Y530-U00 Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Build Description : msm7627a-eng 2.3.5 GRJ90 eng.hongtao.20111013.064550 test-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H4G1d_11_10_2017_15_05_00.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.5; FW: 1.22. P00: GPT (00000000, 00000022) P01: sbl1 (00000022, 00000400) P02: sdi (00000422, 00000040) P03: DDR (00002000, 00000040) P04: rpm (00004000, 000003E8) P05: tz (000043E8, 000003E8) P06: aboot (000047D0, 00002BB0) P07: pad (00007380, 00000800) P08: oeminfo (00007B80, 00020000) P09: modemst1 (00027B80, 00002000) P10: modemst2 (00029B80, 00002000) P11: modem (0002C000, 00030000) P12: fsg (0005C000, 00002000) P13: fsc (0005E000, 00000002) P14: ssd (0005E002, 00000010) P15: log (0005E012, 00010000) P16: bkbootup (00070000, 00020000) P17: persist (00090000, 00004000) P18: boot (00094000, 00006000) P19: recovery (0009A000, 00008000) P20: cust (000A2000, 00080000) P21: cache (00122000, 00060000) P22: misc (00182000, 00002000) P23: system (00184000, 00200000) P24: userdata (00384000, 00200000) P25: grow (00584000, 001C3FDF) Repairing from file "C:/Users/GSM City/Downloads/Huawei_Y530-U00/Huawei_Y530-U00_EMMC_H4G1D.srf". Write data verification is enabled. Writing GPT partition... Done. Writing sbl1 partition... Done. Writing sdi partition... Done. Writing DDR partition... Done. Writing rpm partition... Done. Writing tz partition... Done. Writing aboot partition... Done. Writing pad partition... Done. Writing oeminfo partition... Done. Writing modemst1 partition... Done. Writing modemst2 partition... Done. Writing modem partition... Done. Writing fsg partition... Done. Writing fsc partition... Done. Writing ssd partition... Done. Writing log partition... Done. Writing bkbootup partition... Done. Writing persist partition... Done. Writing boot partition... Done. Writing recovery partition... Done. Writing cust partition... Done. Writing cache partition... Done. Writing misc partition... Done. Writing system partition... Done. Writing userdata partition... Done. Writing grow partition... Done. Smart Repair is successfully complete. SW: 1.4.5; FW: 1.22. Disconnected. if yes then how? |
11-13-2017, 10:58 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Repairing IMEI for this device is not supported at the moment by Medusa. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
