02-27-2014, 07:25 | #2 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Maharagama, Srilanka
Member: 661090 Status: Offline Sonork: 100.1616818 Thanks Meter: 541 | download s7562 dll on support put that dll file in phones folder in x:\Program Files\ORT\phones opern ort plus go to easy mode select samsung > s7562 click pinouts solder pinouts connect power supply or battery plug usb cable press repair |
The Following 2 Users Say Thank You to jatchaminda For This Useful Post: |
02-27-2014, 22:35 | #3 (permalink) |
Insane Poster Join Date: Jul 2013
Member: 1978525 Status: Offline Thanks Meter: 3 | Samsung GT-S7562 MSM7227A 2.6V TAP0,IRLength:4,DeviceID:0x106230E1 EmbeddedICE ver:6. Actual Density:0xE9000000 FlashID:0x4A5330301501004A,SubFlashID:0x0770306441 036D08 BlockSize:512 PageSize:512 Density:0MB Actual Density:0xE9000000 Writing Boot... 100% Boot restored. Sir, after restoring boot the phone still does not go into download mode, just reboot please help |
02-28-2014, 15:28 | #5 (permalink) |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | if you not done via jtag just remove wifi controler ic your phone will be work,,,,,, follow this post http://forum.gsmhosting.com/vbb/f258...-dead-1686809/ |
The Following User Says Thank You to chand_gee For This Useful Post: |
02-28-2014, 15:28 | #6 (permalink) |
03-03-2014, 22:32 | #7 (permalink) | |
Freak Poster Join Date: Jan 2009 Location: Germany/NRW
Member: 936229 Status: Offline Sonork: 1606911 Thanks Meter: 115 | Quote:
Write only first 32MB from working Dump and your Problem solved,you will have the Download Mode again and can flash via Odin,tested many times,but with other JTAG Tools,but is same procedure. | |
