Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > GPGORT
Old 03-13-2012, 07:34   #1 (permalink)
bogg7's Avatar
Member: 198113
Sonork: 100.161124
Htc 7 trophy problem repairing by ort jtag
HTC 7 TROPHY PROBLEM REPAIRING BY ORT JTAG
please help me to analyze the problem
here are some screenshots
I use this pinout from ORT support but i edit a liitle in the picture to make it easy understand
I try to detect in the first version of ORT plus 1.00 just if it is connecting or not so its connecting and there is no problem but unsupported nand
as you can see no problem in reading so the connection with the box is correct
this is my problem after trying to use almost all the version of ORT plus when i try to scan the phone the software totally hanging so i disable the antivirus but same problem even i use the latest version of ORT PLUS 1.73
and if successfuly scan and trying with one botton repair its failing
please help me to figure out what is the problem
im using the first ORT BOX the white one
just confuse if it there is a problem using ort plus software because this not a gpg ort may be there is a conflict with the software or there is something im doing wrong
thanks
regards bogg7 aka t@teks
Old 03-13-2012, 11:40   #2 (permalink)
rajeshchiyyan's Avatar
Member: 1347585
Sonork: 100.1596390
Uninstall driver and install from support and try again ... use the different ports
Old 03-13-2012, 12:07   #3 (permalink)
Electroboys's Avatar
Member: 6594
Sonork: 100.27285
Do not use PS_HOLD connect usb cable
Best Regard
Oz
Old 03-13-2012, 13:55   #4 (permalink)
bogg7's Avatar
Member: 198113
Sonork: 100.161124
Best Regard
Oz
i finish reinstalling the driver and restart i also try with another pc same problem
Best Regard
Oz
i removed the ps hold and also connected to ub then follow the instruction from support
this is i get in 1.00 and 1.74
whats probably my problem
the model is HTC 7 TROPHY PC40100 i think this is different from HTC 7 TROPHY from support
is this supported sir
thank you
Old 03-13-2012, 14:34   #5 (permalink)
Member: 6594
Sonork: 100.27285
find me on sonork , lets check this phone together !
Best Regards
Oz
Old 03-14-2012, 07:25   #6 (permalink)
littmanr's Avatar
Member: 190377
I experimented same problems with mozart and LG optimus 7, so i solved using se x10 halth method, bcoz qsd8x50
Old 03-14-2012, 08:52   #7 (permalink)
bogg7's Avatar
Member: 198113
Sonork: 100.161124
whats that method can i see that method thanks
Old 03-15-2012, 04:34   #8 (permalink)
littmanr's Avatar
Member: 190377
Easy using last version, select model SE X10, try with rtck or tck 1MHZ
Old 03-15-2012, 07:39   #9 (permalink)
bogg7's Avatar
Member: 198113
Sonork: 100.161124
i try that but same problem i got its halting
Old 03-20-2012, 21:40   #10 (permalink)
NEO-TECH's Avatar
Member: 750498
i have same problem with htc trophy, please help me, tell me waht to do for solve this
Old 03-22-2012, 14:13   #11 (permalink)
Member: 201840
same problem with sam i9001
Old 05-08-2012, 01:53   #12 (permalink)
NEO-TECH's Avatar
Member: 750498
finaly i could flash full raw backup from support, i used that pinout, without pshold and without vref, yes! without vref i get good connection, with usb cable and full charged battery, the full raw backup work perfectly, but htc trophy repair file always failed, please electroboy check that file, becouse i think its wrong or have problems, so that its all with htc trophy, the pinout work, the full raw backup work too, good luck!
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 08-29-2010 20:17
GId1 problem old_man Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 10-18-2006 15:21
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 09-11-1999 17:39
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 07-16-1999 00:44
Page generated in 0.55704 seconds with 11 queries
