Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GPGORT
Old 05-03-2012, 16:25   #1 (permalink)
Member: 528793
Thanks Meter: 9
s5260 repair boot problem [ Solved ]
after write dump phone still dead
Old 05-03-2012, 17:25   #2 (permalink)
Member: 528793
Thanks Meter: 9
restore 5260 bcmboot failed
Vref:2.706V
TCK:RTCK+
Model:GT-S5260
EmbeddedICE ver:6.
CPUID:0x07926F0F,BCM21XX,IOLevel:3V
FlashID:0x004000EC
BlockSize:131072
PageSize:2048
Density:256MB
TotalBlockNum:2048
Found bad block:0
Found bad block:1
Found bad block:2
Found bad block:3
Found bad block:4
Found bad block:5
Found bad block:6
Found bad block:7
Found bad block:8
Found bad block:9
Found bad block:10
Found bad block:11
Found bad block:12
Found bad block:13
Found bad block:14
Found bad block:15
Found bad block:16
Found bad block:17
Found bad block:18
Found bad block:19
Found bad block:20
Found bad block:21
Found bad block:22
Found bad block:23
Found bad block:24
Found bad block:25
Found bad block:26
Found bad block:27
Found bad block:28
Found bad block:29
Found bad block:30
Found bad block:31
Found bad block:32
Found bad block:33
Found bad block:34
Found bad block:35
Found bad block:36
Found bad block:37
Found bad block:38
Found bad block:39
Found bad block:40
Found bad block:41
Found bad block:42
Found bad block:43
Found bad block:44
Found bad block:45
Found bad block:46
Found bad block:47
Found bad block:48
Found bad block:49
Found bad block:50
Found bad block:51
Found bad block:52
Found bad block:53
Found bad block:54
Found bad block:55
Found bad block:56
Found bad block:57
Found bad block:58
Found bad block:59
Found bad block:60
Found bad block:61
Found bad block:62
Found bad block:63
Found bad block:64
Found bad block:65
Found bad block:66
Found bad block:67
Found bad block:68
Found bad block:69
Found bad block:70
Found bad block:71
Found bad block:72
Found bad block:73
Found bad block:74
Found bad block:75
Found bad block:76
Found bad block:77
Found bad block:78
Found bad block:79
Found bad block:80
Found bad block:81
Found bad block:82
Found bad block:83
Found bad block:84
Found bad block:85
Found bad block:86
Found bad block:87
Found bad block:88
Found bad block:89
Found bad block:90
Found bad block:91
Found bad block:92
Found bad block:93
Found bad block:94
Found bad block:95
Found bad block:96
Old 05-03-2012, 19:31   #3 (permalink)
Member: 528793
Thanks Meter: 9
3h please wait patiently..............
Old 05-04-2012, 08:06   #4 (permalink)
Electroboys's Avatar
Member: 6594
Sonork: 100.27285
Thanks Meter: 22,500
Hi ,
Please do it with RTCK Selected !
Connect USB Cable because it seems your phone loses power or try hold the power button
Other options you selected model GT-S5260 is fine .
Best Regards
Oz
Old 05-07-2012, 22:12   #5 (permalink)
Member: 528793
Thanks Meter: 9
sucessfully repaired s5260 with ort
thnx Mr_Electroboys
The Following User Says Thank You to mama2001 For This Useful Post:
Old 05-08-2012, 03:00   #6 (permalink)
Member: 6594
Sonork: 100.27285
Good Job .
Best Regards
Oz
Old 05-08-2012, 03:08   #7 (permalink)
Member: 1267389
Sonork: 100.1607740
Thanks Meter: 14
thankz bro
job well done.
br,
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 10-16-2013 08:16
GId1 problem old_man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-18-2006 15:21
6110 5.47 sw unlock problem gsms Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-21-1999 19:43
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.27847 seconds with 10 queries
